Question about HP Pavilion dv6000z Notebook
I need a cde of stopwah in assembly language for 8086 microprocessor................and code must b compiled on tasm software...........and output is displayde on 7th segment display.........................plz help me on modnay i will submit this..............................plzplzplz help me
  • tat4u
    tat4u May 11, 2010
    its not too clear what you want or why you want it but it sounds like a bios issue , verify this and we might get somewhere.
I have to tutor tasm.exe and i need sample programs with explanation
Write a program to find out the largest number from a
given unordered array of 8-bit numbers. Store the largest
number in largest variable.
52h, 23h, 56h, 45h, 9Ah, ABh
Aug 12, 2011 | Borland Turbo Assembler and Debugger 5.0...
Can you give an example of compiler using vb?
Dim parameters As New CompilerParameters() Dim results As CompilerResults parameters.GenerateExecutable = True parameters.OutputAssembly = Output results = icc.CompileAssemblyFromSource(parameters, SourceText)
The code above uses the CompilerParameters object to tell the compiler that you want to generate an executable file (as opposed to a DLL) and that you want to output the resulting assembly to disk. The call to CompileAssemblyFromSource is where your assembly gets compiled. This method takes your parameters object and the source code, which is a string. Once you compile your code you can check to see if there were any compilation errors. We use the return value from CompileAssemblyFromSource, which is a CompilerResults object. This object contains an errors collection, which contains any errors that occurred during the compile.
There are other options for compiling, such as compiling from a file. You can also batch compile, which means you can compile multiple files or sources at the same time. Additional information on these classes is available on MSDN Online:
Feb 17, 2011 | Microsoft Visual Basic 6.0 for PC
Tasm.exe, tlink.exe
TASM is Borland's Turbo Assembler. TLINK is Borland's link-editor, not only for the assembler but for C, C++,and other languages.
Aug 23, 2010 | Borland Turbo Assembler and Debugger 5.0...
Can anyone tell how run java program in cmd prompt???
You need to type:
If it's a program.class
java program
or of it's a program.jar
java -jar program.jar
Apr 03, 2009 | Sun Java Programming Language (cdj-275)
What is the difference between Java editor and Java software?
java editor is a text editor which probably understands java language synthax and can automatically call java to compile your code.
Java software is a program written in Java programming language which is interpreted/executed by JVM(JAva virtual machine) on a target computer.
Your question is a rough equivalent to : What is a difference between typewriter and a recipe book written in English language
Jan 21, 2009 | Microsoft Windows Vista Ultimate Edition
What is a compiler and ite story
A compiler takes code that you have writin, and 'compiles' it into machine language code ex.10010011, a language that your computer can understand and execute.
Jan 15, 2009 | Computers & Internet
About physical addressing
you should know assembly langauge better and from the segment register you can read the higher order bit and the lower order bits which is logical address from those you can calculate by combining them
Jul 18, 2008 | Intel Motherboard
Keil compiler
ya keil is a software which used for making hex file for microcontrollers and after that we insert this file to microcontroller by assembler .in keil you hv to use a c similar language.i am expert of embeeded system if u hv any further quiery then u can call me also at 9811613568
May 19, 2008 | Computers & Internet
How to make .exe
In order to make a .exe, you need to use a Programming Language (such as Visual Basic, C++, C, or any number of other ones). You then need a compiler for whatever programming language you are using. The compiler converts the code you write in the programming language into a .exe that you can run on your PC.
There are many tools for converting all sorts of languages into executable files that windows can run. What in particular are you attempting to do? And why do you need it specifically compiled into an ,exe file? Would a .cmd or .vbs script be sufficient as long as you can run it?
Apr 05, 2008 | InstallShield 10.5 Premier...
8086 microprocessor
Nov 23, 2007 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
