Question about Sport & Outdoor - Others
I need a new machine but want to be able to travel with it. What is the easiest stringing machine to transport?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 21 Answers
Dropweight stringers are good for beginners. They are small, easy to move around, and inexpensive. If you're a professional though it's not so good for you because it's not a fast one. This kind of stringer uses a bar to get the proper tension of the string.
Posted on Jan 17, 2013
Amigo handicap scooter -- loosing distance with in use
you'll need new batteries plan on replacing them at 1-1/2 to 2 years
Oct 14, 2012 | Amigo Health & Beauty
Its not my stroller but i need to put it down to put in my car can you please tell me how to put it down.
Good Afternoon
If the seat unit is on the Buzz, you'll need to make sure its in the forward facing position and upright. Now stand in front of it (this is the easiest way of folding the Buzz). Press the button on your left side at the knuckle in - and the grey chevron-marked button on the your right twists forward toward you. Now apply a gentle amount of pressure and the chassis will collapse down smoothly. Ensure the transport lock is applied for safe travel. Remember that if there is any kind of resistance or the chassis makes any kind of clicking noise that you should not continue attempting to fold as the buttons have not been fully engaged for folding.
Apr 28, 2011 | Quinny Buzz 3 Storm Travel System Stroller
Pull starter
easiest thing is to take it off machine-that is the housing holding the string/handle-usually 4 screws-very easy(they may be allen wrench screws)and take it to a local lawn place and ask them if they rebuild them or if its cheaper to maybe just buy/order the entire thing if they have it/can order.It would probably cost 20.00 tops for the new housing with string and handle ready to go.Hope this helps
Jun 28, 2010 | Troy Bilt Tb70ss Gas Trimmer
Whats the easiest way to replace a battery wire to the alternator in a 1998 dodge intrepid?
Cut the terminal off the wire at the alternator end. Leave enough wire so you can use a inline connector to put the terminal back on the new wire.Tie a strong string monofilament fishline works good) to the old wire at the alternator end. Pull the old wire out slowly and carefully out of the loom so that the string follows it. When you have the string at the battery end tie it to your new wire and slowly and carefully pull it back through the loom. Some lubricant will help it slip into place. Install new terminals as required and hook it up. It should work fine!
Mar 18, 2010 | 1998 Dodge Intrepid
Where do I get bolts to move my washer, do I really need them
the shipping bolts should always be in place when transporting the machine but i can also depend on how far you are traveling and the road conditions.you can order them from a local parts store
Jan 31, 2010 | Frigidaire ATF6000ES Front Load Washer
In a paragraph , how does sound travel threw a string
Like a guitar string, sound waves travel the length of the string and transmit the sound to a can tied to the end. The string must be tight.
Oct 18, 2009 | Coleman Heating & Cooling
Need to add new string to a weed eater xt 12
    For manual go to;
    http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
    Preparation Instructions
  1. Press the lock and rotate the spool counter-clockwise.
  2. Remove the locking ring if your weed eater has one.
  3. Take off the automatic feed button.
  4. Wipe away any debris.
  5. Push down on the spool to release the locking tabs.
  6. Remove the spool from the chamber. Restringing the Weed Eater
  7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
  8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
  9. Secure each of the lines into its own upper and lower deck grove settings.
  10. Install the spool back into its chamber.
  11. Pass the lines into the left and right holes and snap the spool into place.
  12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
  13. Reinstall the locking ring if necessary.
Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
Jun 01, 2009 | Garden
Sport & Outdoor - Others Logo
569 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
