Question about Southwestern Bell 2262WP GMRS/FRS TWO-WAY COMMUNICATOR 2-Way Radio
Model no FS2000AT frs 14 ch southwesternbell 2 way radio
    Prodigy:
    An expert who has answered 500 questions.
  • 607 Answers
Hi Martinez,
Unfortunately we cannot help you, as you have not provided enough info.
1. What is the problem you require an answer to?
2. Do you require Software, manual, etc.,?
Without knowing the problem, we can't help you.
Please reply with the above details and we'll try to find a solution to the problem.
Best regards,
Peter
Posted on Mar 05, 2013
  • Trey Sep 07, 2013
    the problem I am having is that I do not know how to answer the walkie when it calls....please help..thank you and have a great day
COBRA MICRO TALK1 FRS 100
THEY SHOULD ALL WORK TOGETHER ON THE FRS FREQUENCIES. MAKE SURE THAT YOU SET THE CHANNELS AND SUBCHANNELS TO THE SAME ON ALL FRS RADIO.
Oct 07, 2012 | Cobra Frs-120 Microtalk 2-mile 14-channel...
Does the T/A 250 use standard CB fequencies?
No. The TalkAbout 250 has 14 FRS frequencies built in to it. These are FM UHF 2-way radio frequencies which differ from CB frequencies.
Best regards.
Mar 04, 2012 | Motorola Talkabout FRS 250 (14 Channels)...
My cobra walkie talkie doesn't work after 2 miles
You didn't include the model number of the radios, but I suspect you're referring to Family Radio Service (FRS) / General Mobile Radio Service (GMRS) two way hand held radios. The FRS /GMRS types are limited to just 1/2 watt. Base GMRS type radios are limited to 5 watts. FRS is limited to Ch 1 - 14. Ch 15 - 22 are GMRS only, and require an FCC license to transmit. You can read more about FRS on Wikipedia.
Many FRS / GMRS two way radios claim incredible distances on the packaging. I've seen some that claim 15+ miles. Given the low power (.5 watt) that they are limited to transmitting, claims such as those would be under the most optimal of conditions. I can assure you that you or I would never encounter those conditions unless we were in some sort of radio laboratory / testing space designed to obtain these crazy distances. In other words, even in optimum "real world" conditions; these radio should only be expected to work when separated up to only several "unobstructed line of sight" miles (such as across open water of a lake, along a beach, etc. The range of these same radios will be reduced significantly when operated indoors, outside between buildings, where blocked by rocks, trees, metal, etc. The only reason you may have reduced range could be due to a power level selector switch that has been set to reduce the output power of the radio. Other than that, I think you'll find a couple of miles is about all you're gong to get.
Feb 20, 2012 | Cobra Radio Communications
Can you use 2 different talkabouts fr50 and t5420 with each other? I have just one of each unfortunately.
  • Yes they will both talk together on the same channels just fine. Most of the more recent Talk About Radios are FRS/GMRS with 22 channels. These radios are FRS only with out the GMRS. The FRS are the first 14 channels in most talk about's as are your radios.
Regards, Tony
May 01, 2011 | Motorola Talkabout FR50 (14 Channels)...
Is there a way to change the frequency of a specific channel?
FRS & GMRS frequencies have been preset by the governing bodies where these radios are licensed for use. They consist of Ch 1 - 14 for FRS or Family Radios Service (the new "CB" radio) and Ch 15 - 22 for GMRS or General Mobile radio Service. GMRS frequencies may be repeated 5 Mhz higher - the repeater input of channel 22 (462.750 Mhz) may be heard if close to the transmitter on Ch 22, but if a repeater has been set up to repeat signals in range on Ch 22, they would also be heard on 467.750 Mhz. The repeater will likely have one or more of the following: a high vantage point such as a hill or mountain top, may increased output power of up to 50 watts, or have an antenna with gain properties. Any one or combination of any of these benefits, will result in a significantly increased area of coverage.
FRS Frequencies Channel Frequency in MHz 1 462.5625 2 462.5875 3 462.6125 4 462.6375 5 462.6625 6 462.6875 7 462.7125 8 467.5625 9 467.5875 10 467.6125 11 467.6375 12 467.6625 13 467.6875 14 467.7125 15 462.550 16 462.575 17 462.600 18 462.625 19 462.650 20* 462.675* 21 462.700 22 462.725
It is important to note that only Ch 1 - 14 may be used without a license. Transmitting on any of the GMRS frequencies (Ch 15 - 22) shown in red in the chart above, requires an FCC license if used in the U.S.A. Other countries may or may not have laws for licensing the use of any or all these frequencies, so check before transmitting. Modifying an FRS / GMRS radio is a violation of FCC rules and if caught; can result in fines, prison or both.
If you'd like to be able to tune actual frequencies - and not be limited to specific channels, you ought to look into amateur ("ham") radio. While not in the FRS or GMRS bands, there are literally hundreds of thousands of frequencies to use once licensed. The ARRL (American Radio Relay League) has a great deal of info about ham radio.
I hope this helps & good luck! Please rate my reply - thanks!
Feb 03, 2011 | Motorola TalkAbout T5530 2-Way Radio
I am looking for a users manual for a Southwesternbell Freedom phone FS2000AT .. its a FRS two way radio ..14 channels. I think it was actually made by Conair .. thanks
the link above is for a "regular" house phone. we are looking for the manuel for the 2 way radio (walkie talkies)...thank you anyways for your help.
Nov 14, 2010 | Cell Phones
Expandability
Any of the FRS radios on the market should be able to communicate with your TalkAbouts. Most have the typical 14 or so FRS frequencies installed. Your T5410 has an interference eliminator, when set to anything other than zero, it will block out other users on your frequency. If you use this option, you will need to chose radios with this feature. Some of the cheaper off-brands do not offer it.
Aug 06, 2008 | Motorola T5410 (14 Channels) 2-Way Radio
2-way radios
The Bellsouth 2231 is a FRS VHF I couldn´t find if thi Bell south 1007 is FRS in UHF or VHF if you have this informtion compair them if both are in the same band VHF or UHF both radios can communicate to each other
Mar 02, 2007 | BellSouth 1061 (14 Channels) 2-Way Radio
What is the frequency for UFR650?
these are FRS radios, and use only the 14 FRS channels within the GMRS band. they will not operate on the other GMRS channels in the GMRS band. FRS Channel Frequency Assignments: Channel 1: 462.5625mhz Channel 2: 462.5875mhz Channel 3: 462.6125mhz Channel 4: 462.6375mhz Channel 5: 462.6625mhz Channel 6: 462.6875mhz Channel 7: 462.7125mhz Channel 8: 467.5625mhz Channel 9: 467.5875mhz Channel 10: 467.6125mhz Channel 11: 467.6375mhz Channel 12: 467.6625mhz Channel 13: 467.6875mhz Channel 14: 467.7125mhz
May 23, 2006 | Unwired UFR650 (14 Channels) 2-Way Radio
Southwestern Bell 2262WP GMRS/FRS TWO-WAY COMMUNICATOR 2-Way Radio Logo
102 people viewed this question
Top Southwestern Bell Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Southwestern Bell Radio Communication Expert? Answer questions, earn points and help others
