Question about Lexmark Optra T614 Laser Printer
Conflict with new router address on my network
When I installed a new router, lost contact through home network with Optra T. The router address is http://192.168.1.254, printer is http://192.168.0.251. The router company said they cant help. Printer works if connected to one computer but I need network. Can you help me resolve it please?
    Novelist:
  • Lexmark Expert
  • 297 Answers
Printer IP needs to be in the same range as the computers and router. All should have the same first 3 sets of numbers....
192.168.1.
the last set of numbers identifies the individual address of the piece of equipment.
Change the IP address on the printer to 192.168.1.251 and see if you can see it in the internet explorer address bar...(should bring up a web page that displays the printers status) The other numbers should look like this:
255.255.255.0 (or similiar)
192.168.1.254 (Gateway ?)
Make sure the PC's all have the same first 3 sets also...or they won't see the printer.
Posted on Jan 25, 2009
I am trying to connect my Dlink DKT-401 router to my Linksys cable gateway router. I am not getting internet access when connecting to the Dlink network
I DON'T THINK YOU CAN RUN 2 ROUTERS ON THE SAME NETWORK UNLESS ONE IS USED AS AN ACCESS POINT.
1. Connect as local device or bridge - If connecting the second router via Ethernet cable, plug it into one of the LAN ports on the first router. If connecting the second router wirelessly, ensure the second router is set for client mode. Note that some home wireless routers do not support client mode; these must be connected by cable. Check your router documentation for details on its client mode configuration support.
2. Check / change IP address - Most home network routers use a default IP address setting. Often, these default IP addresses will not work in a two router environment. Check the second router's IP address value and reset it if necessary to work within the valid address range of the first router (and to not conflict with any other device on the network).
3. Disable DHCP - To avoid IP address conflicts between all of the devices on the home network, only one of your two routers should assign addresses via DHCP. All mainstream routers provide an option to disable DHCP as part of the router's configuration screens.
Instead of adding a second wired router to an existing network, consider adding a network switch instead. A switch accomplishes the same goal of extending the size of a network, but it does not require any IP address or DHCP configuration, greatly simplifying configuration.
Readers Respond:
Dec 11, 2010 | D-Link Computers & Internet
I have a message that say Ip address conflict, what can I do
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
Nov 24, 2010 | Computers & Internet
I have a DGL-4100 behind a Linksys DSL router 2 networks don't.
zSB(3,3) Installing a Two Router Network Installing a router to work as the second one on a home network requires special configuration. Do the following on the second router to ensure it (and the devices attached) function properly:
Oct 10, 2009 | Computers & Internet
Installed a new lynksys router and now can't 'find' it. I contacted lynksys support and they could not find a solution. Old lynksys router had a differenct IP address
IP addresses in a a home system are normally assigned dynamically (that means they are not necesarily always the same). If you require it (or any other device on your network) to have a particular address, you must set it to that address.
Network Magic from Cisco can help you to do this.
I hope this helps you
a
Sep 28, 2009 | Linksys NSLU2 Network Storage Link
How do I change the printer address on my optra t614
I only work on HP printers, but I believe I've seen this model before, if it is simply a network printer, it should have it's own web administrator console. Basically, if you type in 192.168.0.251 it should bring you to a control panel for the printer where you will be able to change the IP address. (Note: You will lose connection to the printer when the IP address is changed, but you can simply access it by entering the new IP address in your web browser)
Jan 25, 2009 | Lexmark Optra T614 Laser Printer
IP conflict issues
open explorer, type in 192.168.1.1
Type in router UserName and password.
If you don't know the UserName and Password check the manual for the default settings.
Have a nice day!
Dec 22, 2008 | Computers & Internet
Lost the install CD
hi,
it should be an ip conflict.I believe you are using both routers at same time which can give same ip address (as both routers ip range is same).hence by disconnecting one router(from network/power) will make your ip conflict resolved.
secondly there is no need of linksys installation cd as it will do more harm than good.routers dont need any software to run where as network adapters need drivers.if you have any further doubts ,you can directly post it.
thank you
Dec 11, 2008 | Linksys Wireless-G Broadband Router
I have Verizon Fios install in my home. I use to have Comcast. This is the situation, before the Fios my linksys wireless router was connected directly to a modem. Now my linksys wireless router is...
Your IP address for you linksys router needs to be changed.  More than likely there using the same IP address such as 192.168.0.1.
You have to convert your linksys router to a switch and change the IP address range it uses to on that doesn't conflict with the Verizon router.
10.150.1.1 should work.
Oct 08, 2008 | Computers & Internet
Lexmark Optra T614 Laser Printer Logo
155 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
