Question about GE (PSS26MSRSS) Side by Side Refrigerator
Display error c1
    New Friend:
  • 15 Answers
THIS IS NORMALLY A DISHWASHER CODE FOR A LONG DRAIN
Posted on Jan 18, 2013
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
Xerox workcentre 5020/Dn c1 error
i have one xerox 5020 machine, there is display showing C1 error code in first tray and C3 error code in bypass tray .if open and close the machine will be idle and ready to cpoy. there is no paper pick up in both trays. please help to resolve the problem.
Dec 17, 2012 | Office Equipment & Supplies
My samsung inverter condition does not switch off error C1
Try:
Switch the unit off with the remote (power button) - "C1" appears on unit
Push "Auto Clean" button on remote
Unit should switch off
Nov 16, 2012 | Heating & Cooling
I have a problem with my Nokia C1
Hi, You can get the restriction code for a Nokia C1-01 from www.onlinegsmunlock.com/nokia-c1-01/rs7wp9/ at affordable cost.
UNLOCKING STEPS FOR NOKIA C1-01
1 - Switch on your Nokia C1-01 without any sim card.
2 - Don't bother as to what is displayed on your Nokia C1-01.
3 - Compose #pw+CODE+1#.
4 - The Nokia C1-01 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia C1-01 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
Oct 05, 2012 | Nokia C101 Cell Phone
What is error code C1? Also what causes the
The C1 error is displayed when the motor tries to pull more than 26 amps to run.
This indicates a problem with the motor or motor controller.
Overloading or excessive suds can also cause this error.
If you like to make a few more checks then the image below contains the instructions for entering the diagnostic test mode.
Its a short cycle that runs all of the components so the operation of each can be checked.
I hope this helps but an intermittent C1 error can be hard to pin down.
http://media.fotki.com/1_p,wbrrkqqwkwbqsdgxgtqsskgwtqkq,vi/kdkftbfkwxkfsqdgqsg/1/1303472/5961857/image5668img-or.jpg
From the service manual....
"C1 = Average current limit Or Instantaneous current limit.
If a status signal comes back from the motor controller that a current
limit has been breached, the unit will return to standby mode and
display either CA for average current limit trip or Cl for
instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of current
draw greater than 5.55 amps
at the motor windings.
Instantaneous current trip occurs if there is a spike of 26 amps
instantly at the motor windings.
This may signify problems with the drive motor, thermal protector, or
motor controller. Over-loading the unit may cause this problem."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
What is causing the drain pump to continue running
C1 - Partially Blocked Drain - This error will occur when dishwasher was unable to pump out water in less than 95 seconds. Check drain line for debris and blockage. If clear, check for a restricted drain valve in the pump. Check the pressure sensor for correct operation as it sounds like it may be defective and thinks that the machine is still full of water after it has emptied.
Oct 30, 2009 | Dishwashers
C1 code what does it mean on a clypso washer
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$^^
Mar 31, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Error code c1
Error code C1 indicates a problem with drive motor-thermal protector or the motor controller
may be due to overloading
Press( stop/cancel) to clear the display.
Hope this helps
Dec 23, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Getting error code c1
Hi
Error code C1 indicates problem with drive motor-thermal protector-or motor controller
Overloading may also cause the problem.
Hope this helps
Nov 24, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
C1 code
Jun 23, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
