Question about Ahead Software Nero 6 Ultra Edition (2434nl20) for PC
Single or Duel Layer?
How can you find out if your dvd player is a single layer or duel layer
  • 79 Answers
Look at the device name in device manager - the letters DL should appear. If not look in BIOS or ont he back or front of the drive. Nearly all drives, around 2 years old and onwards are dual layer. HOWEVER do not be surprised if you cannot write to dual layer discs. DL is a black art and is very difficult and is still not developed properly.
Posted on Jan 25, 2009
HL-DT-ST DVDRAM GT51N ATA CAN IT BURN DUEL LAYER DVDS
If it is not a dual layer DVD burner then it will not burn those dual layer disc.. Sould like all you have is a ROM read only
Oct 27, 2014 | Computers & Internet
Whats a dual layer disc mean then?
A dual layer disc is a DVD which is able to hold double the info.( http://en.wikipedia.org/wiki/DVD#Dual-layer_recording )
Dual-layer recording (sometimes also known as double-layer recording) allows DVD-R and DVD+R discs to store significantly more data-up to 8.54 gigabytes per disc, compared with 4.7 gigabytes for single-layer discs. Along with this, DVD-DLs have slower write speeds as compared to ordinary DVDs and when played on a DVD player a slight transition can sometimes be seen between the layers. DVD-R DL was developed for the DVD Forum by Pioneer Corporation; DVD+R DL was developed for the DVD+RW Alliance by Philips and Mitsubishi Kagaku Media (MKM).[23]
A dual-layer disc differs from its usual DVD counterpart by employing a second physical layer within the disc itself. The drive with dual-layer capability accesses the second layer by shining the laser through the first semitransparent layer. In some DVD players, the layer change can exhibit a noticeable pause, up to several seconds.[24] This caused some viewers to worry that their dual-layer discs were damaged or defective, with the end result that studios began listing a standard message explaining the dual-layer pausing effect on all dual-layer disc packaging.
DVD recordable discs supporting this technology are backward-compatible with some existing DVD players and DVD-ROM drives.[23] Many current DVD recorders support dual-layer technology, and the price is now comparable to that of single-layer drives, although the blank media remain more expensive. The recording speeds reached by dual-layer media are still well below those of single-layer media.
There are two modes for dual-layer orientation. With Parallel Track Path (PTP), used on DVD-ROM, both layers start at the inside diameter (ID) and end at the outside diameter (OD) with the lead-out. With Opposite Track Path (OTP), used on many Digital Video Discs, the lower layer starts at the ID and the upper layer starts at the OD, where the other layer ends; they share one lead-in and one lead-out.
Jun 16, 2011 | Nintendo Wii Console
Hello i have bought my daughter a RV510 500GB 4 GB MEMORY 15.6 INCH LAPTOP WITH DVDOPTICAL DRIVE DUAL LAYER. HAS IT GOT DVD +OR- RW.
Hi, You should be able to use both, but if you make your own movies or music the most popular one is -R DVD. RW are rewriteable up to 3 times. Your laptop will handle both DVD and or CD and duel layer too.
Jun 12, 2011 | Samsung Computers & Internet
Can a slimtype dvd a ds8a2l-a ata device burn duel layer disks
the simplest way to find out is to get hold of a duel layer disk
that already has media on it if it reads the disk then it will be
able to copy to a blank duel layer disk.
Feb 12, 2010 | Computers & Internet
Capacity of the inbuild optiarc dvd
Here the recording spec for the drive
It quotes double layer so it should be able to do up to 8.8 GB which is way way way way bigger than 4.37 mb.
DVD+R (DVD+R Part 1 Single Layer, Basic Format Spec Ver 1.3) / DVD+RW (Single Layer, Volume1: 4X Basic Format Spec Ver 1.3 and Single Layer, Volume2: 8X Basic Format Spec Ver 1.0) / DVD+R DL (DVD+R Part 2, Double Layer: Basic Format Spec Ver 1.0) / DVD-R General (Ver 2.0 and 2.1) / DVD-RW (Ver 1.1 and 1.2) /DVD-R DL (Ver 3.0)/ DVD-RAM (Ver V2.0 and 2.1 and 2.2 Class 0 ; Single side :4.7 GB/1.4 GB ; Double side :9.4 GB/2.8 GB) and CD-R/CD-RW media
Oct 29, 2009 | Compaq Presario 700 Series DVD-Rom Drive...
What does "multi layer support" mean. Does it write multi layer discs? or is it able only to read them? Also, what is a lightscribe?
Multi-Layer support means the drive can Read/Write a Dual-Layer discs.
Lightscribe means you can create a label on a disk.
Check these Links fro more information:
http://en.wikipedia.org/wiki/LightScribe
http://www.lightscribe.com/gettingstarted/index.aspx
Good Luck!!!!!!!!!!!!!!
Sep 18, 2009 | HP Pavilion dv1000 Notebook
Error burning to Dual Layer DVD
Do you have a dual layer burner, you need one to burn dual layer dvds that may be your problem hope it helps
Mar 25, 2009 | Global Marketing Partners Vhs To DVD 3.0...
Dvd-(+)rw won't play on Philips dv642
This player will only read the dvd- format and the dvd- duel layer format this is normal and cant be changed!
I hope this answers your question
PLEASE rate this answer!
THANK YOU!
Jan 18, 2009 | Philips DVP642 DVD Player
Dvd recorder funai
I have fixed mine with the same problem , all it needed was the lens cleaned , i used a laser lens cleaning disc from maplin for 6.99 and voila good as new.
May 09, 2008 | Funai PY90DG DVD Recorder
PC-Drive
it seems that this drive has problems reading dual layer disks but the 8163b dosnt seem to hope this is helpful
May 07, 2008 | Computers & Internet
Ahead Software Nero 6 Ultra Edition (2434nl20) for PC Logo
Top Ahead Software Computers & Internet Experts
celos
lemesee
Are you an Ahead Software Computer and Internet Expert? Answer questions, earn points and help others
