Mithsubisi cassette unit Error code S108 - Heating & Cooling
    Genius:
  • 1,669 Answers
Error 108 are caused by misconfigured system files.
Error 108 Problems usually happen when the computer's registry system overloads with to much data, or when certain system files become missing or broken.
Try disconnecting power for 10 minutes or so to reset the unit.
Posted on Jan 17, 2013
What is the e10 error code on the stereo
E10 : Tight tape error
Cause: A restricted cassette tape transport or broken cassette drive belt
Correction: Substitute a different cassette tape. If there still is an error code, service the unit at an ACDelco Service Center.
If you cannot get the cassette player fixed I would recommend replacing the radio instead of going to a service center as it would be cheaper.
Jun 04, 2014 | 1998 Oldsmobile Cutlass
Esab Powercut 1300 error 13 open circuit voltage. how to fix that
These are not real good mechanism and I don't understand the complaint- there are no error codes in such a unit- I have one here now.
Apr 23, 2014 | Tascam 302 PRO DUAL CASSETTE DECK Single...
Mitsubishi VCR Model HS-821V Ejects Video Cassette & gives an error code E4
Sometimes things like that are caused by the mode switch which will either need to be cleaned or replaced. It's worth looking inside for damage inside the unit. Pay close attention to plastic parts.
Nov 26, 2012 | Televison & Video
Call for service error in Toshiba studio 160
Code Description C01 Main motor drive error C04 PFP main motor drive error C06 LCF feed motor error (DP2000/2500 series) C13 Cassette 1 error C14 Cassette 2 error C15 Cassette 3 error C16 Cassette 4 error (DP2000/2500 series) C18 LCF tray error (DP2000/2500 series) C19 LCF feed motor abnormal (DP2000/2500 series) C21 Carriage initialization error C25 Scanner unit watch dog error C26 Exposure lamp disconnection or peak detection error C38 Replaced process unit error C41 Abnormal thermistor or heater disconnection at power ON C43 Warming up mode after disconnection judgment, or abnormal thermistor after ready C44 Warming up mode after disconnection judgment, or heater abnormal after ready C45 Thermistor disconnection at the end part of heater C56 Communication error between PFC and main unit C57 Communication error between main unit and IPC (DP2000/2500 series)
May 22, 2011 | Toshiba E-Studio 160 All-In-One Laser...
Sony dcr trv245e erroe code c32 20. I have had condensation issues with this camera in the past and now I cant eject the tape. can anyone help
The error code that your unit is now producing indicates that it is experiencing a tape transport problem - specifically that the takeup reel is leaving slack out of the cassette. This may have led to tape becoming caught in the mechanism and hence the cassette will not eject. This is one scenario although unfortunately it is not the only possibility.
The unit will probably need to go to a professional to have the cassette manually removed and the cause of the fault condition identified and rectified.
Jan 02, 2010 | Sony Handycam DCR-TRV250 Digital Camcorder
P8 eroor code
P8 error is abnormal pipe temperature indoor. If you are running it on heating P8 error will appear because the disc pressure is too high. It could be overcharged.
May 31, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
01 error code - unit in safeguard mode
I solved the problem! Open the video cassette door. Look closely at the gear mechanism and see if there is any small debris in the gears. If not, using a magnifying glass and a paper clip(must stretch it out and use the tip) gently move each gear(gently). I had my unit ON. Once I moved the gear it became unstuck and ejected Mini DV cassette. I then re-inserted the cassette and it worked. The dreaded SAFEGAURD MODE message was gone and it is as good as new.
Be Blessed
dennis@privatemtglending.com
Aug 26, 2008 | JVC GR-D250 Mini DV Digital Camcorder
Panafax uf-790 - info code = 011
Check cassette refers to the paper cassette. If there is no paper or the cassette is not seated correctly, then you will get that error. If you tried those, then check the left rear of the cassette for a tab. If that tab is broken off you will get this error and you need a new paper cassette. Good luck.
Jun 14, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
