Question about Samsung S6102 Galaxy Y Duos - Black Unlocked GSM Cell Phone
SIM Card balance keeps going down without using
After installing sim card the balance starts to decline on it's own without me using. What is it in this smart phone that needs to be de-activated??
  • Rodney Bell Jan 17, 2013
    I disabled the WI-FI early on so as to eliminate that part of it. I know texting is P1.0 peso. Without the WIFI/Network connecting I can't understand what can be draining my load down to nothing all by itself. Still digging thru my PDF, also looking at the Globe cards.
    Sergeant:
  • 251 Answers
There is a lot of software that can cause this. Not knowing your plan details. One program I use to detect "bad" apps is "Addons Detector". Remove any software you don't use or the detector says it can make calls etc..... where you know it should not have access - eg. obviously your dial program or message program needs to access the network. You may have also subscribed to a service like the ones that send jokes etc...
Posted on Jan 17, 2013
  • 1 more comment
  • djgough Jan 17, 2013
    I would suggest ringing your provider and call them on it. They should be able to tell you where the charges are going. Sounds like a subscription service but it sounds like you have eliminated that.
    Thanks for the comeback. I wanted to post the resolution just in case anyone else has this problem. I found that my "Data Network" feature had been activated and it was charging me P5.0 pesos about every hour. Once I figured out how to deactivate it, the charges stopped! BTW, it is P4.50 per $ here in the Philippines. Thanks again...!
    Data Network is the roaming, I found out...
2 Suggested Answers
leighp123
  • 1669 Answers
SOURCE: memory card put in sim card hole by mistake and can't get it out
Very tricky, without messing up the contacts inside the phone. Pull out the rechargable batteries before you attempt anything or you will fry the unit! Then you may be able to GENTLY grab and turn the memory card and get it out of the phone. There is no guarantee that the sim contacts in the phone won't be damaged, but the memory card will surely be trashed.
Posted on Dec 26, 2012
Not getting booted.
Just remove your memory card from u'r mobile for oneday.
May be it wil work.
Gud luck.
Dec 14, 2012 | Nokia 3110 Cellular Phone
Sims locked
Make the FixYa experience better for everyone by voting.
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave', for today.
Subject: How to unlock a SIM card
Customer's exact description: sims locked
Discussion: Problems of this type can be easily solved. Customer did not provide the name of the service provider.
Solution: Provide instructions on the entire battery of solutions.
PUK Codes
A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from AT&T to unlock your SIM card.
Since I don't know the name of you carrier, I'm using AT&T as an example. Most carriers use the same methodology though the wording may be different.
You can obtain your phone's PUK code from AT&T in one of these ways:
Take the phone into your carrier's retail outlet.
OR
• Log in to myAT&T online
• Use our Technical Support Chat.
• Contact Customer Care
To get your phone's PUK code online:
? Log in to myAT&T.
? From the myAT&T tab at the top of the page, hover over the Wireless link and select Phone/Device under the My Wireless Service heading.
? From the My Phone/Device screen, select the Unblock SIM Card link under the My Make & Model heading.
? The Unblock SIM screen will display your PUK code and will give you instructions for unblocking your SIM Card.
Once you receive your PUK code, you will need to enter it into your phone to set a new PIN code.
Note: If you enter the wrong PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator."
Second Solution:
You can also do it without any assistance from anyone. However, be sure to read the following carefully because there are pitfalls. If you want to try to do it yourself, just click on the following link: Universal Software Solution for Unlocking a SIM Card
Although most people remember their primary SIM PIN code, those other codes - used for various verification purposes - are never to be found when needed. Below I've included a set of short codes which, when entered on a handset's standby screen, will let you easily change PIN and PUK (short for Pin Unlock Code) codes - but keep in mind, they may not work with all handsets and mobile operators.
More importantly, when changing one's PUK codes there'll be no help to get from the mobile operator if the new codes are forgotten, so make sure to write any changes down alongside the old PUK codes.
The Final Solution:
The following methodology does not work for every phone. Perhaps you'll be lucky. Also, please note that the codes should be entered without the spaces shown below.
Change SIM Card PIN
** 04 * old PIN * new PIN * new PIN #
Change SIM Card PIN 2 (Write down the new code)
** 042 * old PIN * new PIN * new PIN #
Change SIM Card PUK (Write down the new code)
** 05 * old PUK * new PUK * new PUK #
Change SIM Card PUK 2 (Write down the new code)
** 052 * old PUK * new PUK * new PUK #
Display Handset IMEI
*# 06 #
This was wordy but hopefully it helped you.
Ben
Sep 16, 2011 | Motorola Mobility TracFone w175 PayAsYouGo...
These are my numbers 0796086761 and i need mt PUK please
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave' for today.
Customer's exact description: these are my numbers 0796086761 and i need mt PUK please
Solution: Provide instructions for unlocking a SIM card
PUK Codes
OR
? Log in to myAT&T.
Second Solution:
The Final Solution:
Change SIM Card PIN
*# 06 #
Ben
*# 06 #
Ben
Sep 11, 2011 | Cell Phones
How do i get my puk number for my digicel sim card online?
PUK CODE ONLY
As you evaluate my advise.solutions and suggestions, there are a few things you must keep in mind:
• I did not diagnose your problem and am therefore only able to evaluate what you tell me. For example, if you ask me a fuse location, that doesn't mean that I can tell you the reason why the fuse blew. Keep in mind that I'm limited in my analysis to what you tell me.
• A thorough diagnostic approach involves the use of technical equipment, such as voltage meters. scanning equipment and other sophisticated devices.
• Lastly, fixing one problem can very easily reveal a problem with something that you might consider unrelated. If that happens, you might want to view me as being incompetent.
Customer's exact description: how do i get my puk number for my digicel sim card online
Discussion: Problems of this type can be easily solved. However, the name of the customer's carrier was not provided.
Solution: Provide instructions on all of the possibilities.
PUK Codes
Since I don't know the name of you carrier, I'll be using AT&T as an example. Most carriers use the same methodology though the wording may be different.
OR
? Log in to myAT&T.
Change SIM Card PIN
*# 06 #
Ben
Sep 03, 2011 | Cell Phones
My phone locked and said i need a puk #
Customer's exact description: Make the FixYa experience better for everyone by voting.
Subject: How to unlock a SIM card (PUK)
Customer's exact description: my phone locked and said i need a puk #
Discussion: Problems of this type can be easily solved. Customer did not provide the name of the carrier
Solution: Provide generic instructions on how unlock a SIM card.
PUK Codes
OR
? Log in to myAT&T.
Third Method: Although most people remember their primary SIM PIN code, those other codes - used for various verification purposes - are never to be found when needed. Below I've included a set of short codes which, when entered on a handset's standby screen, will let you easily change PIN and PUK (short for Pin Unlock Code) codes - but keep in mind, they may not work with all handsets and mobile operators.
More importantly, when changing one's PUK codes there'll be no help to get from the mobile operator if the new codes are forgotten, so make sure to write any changes down alongside the old PUK codes. Also, please note that the codes should be entered without the spaces shown below.
Change SIM Card PIN
*# 06 #
Ben
Aug 23, 2011 | LG Incite Cell Phone
Sony ericsson w302 lock sye sim card lock i dont no problem.
PUK Codes
? Log in to myAT&T.
You can also do it without any assistance from anyone, However, be sure to read the following carefully because there are pitfalls.
Although most people remember their primary SIM PIN code, those other codes - used for various verification purposes - are never to be found when needed. Below we've included a set of short codes which, when entered on a handset's standby screen, will let you easily change PIN and PUK (short for Pin Unlock Code) codes - but keep in mind, they may not work with all handsets and mobile operators. If you are interested in a software fix, click on the following link: Universal SIM Lock Remover
More importantly, when changing ones PUK codes there'll be no help to get from the mobile operator if the new codes are forgotten, so make sure to write any changes down alongside the old PUK codes. Also, please note that the codes should be entered without the spaces shown below.
Change SIM Card PIN
*# 06 #
Ben
*# 06 #
Ben
Aug 17, 2011 | Sony Ericsson W302 Silver +512MB by Fedex...
My phone don't have a puk code
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave'.for today.
PUK Codes
? Log in to myAT&T.
Change SIM Card PIN
*# 06 #
Ben
Aug 15, 2011 | Orange Cell Phones
I have an inactivated sim card and wanted to transfer my pics but I don't remember the pin
Pictures are not stored on a SIM card, they are stored in the phone's internal memory or on a memory card installed in the phone.
To retrieve them you don't need to install the SIM card, the phone should start without it.
Please come back and leave a rating/testimonial if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
Jul 30, 2011 | LG Cell Phones
Why when i'm using my samsung corby S 3653 i always received delayed and multiple messages?
This problem is generally seen when messages get stored on the sim card. generally sim cards have space for 20-30 msgs before phone memory gets occupied. I would recommend you to keep your sim card memory full always (as in keep some msgs permanently on the sim without deleting). To check memory usage, go to main menu-> messages -> memory status-> text messages (from top right drop down). The second row shows sim card memory status
---Pls rate if its useful---
Jan 09, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
My nokia 5310 will only display the Nokia logo the it will be off
if the problem u described is for real, m sorry to say that u need to format ur phone. Its because when u start ur phone, u see only Nokia logo. But inside, it prepares files which are required to start the phone & to keep it runnin for a long time. if any of these files gets corrupted or missing, ur phone wont start. so I'll suggest u, dont go here & there, go to Nokia Priority Care, and ask them to format it.
Aug 27, 2009 | Nokia 5310 Cellular Phone
Samsung S6102 Galaxy Y Duos - Black Unlocked GSM Cell Phone Logo
56 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
