Please show diagram how to thread this sewing machine.
SOURCE: needle does not pick up bobbin thread on my 373
Are you certain that the needle is in correctly? If it opens at the front the flat side of the needle should be facing the back. If it opens on the left hand side then the flat part of the needle should be facing into the body of the machine. If top and bottom are threaded correctly and the needle is in properly and fully in position it should pick up. If it doesnt then you "could" have a timing fault.
SOURCE: Cannot get the bobbin thread to come up with the top thread
1. Make sure the needle is up in the machine all the way.
2. Make sure the flat side of the needle is facing the rear of the machine
3. Only turn the handwheel on the side of the machine towards you, never away from you.
4.Double check your threading of the top of the machine.
5. Also make sure your using the proper needle, your machine takes the most common needle on the market but some look like it and are shorter or longer and wont work properly. Also make sure your not buying needles for a singer serger.
SOURCE: I have an euro pro
CAll Euro-pro at 1-800-798-7395 and you can order one directly from them. Don't panic, just take a deep breath, it will probably cost about $35. but at least you will have the correct one.
Good luck and happy sewing
