Question about Fusion NEW CAAM20350 1000W 2 CH CAR AUDIO AMPLIFIER AMP 2 CHANNEL
I have a fusion ca-am20350 amp but its not geting power the led flashes red then turns off
My samsung ml-1666 printer problem is while i'm push the power on button the printer LED (RED & Green) lite goes on and its consist continue. what couse this problem.....
Two reasons I could think of
Low toner.
Pre-set counter on cartridge reaches limit.
Try removing the toner cartridge and powering the unit on.
While unit is plugged in, re-install cartridge.
Not knowing how old the printer is a the amount of use, it is had to answer
Apr 30, 2014 | Samsung ML 2010 Laser Printer
PT54DL50
MOST LIKELY problem is the convergence amps but.....
It might be your vertical or horizontal circuit...those initiate a 3 blink failure code too....
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
My LG 42LV4400 led tv won't turn on. Even the
Someone must open it and check voltages on the power supply board as the first step.
Depending on what is found boards may have to be ordered and installed to KNOW which will fix or not fix the set.
Mar 14, 2012 | LG Televison & Video
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
Fusion amp . the green light is on but when i turn the volume up the red led light is flashing but gleen led is still on and sub goes a quiet bass sound .
First your need to make sure that the amplifier is grounded properly. And verify that all other connections are as well. Unfortunatelly, i wouldn't be able to help you because i need to be in front of it to troubleshoot. Hope you fix it.
Nov 11, 2008 | Car Audio & Video
Fusion NEW CAAM20350 1000W 2 CH CAR AUDIO AMPLIFIER AMP 2 CHANNEL Logo
Top Fusion Car Audio & Video Experts
Matthew Spark
Matthew Spark
Tygh Duval
Tygh Duval
Are you a Fusion Car Audio and Video Expert? Answer questions, earn points and help others
