Question about Winter Sports
How do you do a parallel turn? - Winter Sports
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 21 Answers
My computer cannot detect my scanner. Error Code: 0x0070800
The FB320P is a parallel port scanner and is having problems communicating with the computer. Are you connecting it directly to the parallel port on the computer? In that case, you may not have bi-directional communication enabled. Turn off the scanner and the computer and disconnect the data cable from the computer. Turn on the computer and enter the BIOS. (Press Esc, F1, F10, or Del repeatedly after you turn the computer. You should see a screen with the correct key to press; it varies depending on your BIOS and motherboard. If you miss the timing, shut down the computer and try again.) In the BIOS, search for the parallel port settings and see if you can enable bi-directional communication.
Not all parallel ports support bi-directional communication. If you can't enable the feature, you need a different parallel port. Try a PCI slot add-on card; just check the features and check the manual for enabling bi-directional communication.
If you are using a USB to parallel port adapter, get a different one that supports the bi-directional communication.
What OS are you using? There are a few that had ASPI driver issues; a third party app, ForceASPI, may help. See http://www.afterdawn.com/software/cd_dvd/dvd_tools/frcaspi.cfm for information.
I hope this helps. Please add more information about the configuration (cable, OS, etc) for extra ideas to solve the problem.
Sep 16, 2012 | Canon CanoScan FB320P Flatbed Scanner
How do i install 2 ckicker cvr to my amp
Here are a couple of diagrams 2+4 ohm dual voice coil wiring.
Option 1 (parallel/parallel) = 1 ohm load
Voice coils wired in parallel, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono 2_4ohm_dvc_1ohm.gif
Option 2 (series/parallel) = 4 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif
Option 1 (parallel/parallel) = 0.5 ohm load
Recommended Amplifier: Stable at 1/2 ohm mono 2_2ohm_dvc_05ohm.gif
Option 2 (series/parallel) = 2 ohm load
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_2ohm_dvc_2ohm.gif
Option 3 (series) = 8 ohm load
All voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif
Apr 12, 2010 | Kicker CVR12 Car Subwoofer
How do i hook up kicker solo baric in the box
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif Option 1 (parallel/parallel) = 1 ohm load
Apr 10, 2010 | Kicker Solo-Baric L5 Car Subwoofer
How do i install my L5 solo barics to a 2 channel amp if there is only one connection on the enclosure next to the vent? If I bridge the amp to 1x1000W will the power distribute evenly between both...
Option 1 (parallel) = 2 ohm load
Speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_4ohm_svc_2ohm.gif
Option 2 (series) = 8 ohm load
Speakers wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_svc_8ohm.gif
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif Option 1 (parallel/parallel) = 0.5 ohm load
Apr 09, 2010 | Kicker Solo-Baric L5 Car Subwoofer
Mb password lost
Only solution is to buy, or make on your own, a parallel port password removal key. You can probably get a cheap one on eBay for around $10, or make one using an old, parallel printer cable. The wiring schematics is available for free (just google it). Plug the key into the parallel printer port, turn on the laptop, and the CMOS password will be removed.
Feb 13, 2010 | Toshiba Satellite Pro 490CDT Notebook
I installed the laser hp 1100 on windows xp
Your problem is your PC parallel port is not configured or turned on. I would first look in the control panel, device manager and see if you have a parallel port listed and it does not have a yellow or red sign on it. If red or yellow then it is on but not configured. See below for that solution.
If it does not appear, reboot your PC and enter the bios. Find the setting for the parallel port and set to enable. If on you can change the setting on what type of parallel it is emulating. Normal is bi-directional IEEE.
Then save and restart to go into Windows. Test and print.
OK, if the parallel port in the DEVICE MANAGER shows a yellow or red sign on it, it has a bad driver, or bad settings. Un-install the port by right clicking and choose UN-INSTALL. Restart your PC and it should find the parallel port and install it again. Hopefully without the yellow or red sign on it. If the red or yellow sign is back. Look on the internet for the newest driver for your motherboard.
As a note: if you are using a print server or USB to parallel adapter these solutions won't help. You will have other issues to address.
Good Luck
Dec 17, 2009 | HP LaserJet 1100 Printer
Hi my HP scan jet 3400c cannot turn on. what is a problem.
The scanner have two ports to connect to PC, USB and Parallel.
It has no Power switch.
Disconnect all cables from your scanner (USB/Parallel and power.
Plug power cable to the scanner, and then plug the power supply to an outlet.
Does it turn on ?
If not, than check the power adaptor.
If it turns on, then turn off your computer, plug the USB/Paralel connector to the scanner and to your PC and turn on your PC.
You should know that you can use only one connection for your scanner at a time, USB OR Parallel.
Parallel for under Windows98, and USB for Win98 and above.
Regards.
Apr 20, 2009 | Computers & Internet
HP 4400c scanner
I~m considering that you already have turned everything off (computer, scanner, all the power) and turned on again. Your parallel port may be damaged. You shoult try to use your scanner in another PC, if it works, you will have to replace the parallel port. (there are some PCI cards with parallel port, it´s cheaper than to replace the entire motherboard.
Apr 29, 2008 | Office Equipment & Supplies
Unable to use CanoScan N640P with Acer Notebook
Hi ymonique,
Can you tell us whether this worked? I have the same problem but the system still cannot find the scanner when I use a USB to parallel cable.
Sep 29, 2007 | Canon CanoScan N340P Flatbed Scanner
Winter Sports Logo
670 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
