Question about Dell Inspiron 531 Athlon 64 X2 4400+ 2.3GHz 1GB 500GB DVD RW Vista Home Premium PC Desktop
Booting up I can't boot up, Ubuntu 12.0.4LTS is the OS. I tried the install CD, an x appears where a checkmark should be in the required drive space, it won't continue the install. I did install a new power supply before all this happened. Could I have a loose cable somewhere causing the problem?
  • Dell Master
  • 998 Answers
Yes, I would check all connectors and remove all devices to the bare bones and see if it boots up. Then re-install cards one at a time to see if you can isolate the problem to a specific card or device.
Posted on May 09, 2014
Sunil Panem
  • 80 Answers
SOURCE: System won't boot
Hi
As the power light doesnt come on, the comp is not getting any power. Pls reseat the cable tht goes from the motherboard to the power button inside and check if it is turning in. Otherwise the comp has to be serviced.
Posted on Feb 05, 2008
  • 1602 Answers
SOURCE: my dell optiplex 260 can't recognize a cd-dvd ron or hard drive
CMOS BATTERY MY BE THE PROBLEM.
GO INTO BOID GO TO HARD DRIVE SETTING SELECT NEW HARD DRIVE SEE IF IT WILL REGISTER OR COME UP.
REBOOT SYSTEM.
OR
WHEN THE SYSEM FIRST COMES ON YOU WILL SEE SOME INSTRUCTION FLASH UP ON THE SCREEN PAUSE THE IMAGES OR INFORMATION TO SEE WHAT "F" KEY TO PUSH LIKE F10 FOR A FEW SECOND OR UNTIL YOU HEAR A BEEP NOISE
LET THE COMPUTER FINISH WHAT IT IS DOING AND FOLLOW INSTRUCTION INFORMATION ON HOW TO DO THINGS ARE LIST ON THE BUTTOM OF THE SCREEN AND HOW TO SAVE IT WHEN YOU ARE DONE IT IS USUALLY F10 AND Y FOR YES THAN REBOOT SYSTEM.
ROD
Posted on Feb 09, 2009
rwalkero
  • 82 Answers
SOURCE: Dell Dimension C521 w/Vista will not boot OS.
There is no way around this you need to get your OS from Dell and reload.
Sorry.
Posted on Feb 19, 2009
siawolf
  • 749 Answers
SOURCE: dell optiplex gx280 won't boot up
you either have the boot priority in the bios off or you have improperly cabled your hard drive . perhaps you set it to boot to cd while installing the operating system and forgot to change the order back.
The floppy drive does not have to be present for the system to boot (if set to "not installed" in bios)
your boot devices are your cd/dvd rom and your harddrive.
Seeing as you've recently replaced the power supply , ime assuming you didnt dismantle the whole computer , just the power leads coming from the power supply, which means you only moved power , not data cables.
This would be the first thing to check -- power to the harddrive and cd rom, the 4 pin connector that sometimes connects to the motherboard and any data cables you might have bumped while changing the power cables. check these things and post here again.
Regards
Posted on Apr 01, 2009
wipdhuls
  • 133 Answers
SOURCE: dell dimension L800CXE
Hello Wademyd,
It seems that the installation CD that you have is not a bootable CD.. must be old one.
Please down load the boot disk for windows from http://www.bootdisk.com or follow the Microsoft article link given below:
http://support.microsoft.com/?kbid=310994
Do not be intimidated by the article, although it looks big but there is very little that you need to do, rest of it is general instructions like where can you order a new CD from etc...
OR
Simple solution is to borrow Bootable Windows XP installation disk and install it using the serial Key that has been given to you.
Please let me know if that helps and please rate the solution if it helped you.. it will not cost you anything but will make a difference for me :)
All the best and kindly let me know in case you need any further assistance.
Regards,
Srinivas
Posted on Jun 11, 2009
Can I override the bios at startup so that it will recognize a new hard drive - for linux?
There should be no need to play around with your bios settings. Linux will install on a brand new hard drive as the sole operating system, or on an existing hard drive alongside Windows without any problem.
If you haven't already got a Linux distro, have a look at
http://www.ubuntu.com/download/desktop
Download whichever version of Ubuntu you prefer (LTS- the long term support version is recommended).
When the .iso file containing the operating system had downloaded, burn it onto a dvd, or install it on a usb drive.
Insert the dvd into the drive and restart or switch off/switch on the computer. The dvd will then kick in and offer you the choice of trying Ubuntu without installing, or a full install.
If you're using a new, empty hard drive just follow the on screen instructions and Ubuntu will install as the sole operating system.
If you already have Windows on your hard drive Ubuntu will give you the choice of either erasing Windows or installing Ubuntu alongside Windows. It's your choice.
Installing Ubuntu alongside Windows creates a dual boot hard drive. At start up you just choose which OS to use - Windows or Ubuntu. If creating this dual-boot system Ubuntu puts a (Linux) boot loader into the Windows OS so that Linux is recognised.
If you save the Ubuntu file to a usb drive you then have to change the bios settings so that your computer uses USB as the first boot device. Then restart your computer so that it boots in from your usb .. and Ubuntu will begin installing.
Whichever you use - dvd or usb - during the installation process Ubuntu will ask you how many GB of hard drive space it should use? You do not need to physically partition the hard drive. Linux will do it for you.
If it's a desktop PC you are using with Windows on the first hard drive and are fitting a second hard drive to install Linux on, or have installed Linux on the second hard drive .. and find that Linux doesn't appear at start up, it's because there's no Linux boot loader in Windows.
I quit using Windows many years ago.
Nov 01, 2015 | Everex IMPACT GC2500 PC Desktop
Toshiba satellite M45-S169 won't boot ubuntu from DVD
Your really pushing the lower minimum requirement limits if you're trying to use Ubuntu 11 or Ubuntu 12. Especially with your on-board graphics chip which borrows system ram.
Try Ubuntu 10.04.4 LTS (Lucid Lynx) instead.
Go Here and download the 1st link on the list under Desktop CD:
http://releases.ubuntu.com/lucid/
OR...
Here is a direct link to the ISO file you need to download and then burn to a CD:
http://releases.ubuntu.com/lucid/ubuntu-10.04.4-desktop-i386.iso
If you don't have Software for burning iso's to CD's then download and install this totally FREE CD Burning program:
http://download.imgburn.com/SetupImgBurn_2.5.7.0.exe
May 31, 2012 | Toshiba Satellite M45-S169 Notebook
Linux install on a powerbook g4
I might be talking off my head here - but doesn't linux require an intel processor?
Feb 02, 2012 | Computers & Internet
My FUJITSU SIEMENS AMILO PA 1538 screen comes black ? HELP
Try connecting the laptop to an external monitor and see if all is working Ok with that, if it is, then you may need to get the laptop display serviced - if it does the same on the external display, then try booting the laptop from a CD or DVD such as an OS install CD (Windows or Linux) or a boot utility CD such as Hiren's Boot CD - this will allow you to test whether the problem lays with your installed operating system or with the hardware. . . .
Note: do not go any further than the initial displays if using an OS install CD unless you are using a Linux Live boot CD which will not destroy your installed operating system. . . .See http://www.hirensbootcd.org/ to download a copy of Hiren's Boot CD to burn to a CD. . . .See http://www.ubuntu.com/download/ubuntu/download to download a copy of a Ubuntu (Linux) Live CD.
Dec 17, 2011 | Computers & Internet
How can i boot my Windows Seven OS if the "bootmgr is missing"? I'm installing windows seven but when windows start copying files but error message appears that required files for the...
What you need is bootable DVD/CD for installing or repairing Windows 7 to get missing 'bootmgr' or repair corrupted bootmgr...If there are files corrupt on your CD, you can get new one from shop you have purchased..Maybe just need to clean up your DVD/CD, so your DVD drives can read properly the files installation..
Aug 07, 2011 | Computers & Internet
How can i install Linux OS on my laptop? please help
do you want to have Linux while you are also having Windows? Then is will be a dual boot. To do this, have another partition of your hard disk empty. Like C (windows) and Drive E(free partition).
Download the latest version of ubuntu linux and use the bootable cd to install ubuntu on the other partition
Sep 15, 2009 | Microsoft Windows Vista Ultimate Edition
Install Ubuntu
Make sure the computer starts from the cd drive.
see this page for instructions on changing the boot order
http://www.whitecanyon.com/how-to-change-boot-order.php
ones the boot order is set properly insert the cd in the drive and restart the computer.
ubuntu cd/dvd will load and give you some options on the screen, follow the prompts to install ubuntu.
if you need more help read the ubuntu documentation
https://help.ubuntu.com/community/Installation
if the above link is broken try
http://help.ubuntu.com/community/Installation
Aug 09, 2009 | PC Mall Ubuntu 8.10 for Linux
Difficult boot from cd drive - dell inspiron
Try to do this, when you see the dell logo, keep on tapping f12 then choose cd rom or dvd rom device, then keep on tapping enter until you will be able to see the setup page of the program/os that you are installing.
Nov 03, 2008 | Dell Inspiron 9200 Notebook
Table Pc
if you have an external dvd drive try using it
there's no easy answer.
Jul 26, 2008 | CMB T43 750 Notebook
Open Questions:
Dell Inspiron 531 Athlon 64 X2 4400+ 2.3GHz 1GB 500GB DVD RW Vista Home Premium PC Desktop Logo
37 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
