Question about Linksys Wireless-G WRT54G Router
Connection problems i have a linkskey router and it is constantly disconnecting from the internet signal. i am constantly having to unplug and replug it. any suggestions?
  • Anonymous Mar 04, 2009
    i want to format my linksy router to factory reset
  • tati thompson
    tati thompson May 11, 2010
    how constant is constantly? like every few minutes or what?
    Scholar:
  • 60 Answers
Check the "keep alive" settings in your router, there is usually a choice between having it constantly "pinging" to keep the connection open, or letting it disconnect when it has been idle for awhile. Make sure it is set to "keep alive". The wording may be different but it will be something along these lines. Go in your browser to the wireless router's configuration page (i.e. http://192.168.1.1 ). Depending on what brand router you have this ip address will vary, consult your documentation for which number is used.
Posted on Jan 26, 2009
My tv stopped streaming Netflix It says no signal
Unplug your router for 20 seconds and replug it in, or if you use ethernet cable, uplug and replug to make sure it is connected. If you use wifi, check settings.
FREE-BUSINESSES.com
Nov 06, 2017 | Computers & Internet
Wireless router will not power up?
Capacitors in the power supply have gone bad. Might be time for a new router.
Mar 06, 2016 | Belkin Connect N150 Wireless N Router
My router won't give me internet access?
IF you have a Modem and a Router & you have the cables on both hooked up right just unplug the Modem for 1 min and replug it back in and after that unplug the Router for 1 min and replug it back in and they should auto detect or set up and they should work.
Jul 30, 2014 | Zonet ZSR4154WE 80211N Wireless Broadband...
Cant connect to internet
Try entering password again off router. Unplug and replug router then try again. Make sure your WIFI is on too.
Feb 06, 2014 | Dba Archos 5 160 GB Internet Tablet with...
Find compatible router
Contact Netgear! Their tech. support number should be in the documentation that came with your router.
May 15, 2017 | Motorola Computers & Internet
Zyxel router P - 330W EE continuously overloads and disconnects from the internet
mainframe computer? You have a business? Your ISP may be "throttling" your data.
Jan 04, 2013 | Zyxel Computers & Internet
Diagnostic light keeps blinking
Check the LED lights that are blinking on the front of the DSL modem. Check the "Internet/Online" LED and make sure it is blinking green or a solid green. If this LED is not blinking, then the modem is not getting a phone signal, or the service is out. Remove the line and check it to make sure that you're getting a signal.
Check to see if filters are connected to the phone lines that are all around the house. These filters separate the phone line from the DSL line so that the lines do not crosswire and disturb the Internet connection or the phone connection. The DSL is usually shipped with a couple of phone filters. These phone filters can be purchased at many electronics stores or provided free from your Internet Service Provider.Check to see if the modem is connected to a wireless router. If the modem is connected to the router, try disconnecting the router and connect the modem straight to a computer. If the modem is also a multi-port wireless router, then connect the computer to a different port on that same router.Reset the router if the previous steps do not resolve the problem. Follow the initial set up instructions given to you when you first installed the router. Perform any firmware updates that might be needed once online, and use the discs that came with the modem.
Feb 07, 2012 | Cisco RVL200 Router
I checked all my connections and my router, wr850g shows constantly flashing/blinking lights and will not reset in the 10 seconds that it is supposed to. the ip address is also not becoming 192.168.10.1 it...
1. Unplug the ether net cord from the wall and wait 1 minute replug the Ethernet cord.
Try you connection again if no connection then go to the command line at the DOS prompt and type "ipconfig /all to see the devices that are connected.
If you see anything like "media disconnect" then you have an issue with your ISP ( internet Service Provider).
Jul 02, 2010 | Arris Wireless G Broadband Router (wr850g)
Wireless connectivity suddenly lost
Have you tried power cycling the router and the modem? if not:
1. Turn off your modem and router by unplugging the power cord at the back of the devices.
2. Disconnect the Ethernet cable from the modem to the router vice versa
3. After a minute, replug the power cord at the back of your modem then reconnect the ethernet cable at the back of the modem as well.
4. After a minute, replug the power cord and the ethernet cable at the back of your router.
5. Try to test the connection.
Warning: You can reset the router if you know that you can reconfigure it back to connect to the internet. If you don't know how to set the router back to connect to the internet, it would be ok to you to not to do step 6.
6. If it didn't work, You can reset the modem. Press the reset button at the back of your router while it's turned on, wait for 15 seconds after that, unplug the power cord at the back of the router while the reset button is still pressed, wait for 15 seconds after that, replug the power cord at the back of your router while the reset button is still pressed, wait for 15 seconds again then release the reset button after 15 seconds.
7. Reconfigure your router's settings to communicate to your modem. ( I don't know if you have cable internet connection, but if so, you can just clone the mac address of your modem to connect to the server, if you are using DSL if it's asking for a username and passowrd, just use the PPPoE type of configuration in your router)
8. If it failed, try to update the firmware of your router.
Jan 14, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
Dsl light flashes red constantly
Whenever your dsl light on the 2wire modem turns red,it only means that there is a problem with the dsl connection to the modem. Here are some ways on how you can isolate the problem
1. check if your modem is properly connected to the phone jack by unplugging and replugging you phone cable
2. try to reboot the modem
3. if still getting the same lights, contact your ISP
Nov 13, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Linksys Wireless-G WRT54G Router Logo
381 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
