Question about Hotpoint Washing Machines
Hotpoint aquarius wmf760 washing machine drawer removal
Can you tell me how to remove the drawer to clean it?
5 Suggested Answers
  • 90 Answers
SOURCE: How to remove top panel and front facia on a Hotpoint Aquarius WDF451 washing machine
Un plug it. There should be small screws either at the bottom of the panel on the front or there is separate panel that comes off the top back. If the back is one solid piece top to bottom, then the control panel lifts out and hinges up when the two small cross tip screws are removed from the bottom outside corners of the control panel..
Posted on Feb 10, 2008
  • 57 Answers
SOURCE: how do i remove and replace rubber seal on door of
Remove the lid and loosen the band internally holding gasket to tub, from the top. The front come off easily once the retaining band is removed. Just reversed the process to put on the new rubber.
Posted on Dec 09, 2009
  • 104 Answers
SOURCE: Bra wire stuck between inner and outer drum how to
Depends where it is stuck. If near the very front you can sometimes get them by removing the door seal to gain a small access between drums. Other ways is remove the outlet pipe from the bottom of the drum or easiest and most probable area where it stuck is remove heating element. Provides a better view and bra wires normally get stuck on them.
Posted on Jan 28, 2010
barkencoa
  • 3463 Answers
SOURCE: How do I remove the drawer from my Hotpoint
Open the drawer, lift or push it upwards, and pull it out towards you.
You should now be able to clean it.
Please rate my solution.
Thankyou.
Posted on Jan 30, 2010
Testimonial: "thanks"
Problem with a hotpoint wmf760 aquarius + error code h20 coming up
You may have soap & grease in the pipe that leads to the pressure switch. Remove and flush through and/or replace. dry before refitting.
Thus constant high would give pump faults (thinks machine still contains water). Constant low may cause over filling. If you have a plug that suddenly moves, that can cause the above errors.
Jan 02, 2013 | Hotpoint Ultima WF860 Front Load Washer
Hi, my hotpoint Aquarius 1100 washer dryer keeps leaving the soap from washes in the drawer. Any ideas why? Thanks
Try removing the draw and cleaning it thoroughly i would recommend running a few hot washers with no powder through the machine too.
Thankswww.TalkAppliance.co.uk
Apr 24, 2012 | Hotpoint Washing Machines
How do i clean the soap powder dispenser drawer? Can it be removed?
There should be a clip in the middle of the top of drawer you press this down quite hard to see it ,this then allows tray to be removed easy for cleaning
Jan 01, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Why is the washing powder not washing away? insteard it stays in the drawer and clumps together.
It either needs to be thoroughly cleaned, or there is a blockage in the dispenser compartment.
Remove drawer and clean all parts, remove and poke with a piece of wire the little blue plastic piece, sometimes grey, this hopefully will solve the problem.
Mar 09, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
How do I remove the drawer from my Hotpoint aquarius WMF 540 to clean it??? x
Thankyou.
Jan 30, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Can I remove the detergent drawer in a hotpoint hvl241?
There should be a release tab in the dispenser, push down, pull out
if NOT
Remove the screws along the rear top of the washer,lift the top, remove.
Nov 08, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint aquarius leaking
If this is leaking as its filling check its clean and nothing in it you can also remove drawer, check dispeser hose...good luck
Oct 01, 2009 | Washing Machines
At 20 minutes the drawer leaks
have you removed the drawer and cleaned the soap drawer holder ? as these can be blocked and cause this fault
Sep 15, 2009 | Hotpoint Aquarius WD640 Front Load...
Water is leaking from soap dispenser only at beginning of cycle
Remove dispenser drawer, and check for soap blockage.
Locate and clean filter, check to see if there is one located behind bottom kick strip, if no filter there, then you will have to remove lower rear cover of washer, and locate and remove the large black hose on bottom of tub.
Remove filter and plastic ball,clean and replace.
Refit filter, ball and hose ,ensuring it is fitted correctly.
Test for leaks.
Plz ratev my solution.
Thanks.
Jan 14, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
290 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
