Question about Brother MFC-3240C All-In-One InkJet Printer
HOW TO REFILL WITH THE HELP OF SYRINGE INK CARTRIDGES OF BROTHER
I have colour and black ink and syringes but do not know where to insert syringe in cartridge of brother mfc 3240c
  • garg_avinash Jan 27, 2009
    pls help me to locate the exact location of hole in the color cartridges of printer brother mfc 33240c so that i can insert the syringe to refill the ink
  • Anonymous Mar 22, 2014
    I refilled all of the ink cartrigdes with a syringe..(I used the original cartridges),now the printer will not recognize the black cartridge as being full
  • 10,865 Answers
Locate the small hole or holes on the cartridge and slide the needle in. Be sure to put the right color in each. good luck
Posted on Jan 25, 2009
  • Joe Hogan Jan 29, 2009
    If you can't find the little hole take the cartridge to a walgreen's drug store and ask them to show u as they refill cartridges at wallgreens.
How to refill ink cartridge of Epson me32?
Follow these steps:
1.
Buy an Epson ink refill kit. A refill kit gives you all the tools you need to refill Epson ink cartridges. Kits typically include a syringe, rivets, ink, and instructions on how to refill the cartridge. You can find Epson ink refill kits on the Printer Filling Station along with instructions for each specific model (see Resources).
2.
Cover your workspace with a paper towel and fill up the syringe with the ink color you need. Epson refill kits will either include black ink or the color combination cyan, yellow and magenta. On average, you'll need 10 ml of black ink or 5 ml of color ink for Epson ink cartridges.
3.
Find the rubber seals on the back of the Epson ink cartridge. Insert the rivets into each seal.
4.
Empty the contents of the syringe into the Epson ink cartridge. You'll want to perform this action slowly in order to avoid spilling or overfilling the cartridge.
5.
Remove the rivets. Use tape to cover the holes you made in the ink cartridge. Return the ink cartridge to the printer. Allow the printer to go through several print cycles in order to ensure that the Epson printer operates properly.
In case of any additional help please revert back
Jun 12, 2011 | Office Equipment & Supplies
Tip
How to Refill the Epson R340's Ink Cartridge
<span>Instructional steps<br /></span> Things You'll Need: <ul> <li> <span>Syringes</span> </li> <li> <span>Refill ink</span> </li> <li> <span>1/16 inch thumb screw</span> </li> <li> <span>Paper towels</span> </li></ul> <ol> <li> Place the cartridge on a flat surface over some paper towels to soak up any spilled ink.<br /></li> <li>Drill a hole directly above the "H" in the word "Push" on the top label.<br /> </li> <li> Drill a hole above the the first hole so air can escape while you are filling the cartridge.<br /> </li> <li> Fill a syringe with the correct color and amount of refill ink. The black cartridge holds 25 ml of ink. Color cartridges hold 10 ml of ink.<br /> </li> <li> Insert the needle of the syringe into the first drilled hole. Slowly inject the ink into the cartridge.<br /> </li> <li> Replace the cartridge into the Epson R340. Allow it to rest for 24 hours so the ink can absorb into the sponge inside the cartridge.please rate this post by saying how helpful it is to you<br /></li></ol><span><br /><br /><a href="http://www.ehow.com/how_7414161_refill-epson-r340_s-ink-cartridge.html#ixzz13r3MVnYc"><br /></a></span>
on Oct 30, 2010 | Office Equipment & Supplies
Please how can i refill a canon printer's cartridge (canon pixma ip2600), without the ink pouring out through the other end
Place the empty PG-30 cartridge on a layer of paper towels on a flat surface.
Use the thumb screwdriver to enlarge the small refill hole just below the letter "B" on the top of the cartridge.
Fill the syringe with 20 ml. of black printer ink.
Slowly insert the syringe into the refill hole that you drilled and release the contents of the syringe.
5
Allow the cartridge to sit upright for 4 hours before inserting into the printer.
Easy!
~KenjiFox
Jan 07, 2011 | Canon Pixma iP2600 Photo InkJet Printer
I whant to refill pixma canon ip2700 with black ink but dond now how
Color Cartridge 1. Place the cartridge over somepaper towels in case there are any spills.Remove the label sticker from the topof the color cartridge. 2. Drill into the three small holeson the top of the cartridge to widen them so they will allow syringe needles. 3. Fill a syringe with 6 mL ofmagenta ink. Insert the needle into the refill hole that is located below thetwo protruding rectangles on the top of the cartridge. Slowly inject the ink. 4. Fill a syringe with 6 mL of cyanink. Insert the needle into the refill hole located below the large rectangleon the top of the cartridge. Slowly inject the ink into the cartridge. 5. Fill a syringe with 6 mL of yellowink. Insert the needle into the refill hole located below the small rectangleon the top of the cartridge. Slowly inject the ink into the ink chamber. 6. Replace the cartridge into theMX310 printer. Black Cartridge 1. Set the cartridge on some paper towels. 2. Drill a hole into the dimplelocated directly above the semicircle on the top of the cartridge.Fill asyringe with 20 mL of black ink. Insert the needle into the hole and slowlyinject the ink. 3. Replace the cartridge into theCanon MX310.
Nov 28, 2010 | Canon PIXMA MX310 All-In-One Printer
HOW DO I REPLACE THE INK .I BOUGHT THE INK BUT FOR GOT HOW TO PUT IT IN
In order to replace the ink..please follow the following steps
#1
Spread out a piece of newspaper where you plan to work. Remove the supplies from the refill kit. The Lexmark 44 will have one bottle of black ink, one thumb drill and one syringe. The Lexmark 43 will have one bottle each cyan, magenta and yellow, three syringes and one thumb drill.
#2
Remove the label from the ink cartridge. The black refill hole is at the top of the ink cartridge. Use a toothpick to check the color of each fill hole on the color ink cartridge. Generally, the magenta is at the top of the cartridge, the yellow is at the left center and the cyan is at the right center.
#3
Use the thumb drill to open up the fill hole to fit the syringe needle. Place the tip of the thumb drill on the fill hole and twist until the hole opens up larger. Do this for each color hole on the color ink cartridge.
#4
Fill each syringe with 7 ml of color ink (one for each color) and 15 ml of black ink. Insert the syringe needle into the bottle of ink and pull the plunger upwards.
#5
Place the tip of the syringe needle into the fill hole. Slowly press down on the plunger. If the ink seeps out while filling, stop filling the cartridge and wipe up the ink with a paper towel. Some cartridges may not need the full amount of ink. Repeat this step for each of the colored ink fill holes.
#6
Replace the ink cartridge in the carriage of the printer. Run one to three test pages to cycle the ink and check the printing. Use any document with color on it for the Lexmark 43 and any document with black text for the Lexmark 44.
Thanks
Oct 06, 2010 | Lexmark X9575 InkJet Printer
How to refill hp photosmart C4280 psc all in one ink cartridges?
hi
check here for color one
for black
and for black XL
if i help you pls vote for me
Oct 03, 2010 | Computers & Internet
Hello'' can you tell me how to change the ink in the kodak printer?
  1. Open up the cartridge to reach the ink chamber within. For color and photo cartridges, just remove the lid with a sharp knife (insert it where the black and colored plastic meet) to find the three fill holes. On black cartridges, make a hole with a heated pin or drill on top of the cartridge where the letter "K" is.
  2. Step 2 Check the chambers in a color/photo cartridge to determine which color ink is in which chamber. Insert a different toothpick or pin into each chamber to draw out yellow, cyan or magenta ink.
  3. Step 3 Fill a plastic syringe bottle with enough ink in the color you are refilling. A black ink cartridge should need 10 to 15 milliliters. A color/photo cartridge takes 5 milliliters of each color.
  4. Step 4 Insert the syringe needle into the cartridge, sending the tip down to the bottom. The chamber contains a sponge, so you will need a small bit of force to push it in.
  5. Step 5 Inject the ink into the cartridge. Unlike other brands of cartridges, you want to saturate the sponge with ink in a Kodak cartridge. Depress the syringe plunger slowly until you can see the ink begin to surface on top of the sponge.
  6. Step 6 Wash all ink residue out of the syringe after you've refilled one shade of ink. If you intend to refill another color immediately, dry the syringe out first.
  7. Step 7 Replace the lid on a color/photo cartridge. Apply a strip of tape to the spot where you first removed the lid to secure it. You don't need to seal a hole you drilled in a black cartridge.
  8. Step 8 Leave the cartridge standing in a secure spot overnight. This helps the ink settle within the cartridge for even printing once the cartridge is back in the printer.
Apr 30, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Where do i inject the ink in my cartridges on a lexmark printer. i need to refill both cartridges. i have the black and coloured ink, and the syringe, however i dont know where to inject.
Usually the refill kits come with instructions that cover many cartridges.
A lot of the lexmark's use HP style cartridges and those often you lift the label to access the fill holes.
FILL SLOWLY and do not over fill. Usually the cartriges hold so many ml and youcan measure that on your syringe. Knock off a few ml from what they say the cartridge takes.
Nov 11, 2009 | Lexmark X2500 All-In-One Printer
Leaking ink cartridges
You will need a syringe no smaller than 20ml.
Remove the cartridges from the machine.
Holding them upside down, place the syringe in the hole.
Tilt the syringe slightly and drawback in an attempt to create a vacuum and pull the syringe out.
You only need a slight vacuum.
If air returns to the cartridge through the other hole (the one with the little white thing sticking out from the middle), then the cartridge maybe no good, although you could try using pliers to pull that stick out slightly and holding it for a bit to try and correct its position and hold a seal, but this is generally a temporary fix.
Now once again insert the syringe into the appropriate hole and attempt to create a vacuum then pull the syringe out.
Place the cartridges back in the machine and they should be ok.
Jun 12, 2008 | Brother DCP-110C All-In-One InkJet Printer
How To Refill?
Harry, you can use every DYE ink for brother printers. DO NOT use pigmented ink due to clogged filters inside the printhead!!!! The carts for mfc210 are filled with 20ml for BK and 11ml for C/Y/M. I use to refill 20ml only ink for bk and 10ml ink + 1ml printhead cleaner for C/Y/M. See here how to do that (LC900 refill): http://www.hstt.net/refill-faq/brother.html#LC-900 Refillen (Simply drill a hole into the brother brandname and leave it open!) I use a 20ml syringe and 3 12(10+2)ml syringes from the drugstore (ask your doc! It may be cheaper ;-)
Sep 26, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-3240C All-In-One InkJet Printer Logo
138 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
