Question about Hunting
If I catch a mouse how should I release it? - Hunting
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 21 Answers
Release the mouse far enough away so that IT won't come back. A FEW hundred yards should do. I hope this helps.
Posted on Jan 17, 2013
I lost the combination and I need to know how to open it without the combination. Help!!!
man I hate this when it happens . to destroy a perfectly good case . saw or grind the lock off .
Dec 09, 2015 | Vaultz Locking VZ01353 SLR Camera Case
you can release it to the fields far away from your home
Feb 03, 2013 | Hunting
How do set a mouse trap - i torn directions off am scare to experiment
Rule number one, BAIT IT FIRST!
Rule number two, always keep your fingers out of the line of fire.
When you are looking at the trap, it is sprung. That is, the mechanism is tripped, and the spring has flipped the bar to the "catch" position. You'll see the bar and spring. Look, and you will see another, single bar, connected on one end to the trap, with the other end loose. This is the trigger release bar. If you look at the bait tray, you'll see a place where the metal is pushed out on the side. This is the trigger. Here's how it works: You fold the spring bar over the bait pan, and hold it tight against the base, keeping your fingers out of the way (see rules 1& 2 above). While holding the spring bar down, use your other hand to bring the trigger release bar over the spring bar and to the bait tray. The end of the bar rests under the notch on the bait tray. As you are setting the bar, you'll slightly reduce your pressure on the spring bar. This pushes the release bar tighter against the notch. When the bar is in place in the notch, the trap is armed. When the mouse is tugging at the bait, the bait pan will shift and release the trigger release bar. It flips backwards, releasing the spring bar, which then catches the mouse.
Best regards, --W/D--
Jun 02, 2011 | Microwave Ovens
How can i remove the battery of my microsoft mouse 5000
I found this page about that particular mouse: if you look at the images part way down the page (may have to scroll down a bit) the middle image is of the bottom. There is a little trap door for the batteries. There is a little catch you just push on the release and the door opens. Very easy.
May 31, 2010 | Microsoft Bluetooth 5000 Mouse
I cannot find a way to open the compartment to change battery in mouse. Have pressed button and pushed and pulled - nothing
This help?? >>>>>>>>>>>>>>>
Where do I change the batteries for my mouse? I can't find where the batteries go.
Answer
This article applies to the following products:
All Logitech cordless mice
For some cordless mice or trackballs, there is a slot for the battery door on the bottom of the mouse. Between the slot and the outside edge of the door is a thin strip of plastic. If you compress this thin strip of plastic towards the slot, the catch on the door will release and the door should open.
On other mice, the battery door is on the top of the mouse. Simply slide the top of the mouse cover down and lift the door up. There should be an etched diagram on the door indicating which direction to slide the door.
Once you have opened the battery door, remove the old batteries and dispose of them according to your local waste disposal regulations. Then insert the new batteries into the battery compartment using the diagram in the compartment as a guide. When you have finished inserting the batteries, replace the battery door.
Mar 28, 2010 | Logitech Cordless Mouse
Im having a problem opening my hood on my 2000 land rover dis 1
You don't specify whether its just that you can't find the release catch, or whether the release catch is stuck / broken,
In the UK (Right hand drive car) the release catch is situated in the left (passenger side) footwell, within about a foot of the lower front door hinge. In a Left Hand Drive car, I guess this would be reversed (i.e. right hand side footwell). Pull, and it semi releases the hood. Next, walk to the front of the car, pull the hood up about 1" and insert your fingers about a foot left of center. Sweep to the right, and you'll release the secondary catch and the hood will be open.
However, if its stuck / broken, then ......
You need to work underneath the front of the vehicle - the idea is to get at the catch and release it with a long screwdriver flicking the catch to open the bonnet -or getting a grip of the cable if it is hanging loose ( i.e. broken ) then getting a grip of the cable with mole grips or even pliers - to pull and release the cable / bonnet.
Once the bonnet is open - you can deal with renewing the cable assembly, or greasing it thoroughly.
Feb 21, 2010 | 2002 Land Rover Freelander
The hood will not release to open. I released the inside lever & the hood poped up a little. In the grill there is a plastic "T" lever that you pull to release the hood. I have pulled it hard & the...
So I gather that the release inside the car has release the hood's primary catch, but the T handle is not release the secondary catch to allow the hood to fully open.
If this is the case, take some lithium grease or WD-40 (lithium grease is much better and lasts much longer) and spray it onto the catch assembly.
Try pulling on the T handle some more after a few minutes of the grease soaking in and see of that releases.
If that doesn't work, then take a long flat screw driver and press it against the catch gently hit the screw driver with a hammer (you should be trying to push the catch towards the driver's side of the car)
You may need someone to be pulling on the T handle as you hit the catch with a hammer. I actually had to do this with a jetta before....
Nov 20, 2009 | 1998 Volkswagen Passat
The pass. side bonnet catch will not release and open the bonnet.
Have someone lift on the bonnet while you pull the release handle.
Nov 06, 2009 | 1997 Mercedes-Benz E-Class
How to change batteries on dell bluetooth mouse?
Usually there is a catch on the bottom. Sometimes you need to take out a screw or two, but once you push on the catch it will pop apart.
Jan 25, 2009 | Dell Latitude D600 Notebook
Logitec trackball
I have a logitec trackball marble mouse usb for one computer and ps2 socket for another, both have 5 screws. To find the fifth you have to feel about on the sticker on the back and poke a hole in it.
Linear
Jan 15, 2008 | Logitech Marble Mouse Trackball
Hunting Logo
490 people viewed this question
Top Hunting Experts
Peter
Peter
Carl Wiehe
Carl Wiehe
Bruce Mommaerts
Bruce Mommaerts
Are you a Hunting Expert? Answer questions, earn points and help others
