Question about Radio Shack Pro-82 Scanner
Ive had this scanner for a while and it barely does anything. It only scans one channel. And I know there is more going on out there than what i get. I dont know how to program it and Radio Shack doesnt seem to know either. Hopefully you can help.
  • Anonymous Feb 03, 2009
    nothing worry but can get it porgger
    Problem Solver:
  • 12 Answers
When on the scanning part push the scan part again and push the prog buton that is under the lower arrow key and push it again so it will go to a different (blank channel) . you will know when it you are able to prog when the word prog will be on the bottom of the screen then go to cityfreq.com to find the codes for your area and put them in and then press enter. after you do that press the prog button again and it will move to the next number to program a different on when you get the desired amount of frequencies in your scanner just push scan and it will run through the entered codes.. Or if thats not the problem then on top should be a bank of numbers and andd you have to push the number of what bank you want it to run through at that time.
Posted on Feb 06, 2009
Whenever i turn on my pro-82 scanner all i get is static and have tried squelch and reset
Check your antenna connections, if the connections are good then try a different antenna. Most likely that is the problem if it's the scanner. If your trying to scan Public Safety Frequencies you may be running into a situation where they have gone Digital and your scanner is Analog or they may have encrypted their frequency or control channels so the scanners won't work.
Sep 21, 2011 | Radio Shack Pro-82 Scanner
Dont know how to program
To program a known frequency into the PRO-82:
1. Power the scanner ON
2. Press the PGM key
3. Enter a channel number between 1 and 200 (you might want to start with 01).
4. Enter the frequency, including decimal point (Ex: 146.26).
5. Press ENT
6. Press PGM to advance to the next channel
7. Restart at number 4 above.
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
Jun 13, 2010 | Radio Shack Pro-82 Scanner
How do i set the scanner to only scan dedicated channels
Here http://support.radioshack.com/support_electronics/doc69/69887.pdf is the manual to your scanner.
It appears that all you should have to do is press the SCAN button and it will start scanning your programed frequencies.
May 19, 2010 | Radio Shack Pro-82 Scanner
I reset my pro 82 scanner now i need to program my scanning codes
Your reset wiped out all programmed frequencies, leaving "000.0000" in each channel. That automatically sets the LOCKOUT icon, but it will clear when you program a frequency into the channel. You can download and print your scanner manual here:
Need the frequencies for your area? Visit:
BillB
Jan 22, 2010 | Radio Shack Pro-97 Handheld Scanner
How to program radio shack pro 82 scanner
is it a digital scanner? You know that everyone has gone digital there fore making that kind of scanner outdated and if you are trying to listen to police u wont pick anything up. I was told that some raido shacks will re program it for you.
Oct 11, 2009 | Radio Shack Pro-82 Scanner
Pro 82 Scanner from Radio Shack problem!!
While its in scan mode press the # of the channel to select.. you will see the bar go under the # Then it will scan the channel
Jun 04, 2009 | Radio Shack Pro-82 Scanner
Scanner will not move from the programmed Police channel
you may need to play with the squelch. and/also hold down the light/key button until the key goes away but mess with the squelch after you get rid of the lock. you want the squelch as far left without it stopping and making static noise
Jan 18, 2009 | Radio Shack Pro-82 Scanner
I have a radio shack weather alert pro 82
Tilt the scanner in a different direction while looking at the display. Do you see anything on the display when you look at it from a different angle? Sometimes manufacturers don't put the LCD display in correctly, and because LCD's have a really small viewing angle it can result in not seeing what is displayed.
Oct 19, 2008 | Radio Shack Pro-82 Scanner
Loss user manual for Pro-82 Scanner Reciver.
Hi - You can download the manual from the link below:
Radio Shack Pro-82
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 09, 2008 | Radio Shack Pro-82 Scanner
Pro-82 scanner
go to cityfreq.com and see if the frequencies in your area have changed. you might even need a new anteanna radio shack should have a really good one for 20 buck. a little longer than the original but good
Jun 15, 2008 | Radio Shack Pro-82 Scanner
Radio Shack Pro-82 Scanner Logo
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
