Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
GE Profile Dishwasher with water in bottom, won't drain Cloudy water remains in bottom of washer and won't drain.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Your described problem almost always indicate a faulty drainage system. Unless there are defective components, cleaning (although messy) would be corrective. Normally, there would be a filter/screen that could get clogged, a sump/bowl that may be filled, an impeller bot turning or a stuck pump motor. It is also possible that debris could be blocking the drain valve of the drain hose is kinked, blocked or for some reason not discharging. As earlier stated cleaning would normally address the issue.
Good luck and thank you for using FixYa.
Posted on Jan 25, 2009
    Brigadier General:
  • 5,158 Answers
If it will drain in other cycles it's the control module... if it won't drain ... you have a clogged drain hose
Robert
How do I find and check the drain hose on my GE PDW8480 dishwasher?
The drain hose normally goes to the air gap located next to the sink faucet if it doesn't have that make sure the hose is higher in the middle than it is where it drains to the garbage disposal the dirty water is coming from ur sink from when u wash dishes then it goes back to the dishwasher you need to elevate the drain hose
Apr 12, 2013 | GE Profile PDW8400J Built-in Dishwasher
My GE profile dishwasher is leaving soap residue on the dishes after a wash cycle. Cloudy and a sort of fim on the dishes. Seems to be getting worse. I use the same dish detergent-Cascade and regulary use...
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Mar 04, 2011 | GE Dishwashers
Ge profile dishwasher never cleans dishes and water is constantly in the bottom of the dishwasher producing a horrible smell.
DishwasherProblems - Water will not drain out
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Oct 20, 2010 | GE Profile PDW8600J Built-in Dishwasher
Dishwasher overflowed, garbage disposal still works. Ran the dishwasher and noticed food and debris shooting back into sink thru garbage disposal. Water was on floor. Upon completion of full cycle, water...
Before loading into the machine you have to remove food particles. Washer will wash the greasy surface. If particles are left in the dishes, the same will find entry to the drain system. Check the drain filter in your machine. Clean them. Mostly problem will be solved!
Apr 08, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
The GE Profile Dishwasher does not drain completely. The bottom drain shows no obvious clog and the screens are clear. The overflow drain in the back of the washers the only reason the dishwasher does not...
Uncouple the drain hose connection under the sink and use a wet/dry vacuum to **** out the drain hose and the stub on the sink drain plumbing to clear any possible clogs. There may be a blocked check valve near the pump that might have to be cleaned or replaced. Check the hose itself for any kinks or collapsed section. There might be a damaged drain impeller on the pump. Hope this helps!
Mar 11, 2010 | GE Profile PDW8400J Built-in Dishwasher
Dish washer is leaking soap suds from bottom of door and doesnt seem to want to drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Jan 09, 2010 | GE 24 in. Profile PDW7800 Built-in...
Washer does not drain, and leaves water in the
hi..The drain is clogged.check the strainer at the
bottom of your unit.Always rinse your dishes of food
before putting them in the washer.
check this out..
thank u..
kindly rate my response..
Jun 09, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE profile dishwasher does not drain out aat end of cycle
I just fixed the very same problem by replacing the piston and nut (part # WD24X10018).
Jan 07, 2009 | GE Dishwashers
GE NAUTILUS GSD3200-J00WN DISHWASHER WON'T COMPLETELY DRAIN
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
heatman101
Dec 27, 2008 | GE Profile PDW9880NSS Stainless Steel...
GE Profile Dishwasher (5 years old); Leaving residue on dishes
In my case the counter mounted breather for the drain tube was being restricted ... finally to the point it would not drain the tub at all. I disassembled the above counter drain assembly and cleaned it out as it wass completely blocked and things work very well again. I would suggest this foirst as it is an easy task and is done 'above the counter'.
I then ran 2 cups of CLR with wash cycle ... no dishes to clean out the rest of the washer as on dissaembly of the internals to diagnose they were and very scummed up with a hard white crusty substance that was completely blocking some of the drain sump performations.
Dec 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
114 people viewed this question
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
