I have a kenmore washer (without belt) and today i noticed that it washes but it does not drain. I took the hoses off that connect to the pump but there is nothing blocking
  • 2 more comments
  • Anonymous Jan 30, 2009
    My washer is a front loader so I don't have a top lid to lift.
  • adaubon Jan 30, 2009
    Does the Front loader has one of those switch, if so where?
    Yes I also took the pump apart to see if there was any obvious damage. Saw nothing
  • simonzhang Mar 26, 2009
    I have a Kenmore 700 series washer. It washes but does not drain and spin
    President:
  • Washing Mach... Master
  • 2,651 Answers
Soundsas if oyou have a faulty lid switch, lift teh top up and down a few times and listen for the "clicking" sond of a switch being activated, if you donthearit yo need a new lid switch,hte unit will fill and wash with the door open, but when it comes to drain/spn the lid must be closed for safety reasons, and a bad switch will not allow spin/drain to occour.
Posted on Jan 25, 2009
  • Ron Coons
    Ron Coons Jan 30, 2009
    please post entire model number so i can research further. thanks
The washer started making a noise about a month ago, kind of like change rattling in the bottom of the machine. Today the machine leaked water all over the laundry room and down the hall. It didn't come...
sounds like the water pump, is leaking or the rubber hose from the drum to the pump. its very hard for money to get thru the filter holes, of the drum to the pump
Dec 19, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore front load he2 plus wont drain.
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Aug 05, 2009 | Kenmore HE2 Plus Front Load Washer
My kenmore series 80 washing machine won't drain water. We have checked the hose and that is clear, what should we check next?
Check the following.
2. Water Pump
Jun 25, 2009 | Kenmore Washing Machines
Kenmore 90 series washer does not drain
Check the following to address this issue.
2. Water Pump
Jun 21, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore washer fills during spin cycle and doesn't drain completely
HI, this is just a slight clog or faulty drain pump. check the following areas.
2. Water Pump
Jun 18, 2009 | Kenmore Washing Machines
My washer won't drain and continues on to the next cycle
If all checks out ok during the above suggested inspection, replace the control board or timer module.
Jun 17, 2009 | Kenmore Washing Machines
My Kenmore Series 80 top loader will not drain and begins the spin cycle then shuts down after a few spins depending on the water level. The machine can only be drained manually. There is no blockage of...
There are many issues that can lead to a no drain situation. check the following areas for faults.
Jun 13, 2009 | Kenmore 24032\24036 Top Load Washer
No drain or spin cycle
Check the following to address the issue--
2. Water Pump
Jun 03, 2009 | Kenmore 22422 Top Load Washer
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Washer Top Load Series 60 won't drain
The water pump is a belt-driven device actuated by a clutch. Your problem could be:
1. Stuck pulley - break it loose and WD-40 it
2. Broken belt - replace
3. Bad clutch - call repair or replace
There is almost nothing that can go wrong in the pump itself. It's probably one of these three.
Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
