Question about Home Security
Digidoor 2 Hi there. My digidoor 2 motor only turns in one direction regardless. I've replaced the rockers and the relays, but no joy yet. I can activate to start, and it stops on limit, but needs to release the motor to get the gerage door closed. Can anybody please advise? thank you in advance
SOURCE: Liftmaster security + model 1265 NOT CLOSING PROPERLY
Same thing happened to my garage door. Take some WD40 and put on tracks. Worked like a gem and it took a 91 year old lady to tell me to do that!!
Posted on Jul 24, 2008
  • 118 Answers
SOURCE: Craftsman garage door opener - Clicking/blinking - no open/close
First, check the safety eyes. There should be a light on each eye that is on. If not, realign the eyes. If that does not work, check the force settings. They are the blue adjustment screws. They should be set on 4-5. Do not go above 6 or there is a problem with either the door or opener, or both. If this does not work check all of the wiring on the back of the opener. 1 should be a red wire, 2 should be three white wires and 3 should be two black wires. Check the wiring to the wall button. the back of the button indicates red and white screws. To take off the wall button you will have to remove the big white button if you have the "deluxe wall control" If this does not fix it, respond with more info on door position and what happens with remotes and wall button.
Posted on Feb 26, 2009
SOURCE: garage door opener will not work after gear replacement
Mhindo,
Check this link: http://www.fixya.com/support/t519365-sear_1_2_hp_garage_door_opener_replaced
Should help. Solution 1 did it for me. My comments are under username Otrand.
Posted on Mar 21, 2009
SOURCE: Craftsman Garage Door not working, motor seems fine
I have similar jerkiness problem and have gone through all the nine yards of possible causes. The motor stops at random position and at random time. Even when I unhook the door from the carriage, it still showed this symptom. It started when I had one torsion spring broken. I replaced both torsion springs and adjusted for weight balance. Make sure the two cables windup properly along the thread of the pulley; Checked the photo eye sensors; checked/test capacitor; cleaned rpm sensor; adjusted all possible force settings; make sure limit switch at sound; re-programmed my remote just to check if the logic board somehow still work on this side and it did;
One important observation I have is that when I adjusted the carriage chain, I've noticed that the opener unit turns off and on as if there's a loose connection/contact. This I pursued more. The more I investigate, I spotted a "tiny" spark on one logic board soldering at the transformer footing as I **** the back panel (where the board is mounted) back and forth to simulate the on/off due to the loose contact observed earlier. This one solves everything! All I had to do is take the logic board out and re-solder that failed connection and Hooray - it fixed the problem!
Hope this helps someone with similar issues,
Viewful
Canton, Mi
Posted on Jun 18, 2009
  • 3197 Answers
SOURCE: My Sears Craftman garage door opener closes about
If the main light is flashing 10 times when the door reverses it is a door sensor problem. One may have been bumped so that they no longer point at one another. Make sure the small light on each sensor is lit and not flickering. If this isn't the case you might need to increase the down force a little. The control is on the back panel near where all those white wires go. Increase it about 1/4 turn and try.
Posted on Dec 16, 2009
Can i fit 12v battery backup for digidoor 11 to open when there is loadshedding. My digidoor2 had the extra consoke for remote receiver
Nope, Digidoor II has no battery backup. You need to invest in a UPS or replace the motor.
Digidoor one, Digidoor III and the Digidoor IQ all have build in battery backup.
__________________
Reference:
http://www.4x4community.co.za/forum/showthread.php?t=142874
Jun 13, 2015 | Computers & Internet
I bought a receiver to pair a Centurion D5 motor with thE Digidoor motor.How do i install the Receiver on a Digidoor motor?
Hi there Vusi.
You should have a manual open and close switch on the wall for your Digidoor. You need to find the two wires which control the open and close functions on the Digidoor Trace these back to the Digidoor motor connect these to the Comm and NO terminals. You also need to supply 12V power to the receiver This needs to be connected to the Possitive and Negative terminals on the receiver. These connections originate in the Digidoor motor housing and can be connected right there. Some Digidoor motors have connection terminals for additional remote receivers in the housing. Remember that the minimum connections needed are Positive, Common(Sometimes the common is also the negative supply so you can bridge the common and negative terminals on the receiver) and NO. Then pair the remote with the receiver as per the instructions in the receiver box. If you still cannot come right post pics of the PC boards of your receiver and Digidoor motor and I will identify the connections for you
Jan 05, 2015 | Televison & Video
I have a 2001 KIA Sephia I've had within the last 2 months the timing belt replaced, the fuel filter, pump & relay switch replaced, alternator and a new battery put in and it seems like I'
This will need a hands on inspection by a qualified mechanic. i suggest the Kia dealership, but at a minimum it needs to go to a different shop than the one you've been taking it to as they seem to not know what they're doing.
Mar 22, 2017 | 2001 Kia Sephia
My sanitop is not working. i've changed the fuse but no joy. can the motor be burnt as it may have been on for a while since my son left the tap running
If anything goes wrong with the unit it usually happens in the pressure chamber, the motors are very durable, any part in there can be replaced. Im thinking the capacitor might have seized up and will probably need to be replaced.
Sep 20, 2012 | Saniflo SaniPlus-Round SaniPlus Macerator...
Interior fan hasn't worked properly for some time, would only work on fan's highest setting. Now we've got no air at all, regardless of setting.
Blower motor RESISTER has went bad. Its behind the blower motor; small hands are a definite plus for changing it.
Aug 08, 2012 | Cars & Trucks
2002 jeep liberty p1491
Hi there:
P1491 is for the cooling fan relay control circuit as you've found already.Start by checking the fuse for the fan relay. Its in the box under the hood, a 40 amp fuse.If you've got a couple jumper wires, you can unplug the fan connector and carefully jump the fan to see if it works. The fan connector is on the right side of the back of the fan shroud. Unplug it and jump the black wire to ground and the green to positive. You've got to be very careful doing this though-you are in very tight quarters, its not hard for your jumper wires to touch each other in the connector and short together, and if you use small diameter jumper wires they will get hot quickly when the fan comes on.If the fan doesn't come on when you jump it, or if it runs slow or sounds bad, you've got a bad motor and will need to replace the fan assembly. One thing that does happen somewhat often, is a bad fan motor will burn up the relay. If the fan motor is drawing too much current it will overload the relay and burn it up. This is why its so important that if the fan motor runs slow or makes noise that you replace it, or you may end up burning up relays frequently.If the fan runs and the fuse is good, its very likely you just need a fan relay. This is a pulse width modulated relay, not the on/off clicker type you'd find in the fuse box. This unit is capable of infinite speed control. It gets very hot in operation, so its mounted to the body sheet metal to allow heat to dissipate through the sheet metal. The relay is mounted under the right headlamp held down with two 8mm screws. To get to it you have to remove the front bumper cover and headlamp bracketry to access the relay. These relays are pretty common.
Hope helps.
Mar 26, 2012 | Jeep Liberty Cars & Trucks
Hi there:
Hope helps.
Rear windows on 2003 Montana won't close, now that they're open. Is there 2 motor, one for each window. I;ve looked at the switch & all appears okay if it's the motor(s) are they easy to...
If the lockout switch on drivers door is "OFF"... Window fuse's and relay's may be up under passenger side dash or behind glove box.
Could also be a broken wire in the rubber boot going from the door to the body. You will have to eliminate each till you find the culprit.
The motor and the relay are the most likely to cause this problem. Try swapping the relay with a working window relay. If it still doesn't work, remove the door panel and remove the window motor.
Turn the motor shaft in both directions by hand several turns. Then plug the motor in and see if the switch will now run the motor. Sometimes thats all it takes to get it working again. I have had to do this with brand new motors. If voltage is not present at the motor connector, either a bad switch or a broken wire exsists. Make sure to check for voltage coming to that windows switch. Actually, GM use's a circuit breaker type relay for each window and one fuse for all the circuit breakers.
Aug 02, 2011 | 2003 Pontiac Montana
I have a 2002 Mercury Sable w/DOHC that was drove through flooded intersection last week & stalled. The water was about 2-3 feet deep. I've replaced oil, filters, spark plugs & dried out...
when car won`t turn but clicks then the ( brushes of you starter are worn may be the man who replace used the old brushes ) its very simple thing but will get your car to start
but you didn`t mention anything about fuses and relays if you haven`t replace them all then replace relays/fuse first
you welcome any time sir .
Jun 14, 2011 | 2002 Mercury Sable
Hi, My Digidoor II opener only moves the door 20mm at a time and stops. The same happens using the remote or the wall mounted pushbutton. How do I fix this?
I had the same problem easy to fix!
It's the rocker rail (small plastic thing that ajusts the power and direction) that is damaged. Buy the part for R36-00 from any Digidoor agent 011 3978448.
Remove the motor from the installation rail and open the blue motor cover. You will see the rocker rail is attached to the blue cover, one of them will be broken. Replace both of them (up and down)!
Jan 06, 2011 | Computers & Internet
Home Security Logo
23 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
