Question about New Home 2014LE Mechanical Sewing Machine
Bobbin thread not sewing tight
My bobbin thread on my SX2122 is not sewing tight, top stitch looks fine, bottom thread is loose and I can easily pull it loose. It is the computerized machine, was sewing beautifully untill the last bobbin finished, have refilled the bobbin twice but have had no lick
  • New Home Master
  • 7,365 Answers
Try adjusting the top thread tension one number or letter higher
sewing on a scrap piece of fabric till the stitch looks normal.
Posted on Jan 17, 2013
SOURCE: bobbin threading
I need to find a needle threader for a sx 2122. I am find it impossible to find one. I lost the little spring that goes in it. Please help
Posted on Jan 26, 2009
  • 43 Answers
SOURCE: I would like to know correct way to thread needle,
Find the threading instructions for your Janome by clicking to this link in my business web site: http://www.sewvac1.com/Janome_632_Threading.pdf
Posted on May 07, 2009
  • 240 Answers
SOURCE: The needle doesn't catch the thread in the bobbin
Are you certain the needle is not bent and that it is in the right way around? Which model is it?(I used to sell them)
Posted on Jun 21, 2009
  • 103 Answers
SOURCE: When I sew, the bobbin thread is all bunched up
when bottom thread is loose then tighten top thread tension.
Posted on Oct 29, 2009
bargainbox
  • 1388 Answers
SOURCE: bottom thread bunching
For a comprehensive 5 page illustrated tutorial...Check this solution link, just copy & paste:
http://www.fixya.com/marketplace/servicepage.aspx?srvid=17197&ctgid=164&brdid=1060&prdid=131120&smid=23884&mthid=1&mpsaugid=347d7805-9ce5-42d2-b812-b602b6cf7437
Posted on Oct 18, 2011
What should the tension be on for this machine?
Most of the time if the bobbin thread is coming through on top it means that the bobbin thread is too loose and/or the top thread is too tight and is pulling the thread too much. check and make sure that there isn't anything in the top tensioner that could be increasing the tension like lint. Good luck.
Feb 17, 2015 | Singer CG-590 Commercial Grade Sewing...
When i am sewing the stiches on top, but its at the bottom
change the needle --make sure it's the right one for the fabric
being sewed
rethread the machine top and bobbin
make sure the bobbin is turned the right way in the bobbin case
also check the top thread tension, if the stitches under the fabric
are loose adjust the top thread tension one number or letter higher
at a time and sew on a scrap piece of fabric till the stitches look
normal
here is a free manual
http://www.singerco.com/uploads/download/696_5417c.pdf
Jan 07, 2013 | Singer 5417 Mechanical Sewing Machine
My top stich is tight,but bottom is loose of my singer sewing machine.
Think in opposites... the top stitch is formed by the bottom thread tension and the bottom of the stitch by the top. So either the bobbin thread is too tight or the top thread is too loose. Check the bobbin thread first as that is the one most overlook. It should come out of the bobbin without having to yank it hard but it should have a little resistance.
Mar 22, 2011 | SINGER 7470 Sewing Machine
The thread underneath when sewing is too loosed
Usually thread too loose on the bottom is caused by the upper tension being too loose. The top and bottom tensions work together with the top thread making the underside of the stitch seem too taunt or too loose and the bobbin thread causing the top side of the stitch to be loopy or too tight. Select a large zig zag stick and sew a couple of inches. Then examine the stitch. It should look identical on both sides. Look to see which side is drawn too tight, the zig zag being smaller on that side with threads from the bottom threads pulled through. Then adjust the two tensions so that they make a uniform, identical stitch.
Also, when the bobbin tension is right you can hold the bobbin dangling by the thread and it won't spool out to the floor but will let loose a bit with a slight flick of the wrist. Too loose it will just spool out. Too tight and it won't drop at all. When you get that set right then do the above zig zag test to see where the top tension should be set.
Mar 02, 2011 | Sewing Machines
When im sewing my bottom stitch looks good but my top stitch is real loose and sometimes my bottom thread gets pulled up. i have played with the tension but dont help
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 24, 2011 | Brother CS-6000
The bottom thread gets loose and tangles, just the bottom stitsch is not proper
This can happen when the machine is threaded with the presser foot down.
What looks like a problem with the bobbin thread is actually the top thead not seating into the tension control during threading.
When the foot is up, the tension opens and accepts the thead. When the foot is down, the tension is closed and then when you sew, the loose top thead cannot form a tight stitch with the bobbin thread and it is pulled to the bottom.
May 01, 2010 | Kenmore 15358
Loose bottom stitch on brother se 350
Hi, general rule of thumb:: loops on the top, problem on the bottom.. Loops on the bottom, problem is on the top.. When threading your machine, stop just before you thread your needle, put the presser foot down. Try pulling the thread. If it pulls easily, the thread is not thru the tension wheel right. If it pulls hard, you got it right.
May 12, 2009 | Brother XL-5700 Mechanical Sewing Machine
BOTTOM STITCH IS ALWAYS LOOSE
If the top stitch is loose, then you need to tighten the bobbin tension: if the bottom stitch is loose, tighten the top tension. Hope this helps. It could also be the size needle and thread you are using for a particular fabric. Different fabrics require different notions.
Mar 13, 2008 | Sewing Machines
Bobbin on a Viking #1+ sewing machine
Could be the bobbin case tension is too tight--are you using a thicker thread than usual? Also, check to make sure that it is the correct bobbin for your machine--several are very similar but if not exact, will not sew properly. Also, if the thread is not evenly wound on the bobbin, there would be problems. Check to make sure the bobbin thread is threaded through the bobbin tension. It may help to tighten the top tension, but if the bobbin case tension is too tight, adjusting the top tension will not completely resolve the problem. The tension is correct when the top and bobbin threads meet in the middle of the fabric--this means that whenever you start a different project, you may need to re-adjust the tension.
Understanding Thread Tension Threads
Learn the Ins and Outs of Troubleshooting Sewing Machine Tension
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Jun 19, 2017 | Husqvarna Viking 1
New Home 2014LE Mechanical Sewing Machine Logo
200 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
