Question about Toshiba satellite c660
No beep at all on boot up.
USB ports not working
  • 4 more comments
  • Roy Clayton Jan 17, 2013
    forgot to say, laptop works perfectly apart from this
    toshina satellite pro C660. Tried the usual Device Manager uninstall. System information says drivers not installed,
    beep is enabled and speakers do work
    don't know if this helps; 5.06v available at usb ports
  • Roy Clayton Jan 18, 2013
    Thanks again Max. No, it is not working. It recognises something has been connected and even comes up with it;s name but it tries to install the appropriate driver but FAILS every time. The USB ports are unusable.
  • max carson
    max carson Jan 18, 2013
    I have been reading some forums, the USB issue seems widespread. Try this FIX IT from MS : http://answers.microsoft.com/en-us/windo... OR :http://www.drivertoshiba.com/satellite-p... Take a look at the Toshiba Forum :http://forums.computers.toshiba-europe.c...
  • Toshiba Master
  • 7,627 Answers
Try a system restore to a date before the issue. The drivers can be found here: http://uk.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=UK
Posted on Jan 17, 2013
  • 2 more comments
    Trying that now. Thanks Max.
    No joy. I took it back to restore point prior to the last update concerning the usb ports
    Having done system restore it now recognises when usb memory is put in it, even recognising it's name but it install the driver.
  • max carson
    max carson Jan 17, 2013
    That's what it's suppose to do. When you add USB devices your software will ID the hadrware and apply the correct driver. So it's working properly?
The usb cable on my ps3 is not working will not play on any tv in house it plays with hdmi cables
Playstation 3's will not output display information via usb, it does although have a traditional Playstation style connector port for displaying via component cable/ AV cable. To switch to this display setting without having access to an HDMI television press and hold the power button until the PS3 beeps for a second time. Pressing once it will beep but continue holding until the device beeps again and it will boot into a display "safe mode" and ask you to verify your display settings.
Oct 11, 2014 | Sony Playstation 3 (PS3) Console
Keyboard will not work
Try another USB port. Sometimes, the port is associated with a device. Or, maybe the problem is that the keyboard itself is not working at all. In that case, the PC makes beeps on booting.
Nov 22, 2013 | Computers & Internet
Dell Precision T1500 beeping 6 times and will not boot up.
Remove whatever USB cables in the front USB ports below the DVD. Then try starting it should work. If not remove USB from the rear one at a time. Once it restarts replace USB cables into ports.
Mar 11, 2013 | Dell Dimension 3100 PC Desktop
I WANT TO MAKE MY PEN DRIVE AS BOOTABLE PENDRIVE FOR WINDOWS XP
The USB port on most computers is not a bootable USB port. Only after Windows has started up. the USB device driver is running then the USB port will work
UNLESS
Some later model computers/laptop have a bootable USB port and you can change the boot order in the BIOS configuration and change the devices boot order to make the USB port the first boot device.
Feb 22, 2011 | Computers & Internet
Have a Intell D865PERL getting either 6 or 7 beeps when booting, can't be sure which. System will not boot but just beep with PS2 keyboard installed but will boot with keyboard removed. BIOS is version...
It's likely a bad keyboard- try using either an usb keyboard or another ps2 keyboard- if it works and boots normally with a different keyboard, the issue was the bad keyboard. If not, then the ps2 port has gone bad. (you could still use usb)
Feb 01, 2011 | Intel D865PERL Motherboard
Intel d 865 gsa mother board is working but not display no beep what is the problem
i thinks it's not working, check again.....
no display, no beep.....simple symptom of a dead MB
the quality of the MB is all components will work together, even if one component in it fails the MB is dead.....
this rule is not applicable to the following devices in the MB
inbuilt sound cards, or
either of the USB ports or
mouse port, keyboard port
As you can use an external device like a USB sound adaptor insted of the internal sound card for your speaker/sound.
The same goes for mouse and keyboard, you can buy keyboards/mouse that work thru USB
The same is of a USB port, if one of the USB ports fail you have the other ports to use, if all of the USB ports fail then you can use a external USB connector to a LAN port and make the LAN port a USB device.
also.....there is no option..... that you can change one of the components.....they all are embeded in the circuit board, it's cost effective to get a new MB than repair the defective component.....
all the best
Nov 18, 2010 | Intel Motherboard
Keyboard not responding at startup
Do you mean when it's initially starting up: before the POST beep, or do you mean after it boots into the operating system? Either way I would try to switch it to a different USB port before or during start-up. It could be that the USB port has gone bad, or for some reason there's a glitch and the keyboard and port aren't syncing up correctly right away.
Apr 10, 2010 | AcerPower 1000 (AP1000EA380M) PC Desktop
HP Pavilion ze2308wm won't boot up
Have you tried an external keyboard, either PS2 or USB depending on what ports are available?
Mar 14, 2010 | HP Pavilion ze2000 Notebook
Key board port is not working
Try another keyboard if at all possible. Port sill not working?
You can bypass the PS2 port for your key board. You'll need to buy a PS2 to USB Y cable. Places like Best Buy have them. Here is a picture of the cable;
5bababf.jpg Hope you find this helpful.
Cheers'!
Mike
Oct 24, 2009 | EliteGroup P4VXAS (P4VXAS-R) Motherboard
On booting up, computer can not load keyboard system.
One possible problem is that your PS2 keyboard port at the back of your PC is ruined. In time, those so called "outlets" become loose specially the ones with cables which usually got pulled or tangled and make the port strained and the contacts get loose.
If that is the case, you might need to replace the keyboard port, or just stick with your usb keyboard.
Jan 07, 2009 | Dell Dimension 2400 PC Desktop
Toshiba satellite c660 Logo
16 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
