Question about HP OfficeJet 6210 All-In-One InkJet Printer
Tops of characters cut off
My printer is printing some of the lines with the characters cut off on top. For example, all letters that are uppercase (capital letters) or letters that go above the line, such as t, d, b, l, etc are cut off on top. It is not happening on every line, on some of the lines the print is normal. We are stumped. We aligned the cartridges, and answered some diagnostic questions on the windows xp helper, but we got no solution. Thank you in advance for your help. Cathy and Paul Seifer
  • Anonymous Mar 18, 2014
    text is not being printed only top of lines are showing
    Genius:
  • 2,985 Answers
Go to www.fixyourownprinter.com for expert help on this particular problem
Posted on Jul 12, 2007
SOURCE:
How do i type in password uppercase characters
On the top left hand side of on screen keyboard the is an arrow pointing upward. That will do cap ital letters
Nov 27, 2014 | Roku 2 XD Streaming Player 1080p (3050R
Where can I find the vertical typebar adjustment?
Guessing the buffer resting stops for smalls and possibly capitals have moved ir come loose? They should be adjustable with a small spanner and screwdriver. Or if not adjustable you might have to slightly slightly bend the resting stops! However before doing any off the a both check the plate under machine where the shift lock rests. That might be very loose abd give some similar problems. Best
Jul 16, 2014 | Olympia Office Equipment & Supplies
Ip3500 printing misaligned vertical band
my copier nashuatec 3722 .when start copier give me code E-4
Dec 07, 2013 | Canon PIXMA iP3500 Printer
Printing characters
If the characters are on the top of each page there is an invallid printjob in your system. Make sure you remove all printjobs on your pc('s) before restarting the printer.
Dec 31, 2009 | HP LaserJet 2100 Printer
Printing not proper
Adjust the printing properties from normal to best.
Mar 28, 2009 | HP DeskJet 3940 InkJet Photo Printer
Passing PCL code from Word document
All PCL Command Sequences begin with the escape character (an ASCII control code with a hex value of 1Bh, 27 decimal) and end with the first upper case letter (or "=" note: "@" is considered an uppercase letter). In between there is either nothing (the PCL command is just the escape and a single upper case letter) or a set of one or two characters and often a numerical value. The single character commands are listed at the end of the "Decoded PCL commands" table below. The first non-uppercase character after the escape will be a symbol between "!" and "\" (most commonly one of %,&,( or *) which is called the "parameter." After the parameter there is normally a lower case letter called the "group." After this there may be a numeric value. If no value is present, the value is assumed to be zero. Finally the ending uppercase letter is called the "command." See Examples, Tutorials below for some samples of PCL commands and the Decoded commands List for detailed information. Note that these use the text "Ec" to mean the escape character. Since the escape character is not printable, it is very hard to convey in human readable text. Common abreviations are Esc, Ec, [], or <-. See the ASCII page for more information on the codes. That page also allows you to convert between hex, decimal or ASCII codes. The form below can be used to find english descriptions of PCL commands. Just paste the PCL into the box, if you use "Ec" or "esc" to mean the escape character, press the "Ec and esc
i hope this will work for you
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Feb 12, 2008 | Computers & Internet
Canon printer double printing and nor lining up top and bottom of letters
I had a similar problem with my 8500. I downloaded the latest driver from Canon, and the problem seems to be fixed.
Feb 05, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Printer switching orientation
Make sure that manual feed is set to letter, on the printer front panel. This is a tabloid printer, so letter size sheets are fed long edge. The cassette will print okay because the media size info for the cassette is read by the printer from the cassette cams.
Dec 21, 2006 | Xante 4G Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
747 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
