Question about Yamaha RX-V673 7.2 Channel AV Receiver BONUS PAK w/ Two HDMI Cables
My Blu-Ray DVD player is connected to the AV Receiver with HDMI cable.
A friend advised me to connect the Blu-Ray DVD player to theAV receiver with an additional optical cable to further improved the audio. Is this true? Isn't it that an HDMI cable is sufficient for both Video & Audio connection?
    Genius:
  • Yamaha Master
  • 1,054 Answers
You're not going to get any difference using an optical cable. In fact, your receiver cannot look at both jacks at once anyway. If you select an input, it only looks at one jack, it cannot take info from both.
Posted on Jan 17, 2013
  • Elmer Tan Jan 20, 2013
    Thank you for your advice.
2 Suggested Answers
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
How do i set up dvd player
The newer players have an HDMI port on the back. If your AV receiver or television has an HDMI port, connect the player to the AV receiver or television using an HDMI cable, often sold separately. If it's conencted to your television, select the menu option on your television and under "source", choose the HDMI input. Turn on the player and you should see the DVD player logo if all is working properly.
Feb 19, 2015 | Televison & Video
No Sound on LG Super Blu-Ray Disc & HD DVD
Its something wrong in the cables connection try to reconnect them! And make sure that the connection is perfect according to manual then try it. It should work nicely. Moreove HDMI has great sound + picture effect.
Dec 13, 2007 | Televison & Video
No sound from AV receiver, sound only from TV
What brand/model is the receiver. Some have a function where you can select if the audio is passed through to the tv, or output from the receiver's speaker jacks.
Jul 14, 2013 | Televison & Video
How do I connect a sony BDP-s350 blue ray player to a onkyo tx-sr803 7.1 receiver with the hdmi cable?
Connect HDMI cable from the rear panel of the blu ray player to the DVD/IN digital section, labeled as "HDMI/IN" on the rear panel of the receiver.
Jan 01, 2010 | Onkyo TX-SR803 Receiver
How to connect Panasonic BD60 Blu-ray disc player to 2 components
If there are red and white RCA jacks on the back of the BR player and on the receiver you should be able to get sound. The same as your VHS.
Dec 29, 2009 | Panasonic DMP-BD60K Blu-ray/DVD Player
My new BluRay player has HDMI output for both sound and video. My Receiver, however, does not have the HDMI inputs. Can I use HDMI direct to TV, and use Optical connection to receiver for audio? Sony...
Yes, you can connect the HDMI Cable from the Blu-ray Player to the TV directly and then, connect the Digital Optical cable from the Blu-ray Player to the Receiver.
Oct 09, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Sony DVP-NS77H No outout
I had the same problem unitl I read the manual a little more carefully.
I found that ALL connections through my AV receiver had to be identical. I was using component connections with analog connections.
Since I switched to all HDMI connections (cable box to AV receiver, DVD to AV receiver and AV receiver to TV) all is fine.
Hope this helps.
Mar 16, 2008 | Televison & Video
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
No Audio
What port do you have the HDMI from you BD player into on the 510. If you have it on the DVD port then fiber optic will do you no good, the DVD HDMI only supports digital coax, the Video2 HDMI only accepts fiber optic, and there is an extra fiber optic for the Sat input. If your BD player does not have digital coax out, or if you dont want to buy another cable, just move the HDMI from DVD to Video2 on the 510. I am willing to bet you have the BD player plugged into the DVD HDMI port and the fiber optic cable from you BD player to the Video2 fiber input.
Dec 18, 2007 | Sony STR-DG510 Receiver
Yamaha RX-V673 7.2 Channel AV Receiver BONUS PAK w/ Two HDMI Cables Logo
94 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
