Question about Water Heaters
Vokera beep Boiler emitting a beep every five minutes or so. Other than that working perfectly
  • 17 Answers
SOURCE: Vokera Linea 28 combi boiler
sounds like you have an earth leak or defective pump winding
Posted on Nov 27, 2008
  • 234 Answers
SOURCE: vokera mynute 14se lockout reset button on
Has the boiler cool down? Try turn the power off for a few minutes and see if that will work.
Posted on Mar 15, 2009
gary1121
  • 332 Answers
SOURCE: vokera combi boiler
there is a zoneing valve thats suppose to be in the line to keep this from happening, might even have a check valve either way which ever one you have is bad and should be changed with a new one
Posted on Jun 06, 2009
mrhotandcold
  • 248 Answers
SOURCE: i have a vokera boiler and the fault that flashes
refere to manual sounds like overheat stat call expert
Posted on Oct 11, 2009
mrhotandcold
  • 248 Answers
SOURCE: i have a vokera unica 28 which pulses when firing
your fan may need attension fan runs after boiler shuts down is normal on some Vokera,s too clear fumes out the flue 2mins approx
Vokera aav leaking
Robert, i'm sorry to say but the AAV's are machined parts and the seal should not have been broken by removing the cap. The floats are set perfectly and you would have been easier replacing the whole vent. You could have isolated all the pipes under the boiler and just drained the boiler down by releasing any pressure by the pressure release valve. You may need to buy another AAV and start again.
Apr 06, 2014 | Water Heaters
Vokera boiler problems
need to change thermostat and a thermocouple
Jan 28, 2014 | Water Heaters
Vokera mynute 28 se, plumber has replaced fan and swithch as the burner would not cut in, was beeter for a year or so, in trying to find the problem again, he has discovered that if the front plate closing...
It sounds to me like the outside air intake (your boiler requires outside air for combustion) is plugged. Bird's nest, maybe? Leaves? Spider webs? Have the plumber check outside AND where the intake air connects to the boiler.
Nov 05, 2013 | Water Heaters
Low pressure on recently serviced Vokera 14/48se.
Identify the cold feed to the boiler, then look for a tap/service valve which when turned lets water into the boiler via a fill loop to pressurise it. 1-1.5 bar is ok
ju
Nov 05, 2009 | Water Heaters
I have a vokera unica 28 which pulses when firing
Oct 04, 2009 | Water Heaters
Vokera mynute 14se lockout reset button on
Mar 14, 2009 | Water Heaters
Vokera combi boiler
Feb 20, 2009 | Water Heaters
Water Heaters Logo
246 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
