Question about Sport & Outdoor - Others
What is the most expensive badminton racket? - Sport & Outdoor - Others
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 51 Answers
I think its the Yonex NanoSpeed 9000 (Type X) Badminton Racket , its $260
Posted on Jan 17, 2013
Blackflag bug zapper does not kill bugs
We know that electronic mosquito zappers usually come exactly in the form of a badminton racket, and quite similarly have a net woven over its top circular frame; whereas the handle part consists of an electronic circuit and a battery pack integrated with the net assembly.The net structure is primarily made up of three layers of metal mesh and is rather a complicated assembly.The inner central layer is actually the "hot" mesh and is terminated as a high voltage source from the circuit enclosed in the lower handle area. The outer two layers are simply connected with the negative of the battery and constitute the ground for a return path to the central "hot" mesh line.
Apr 30, 2014 | Air Purifiers
Tip
How to wear a wrist strap when playing racquetball
Racquetball can be a very competitive and dangerous sport due to the close proximity between players. Regulations in the USA require that all players wear a strap to keep their racket from slipping and hitting themselves or other players. You would be amazed how many injuries are caused by slipped rackets and there is nothing more embarrassing than hitting yourself.
To put the racket ******** properly, place your dominant hand (if you are a righty the right hand) through the wrist strap that is attached to your racket. Using your other hand, take the racket rotate it in a clockwise motion, this will make the opening where your wrist goes through smaller making it less likely that your hand will come out of the strap.
Put the racket into your dominant hand and grip it so that the "V" formed by your thumb and forefinger should be aligned with the center of the racket's grip. Slide down the racket until the bottom of the racket is resting in the palm of your hand and your pinky is no longer holding the racket. When you get to this position you are ready to start playing.
It is important that you get a strap that is smaller but not too tight, a smaller strap will help to give you a wider range of motion and will give you the ability to hit the ball harder with more accurately.
on Jan 28, 2014 | Sport & Outdoor - Others
Tip
Proper equipment for playing badminton
Like any sport when you come to a badminton game you want to make sure that you have the proper equipment.
The main piece of equipment that you are going to need is a Badminton racket, unlike a tennis racket badminton rackets are smaller and lighter, weighing between 70 and 90 grams. They are generally made with steel or aluminum. There is debate about if the strings should be tight or loose. Tighter strings are said to improves your control while lower tension makes the string bed more bouncy which helps to increase the power of the swing. Some find the high tension to not help them shoot accurately, the best way to figure out the proper tension for you is to try out different tension until you find the one you like.
Shuttlecock also known as a birdie is the "ball" that is used to play. It is made of sixteen overlapping feathers embedded in a rounded cork base that is covered by a layer of either leather or synthetic material. Because the feather birdies tend to break easily players lean towards synthetic ones made out of plastic and synthetic foam.
While you can wear your regular running shoes to play badminton running shoes have too much built-up lateral support which will not protect your foot from injury. The lack of support in badminton shoes allow for free movement in your feet and the thin soles lower your center of gravity leading to less injury. Learning proper footing will also help to keep you from getting injured while playing badminton.
Finally you are going to need a badminton net. The top of the net should be 5 feet from the ground at the center, it should be 2 feet and 6 inches in depth and reach the whole width of the court. There is no regulation as to the height of the ceiling or amount of space over the top of the net, but it makes sense to not have a fair amount of space over the net. The colors of the net are generally dark colors like black or navy with a white stripe across the top
Now that you have the proper equipment, go grab a friend and start playing!
on Nov 04, 2013 | Sport & Outdoor - Others
Tele zapper tz 800 manual
Nov 28, 2013 | Lands Phones
How we can repair the broken badminton racket frame....
The only thing to do is replace it unless it's a hairline crack, which may still result in a larger crack over time, especially after each stringing.
Aug 11, 2013 | Boardsforless Yonex SRQ Ti-600 Long Tennis...
Is badminton an olympic sport?
badminton joined the olympics in 1992.
Feb 20, 2013 | Sport & Outdoor - Others
How many people play badminton at a time?
There can be two opposing players in a singles match or else two opposing pairs in a doubles match.
What are the rules of badmington?
You can read all the rules here: http://www.badminton-information.com/rules-of-badminton.html
Jan 17, 2013 | Sport & Outdoor - Others
Sport & Outdoor - Others Logo
509 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
