Question about HP Color LaserJet 2600n Printer
Locating the fuser release lever on HP color laserjet 2600n
SOURCE: HP Color LaserJet 2600n
Called HP service today as I had a similar problem......and I was out of warranty....but they said this happens at times if dust get into the top of the printer and they have a recall on them because of that.....they are shipping me a repolacement....FREE of charge.
Posted on Dec 04, 2007
713printech
  • 32 Answers
SOURCE: HP color LaserJet 2600n stucked on Initialzing
Well we can check and see if the printer is able to run an engine test. This is how you can run this test;
  1. Turn the printer around so the back of the machine is facing you.
  2. Remove the Engine etest button acess door. This is located in the bottom center of the back.
  3. Push the botton once while the printer is on. The printer should print a page with colored horizontal lines.
If the printer is able to print this page there is a very good indication the problem revolves around the PCA formatter board.
The Firmware might be outdated and causing this problem. Worst case scenario the board might be faulty, in that case your better off buying a new machine, since the cost to replace the board will be higher than that to replace this machine.
Posted on Nov 19, 2008
  • 237 Answers
SOURCE: Sensor error, turn off then on
Check the level of your toner or TOP errors. If the problem persists, let me know
Posted on Nov 25, 2008
  • 199 Answers
SOURCE: Color printing (not black)is light on left side
you have to clean the scanner mirror . open the front cover and remove all the cartridge. you can see a 4 no's of rectangle box in which inside you can a mirrors.clean all the four mirrors.
Posted on Oct 20, 2009
Evildice
  • 222 Answers
SOURCE: HP 2600n - Maintenance of the transer roller sheet
You can clean it using piece of paper (not printed). time for replacement - your image is very ghostly and you cant get better image after cleaning lasser/scanner assy :)
Posted on Oct 27, 2009
HP 2600n Laserjet Ghosting. Prints multiple, faint repeats down the page. Changed all toner cartridges, still happening
Perform fuser cleaning procedure. If not helpful, replace the hot fuser roller. When worn out it collects toner and may lead to repetitive image.
Mar 09, 2017 | HP Color LaserJet 2600n Printer
Where is the fuser located
It is located in the top of the machine near the exit. There is a very good video on youtube which shows how to replace the maintenance kit which includes the fuser. The fuser part starts at about 3.5 min into the video. I googled HP Color LaserJet 2600n Printer Where is the fuser located and it was the first video listed. I hope this helps.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_45d8d6c78cd9f0b6
Dec 12, 2013 | HP Color LaserJet 2600n Printer
My HP Color LaserJet 2600n is printing with small black dots on the left side of the paper. The toner and ink was recently replaced. Is there a plausible reason for this? Thank you!
Could be toner build-up on the fuser sleeve. Pull out the fuser and check the rollers for spots.
Try running cleaning pages before replacing fuser.
Jul 28, 2011 | HP Color LaserJet 2600n Printer
We have a HP Laserjet 2600N. There is a jam in the fuser delivery section. Someone tried to clear the jam but left torn paper inside. How can I remove the jammed/torn paper? Is there a lever that will...
I'm sorry to inform you I referenced the removal of the fuser as it's simple for most machines. However on the 2600 it's buried inside. If you can pull it out the machine will have to opened up to remove the paper. The process includes 18 steps to get it out.
If you want the instuctions on how to remove I can upload them to scribd and provide you with a link. Other than that it would require a service call to a technician or your IT department.
Oct 20, 2010 | HP Color LaserJet 2600n Printer
Paper Jam
Not easy, thats the fuser, normally it is damaged and beyond it causing paper to jam there, no easy fix, cant pull it out without major screwdriver challange...I think thats this one... some fuser s(hot bit that paper exits), are pop out by green release tabs but if I have my models right these are the cheaper version and they fix them to the machine thus ensuring you upgrade..modern world..
Nov 05, 2009 | HP Color LaserJet 2600n Printer
The printer is requesting for a transfer fuser kit. What is a fuser kit and where is it located?
the fuser is the part that burns the toner to the paper and is located under the dark cover where the paper comes out.
Oct 21, 2009 | HP Color LaserJet 2600n Printer
HP 2600n
50.2 Fuser Error Turn off then on Description 50.2 Slow fuser error. The device has experienced an internal hardware error. Action
  1. Turn off the device, wait at least 25 minutes, and then turn on the device.
  2. If a surge protector is being used, remove it. Plug the device directly into the wall socket. Use the power switch to turn on the device.
if no result,
Fix this with a new FUSER Assembly for HP Colour Laserjet 2600/n (200/240v) Part Number: RM1-1821-240CN or Fusing Assembly – RM1-1820(110/120v )
Oct 05, 2009 | HP Color LaserJet 2600n Printer
2600N Printer has an output paper jam
open the back cover you will see a blue knob , just turn it ,jamming paper will coming out
Dec 08, 2008 | HP Color LaserJet 2600n Printer
Printer HP ColorLaserJet displays Fuser Error
My HP Color Laserjet 2600n Printer is giving me error as
" 50.2 Fuser error " . then every time i have to reatart my printer.
please give me suggestion.
thanks and regards.
ajinmumbai
Dec 05, 2007 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
135 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
