Need wiring diagram for Chemigem DM-52
Automatic dosing system for swimming pool
  • 11 Answers
SOURCE: Swimming pool cleaning robot doesn't move
Sound like your filter is dirty. Try backwashing if you have a sand filter, or clean your cartridges if that's what you have. A dirty filter will reduce water flow, which in turn affects the Nav.
Posted on Jan 02, 2009
  • 13 Answers
SOURCE: I have a 24 x 52 intex above ground swimming pool
You must open the little valve on top to let out the air, then screw it back on when water reaches the top,  and ensure both gates are open.
Posted on Mar 30, 2009
  • 990 Answers
SOURCE: I have 3 wires how do I wire the Wayne Reliant one
You should have a wire diagrahm on the back of the motor. It will give you placement for your lines and how to wire it for 110v and 220v. In ether case two of the wires will go to the line connections. You should have one green wire that will connect to the motor caseing on a green screw. It will be out of the way and not on the wire board. It will be on the motor housing off to the side. I hope this helps.
Posted on Dec 19, 2009
  • 587 Answers
SOURCE: I NEED A WIRING DIAGRAM FOR A 120/240/24V ACME
If you're wiring up 120 volts to the primary then you need to connect H1 and H3 together, then connect H2 and H4 together. Then connect one side of line (120 volts) to H1 and H3 and connect the other side of line (120 volts) to H2 and H4. Then for the 24 volts secondary X1 is one side of your 24 volts and X2 is the other side of your 24 volts.
For 240 volt primary connect H2 and H3 together, Then connect one side of your Primary (240 volts) to H1 and connect the other side of your primary (240 volts to H4. Then your Secondary 24 volts is still X1 and X2.
Posted on May 11, 2010
  • 24 Answers
SOURCE: need a wiring diagram for
Here it is. Please vote for me and give me a high rating, thank you. It takes time to find these things and I'm giving it to you free. Thanks and good luck.95e7514.gif
Posted on Sep 12, 2010
Testimonial: "very helpful and nice "
How much salt do i need for a 24 ft round pool
depending on the salt system you are using, the amount of salt will vary. the owners manual should have a salt table with a recommended value. most salt systems will require somewhere close to a 3000 ppm level. to get this, you will need approximately 140 kg of salt. (65 lbs)
Sep 08, 2014 | Intex Automatic Salt Water System for ...
The water is getting cloudy and the sides of the pool are slimy
If your pool water is clowdy and slimy then it is about to turn green. What you need to do first is shock the pool to recommended dose to start killing the algae.
The most common error users make in managing a salt water pool besides not having salt in the pool has no stabilizer in it. This is a chemical that has an affinity for chlorine ions and if it is not there the chlorine can be disipated in a few hours when the sun hits it. Another name for it is Cyanuric Acid. It can be purchased in granular form at many pool supply stores or in a liquid form at Leslies. In order to get your pool blue you need to have the chemistry checked at a pool store or with a test kit (either liquid or strips). Don't buy everything a pool supply tells you to buy but start out with vinyl safe shock, stabilizer and salt. The pool store should be able to help you determine the dose. The following is what I would do:
1. Make sure salt is at the recommended concentration.
2. Shock the pool to recommended dose to start killing the algae.
3. Place the recomended dose of stabilizer in the pool.
4. Make sure pump and filter are working properly.
5. Check the pool chemistry on a daily basis until it is ready for swimming.
6. Check the chemistry on a weekly basis and clean the pool and equipment according to the pool instructions.
Smile, you are a pool manager.
Jul 05, 2011 | Intex Automatic Salt Water System for ...
My water turned green after I boosted it with my salt water system
The most common error besides not having salt in the pool is not having the right amount stabilizer in it. This is a chemical that has an affinity for chlorine ions and if it is not there the chlorine can be disipated in a few hours when the sun hits it. Another name for it is Cyanuric Acid. It can be purchased in granular form at many pool supply stores or in a liquid form at Leslies. In order to get your pool blue you need to have the chemistry checked at a pool store or with a test kit (either liquid or strips). Don't buy everything a pool supply tells you to buy but start out with vinyl safe shock, stabilizer and salt. The pool store should be able to help you determine the dose. The following is what I would do:
The water in the electrolytic cell is green? Do I need to clean it?
I assume from your comment about having green water in you electrolytic cell that maybe you don't have it connected to a pool yet or the pool water is green also. Anyway, if you are just starting your system and there is green water in the electrolyic cell then pore it out and when you place it into operation the pool water will clean it out. If the electrolyic cell is working the most overlooked cause for green water besides not having salt in the pool is it has no stabilizer in it. This is a chemical that has an affinity for chlorine ions and if it is not there the chlorine can be disipated in a few hours when the sun hits it. Another name for it is Cyanuric Acid. It can be purchased in granular form at many pool supply stores or in a liquid form at Leslies. In order to get your pool blue you need to have the chemistry checked at a pool store or with a test kit (either liquid or strips). Don't buy everything a pool supply tells you to buy but start out with chemistry test strips, vinyl safe shock, stabilizer and salt. The pool store should be able to help you determine the dose. The following is what I would do:
5. Check the pool chemistry on a daily basis until it is ready for swimming (or for at least 1 week).
Jul 04, 2011 | Intex Automatic Salt Water System for ...
2010 Easy Set 2500 Gph Swimming Pool Filter Pump (): ok we have the 24 by 52 in intex metal frame pool ...
88 It is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process. On the filter set it to run atleast 1 hour longer than you SWS. set the timer on both at the same time.
May 18, 2010 | Intex 2010 Easy Set 2500 Gph Swimming Pool...
I have a 15 ft by 48 inch intex pool and i just
The most obvious thing besides not having salt in the pool has no stabilizer in it. This is a chemical that has an affinity for chlorine ions and if it is not there the chlorine can be disipated in a few hours when the sun hits it. Another name for it is Cyanuric Acid. It can be purchased in granular form at many pool supply stores or in a liquid form at Leslies. In order to get your pool blue you need to have the chemistry checked at a pool store or with a test kit (either liquid or strips). Don't buy everything a pool supply tells you to buy but start out with vinyl safe shock, stabilizer and salt. The pool store should be able to help you determine the dose. The following is what I would do:
Aug 10, 2009 | Intex Automatic Salt Water System for ...
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Electro Med Services...
