Question about Toys
Engine over heating
Water level fine Thermo fans only turn on when AC is on Oil level fine
    Sergeant:
  • 248 Answers
Thermostat is where I would start. Blocked radiator is the next point of call.
Posted on Jan 17, 2013
  • Tony Taouk Jan 17, 2013
    Thank you very much. I will try
2001 caddy Deville 4.6 only runs hot while driving with ac on .rad. water pump and thermo. Has been replaced and fans work.help
check fluid level --radiator may need to be clean externally--may need a flush --recheck fans for proper speed
Jul 06, 2016 | AC Cars & Trucks
Would a closed thermostat stop the radiator fan from turning on when the temperature is within heat range.it turns on when I turn ac on,is that a different cause when not using ac.
There are two different thermostats--one in the cooling system, and one just to turn on fans. The AC has a separate circuit to turn on fans regardless of engine temp, so tind the the fan thermostat and test it.
Jul 03, 2016 | AC Cars & Trucks
2005 GMC envoy Oil pressure drops to zero when stopped if in a drive thru the car over heats. AC off its ok. Oil level/pressure fine replaced clutch fan wire harness(pigtail)replaced water pump.
The oil pressure drop indicates more problems.
Oil pressure drops to zero at idle on 2002 GMC Envoy after ...
www.fixya.com/cars/t7880379-oil_pressure_drops_zero_idle_2002_gmc Jan 18, 2011 - You could have three possable problems that I can think of. 1) Your oilviscosity is too low and you need to change it to a higher level. A 5w/30 .
Jul 21, 2015 | GMC Cars & Trucks
2001 JAGUAR X TYPE 2.5 petrol awd
How many fans do you have under your hood in front the of the engine between the engine and the front grill ? Sound like you may have two problems an oil leak and a over heating problem. first check the cooling fan or fans and make sure they are working. Second check the valve covers to see if they are leaking oil onto the engine or exhaust.
Jul 15, 2012 | Cars & Trucks
1998 cadillac catera oil pressure light come and and the car overheats when sitting in traffic....
CHECK ENGINE OIL LEVEL SHOULD BE ON THE FULL MARK ON ENGINE DIP STICK. IF OIL LEVEL IS LOW.LOOK FOR OIL LEAKS UNDERNEATH CAR.IF ENGINE NOT LEAKING OIL CHECK OIL PRESSURE SHOULD BE 22 PSI @ 900 RPM IF NOT OIL PUMP FAULTY OR YOU HAVE WORN ENGINE BEARINGS.IF OIL PRESSURE OKAY YOU COULD HAVE FAULTY OIL PRESSURE SENDING UNIT. CHECK COOLING FAN TO SEE IF CAR COOLING FANS RUNNING WHILE ENGINE OVERHEATING.IF NO CHECK COOLING FANS RELAY AND FUSE IF ALL IS GOOD ENGINE COOLANT TEMPERATURE SENSOR FAULTY. IF COOLING FANS RUNNING WHILE ENGINE OVERHEATING.HAVE RADIATOR AND ENGINE FLUSHED OUT. REPLACE THERMOSTAT AND RADIATOR PRESSURE CAP.
Jun 12, 2011 | Cadillac Catera Cars & Trucks
My 2003 vw bug dies and won"t start when i run the ac on very hot days. sometimes when i"m driving all the instrument panel lights all come on ant then it loses power to aprox 5 mph. I checked the...
ENGINE GETTING TOO HOT AC PUTS MORE LOAD ON ENGINE AND OUT SIDE TEMPERATURE HOT.YOUR CAR TELLING YOU I AM HOT AND NEED A BREAK.MAKE SURE COOLANT LEVEL NOT LOW AND THE COOLING FANS RUNNING WHEN AC GOING IF NOT CHECK FAN FUSE IF FUSE GOOD.YOUR THERMO SWITCH NOT WORKING OR THE COOLANT TEMPERATURE SENSOR AND FAN CONTROL MODULE COULD BE THE PROBLEM IF THE FANS DONT TURN ON.
Jul 15, 2010 | 2001 Volkswagen Beetle
92 accord: oil light blinking when car overheated
Ok this one is kind of hard to diagnose but maybe I can give you some answers. The 2 problems you have work hand in hand. If you have low oil level the heat in your cylinder walls raises because there is not enough oil to lubricate the fiction caused by the pistons going up and down. Secondly if your car overheats it gets so hot that the oil gets really thin thus viscosity break down occurs. Your Honda has an electric fan on the radiator and if this fan is not working your car will overheat. Crank your car with the hood up and let it idle till the temperature gauge comes up and the electric fan should come on. You will be able to hear and see this happen. If the temperature guage keeps climbing and the fan has not come on then turn your AC on and see if the fan comes on. They are tied together and when the AC is on the cooling fan switch is bypassed and runs all the time. You also have a oil pump in your engine that keeps the oil pressure moving inside the engine. If this is going out it will cause the oil light to come on and make your engine overheat. I am sure you have checked the oil level and the coolant level in your car but if you haven't please do that. I hope this helps you out to find your problem. Oh yea if the coolant fan comes on when the AC is turned on then you have a bad sensor and you need to replace that. In any case I would not drive it until you figure this out because it will for sure cause engine damage. Good luck, Roger
Feb 09, 2010 | 1998 Honda Accord
Aloha,have 98 base mustang, overheating after many replacements
i would change the water pump and check for plugs in the heater core
Sep 26, 2009 | 1998 Ford Mustang
Running hot coolent is fine...
check for a blown head gasket it will sometimes pump air into the heads and make the coolant levels seem fine but in truth they are not and check the water pump for rusted fins make shure the water level sucks down during sharp throtteling of the motor if so the cooling system is fine as far as that goes but where to start
1.) tempature switch located on the motor it tells the ecu when to kick on the cooling fan
2.) fans spin freely without taking force
3.) thermostat it could be stuck closed due to someone at sometime only running water without antifreez and causing the pressure pin to rust and freeze the gate shut
4.) monitor the water levels if they go down suddenly as 1 gallon of water a week or 2 weeks its a bad head gasket you can see this on spark plugs as well
and for most your water pump make shure you get good heat from the heater at low running tempatures and start the car and monitor what the water in the radiator does (while its cold) the water in a car is over 195% and can easily do harm if the car is just warmed up not even close to over heating so you can imagine what it could do at an over heated state
but get the problem fixed or else you can result in blown head gaskets water in the oil piston breakdown do to rust in the piston walls and even worse complete engine failure
Jul 16, 2009 | 2002 Chevrolet Impala
Toys Logo
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
