Question about Philips Cineos HTS9800W System
Model 32pf9731D/10 red light flashes 6 times - Philips Cineos HTS9800W System
3 Suggested Answers
SOURCE: red light flashing 6 times
I found the above web site pretty helpful, too (AVForums), and have spent a couple of hours reading that thread.
Seems like the capacitators are often why the power won't come on. Also, some people mentioned that holding a blow dryer to your TV will make it come back on. According to the tech-savvy people that could mean that your "solder joins" are cracked. So when they're cold they'll contract and lost the connection,and when you heat them up, they expand and reconnect where they are supposed to. I'm not tech savvy and this doesn't explain much to me, but it's interesting, and I'm sure somebody will go "aaah, I see...."
I'll quote a post from AVForums:
"The main components that wear out are the capacitors which, with aminimum amount of electronics knowledge and a suitable soldering iron(you need one with a tiny point, preferably a butane gas powered one)and a powerful magnifying glass. This must be self supporting or onethat hangs from a neck cord.
The capacitors and any other parts you need can be purchased very, verycheaply from rswww.com and they offer a free delivery service or, foran extra fee, a next day service!
When you remove the back panel from the TV, you will see a few circuitboards and you need to locate the one for the power supply.
On mine it is really obvious as it is situated at the top just left ofmiddle. They all have numbers printed on the circuit board. Mine are2662 (25V 1000 uF) 2663 and 2664 (both 50V 100uF)
The ones originally fitted are '85 deg C' but it is best to replacethem with ones that are '105 deg C' because they will last longer.
These '85 deg C caps' normally have a guaranteed life of of 1000 hours,whereas the '105 deg C' ones have a guaranteed life of 2000 hours!
This being the case, when Philips build the sets they know that theywill probably break down after a minimum of 1000 hours of use. If wesuppose that the caps last for twice their minimum life span (2000hours) and the TV is switched on for an average of 5 hours per day overthe year one, ore more, of them will probably fail in the secondquarter of the second year.
With this knowledge, for high cost items such as this, you would alwaysbe wise to take out an extended warranty and Philips, or any othermanufacturer, should be obliged to include an information card warningconsumers of this fact!
The Aluminium Electrolytic - Radial capacitors in question are,usually, 2 x 100uF. The voltage, I believe, depends on the screen size.My 42" screen requires 50V whereas the 32" version uses 25V caps.
There is also a larger 1000uF capacitor, of a similar type, that willbe sighted close to the other two. This seems to be 25V, whatever thescreen size!
The only thing you must remember when replacing these caps is that thelonger leg on the capacitor is 'Positive' and the shorter one is'Negative' and you must ensure that you do not damage the circuit track!
If you are careful and have a steady hand it is quite an easy job butif you are not too sure, you will probably be able to find a localrepairer that is able do the job.
However, you have to beware of the Companies that offer a service wherethey come and collect the tv for a set fee, usually just under £100!They then work out the cost of the repairs and, if you give them the goahead, they deduct the amount paid from the overall repair cost.
I have looked into many of these and, even if you agree to the repairestimate, usually in the region of £300, they never seem willing toguarantee the repair for longer than three months, six months at thevery most!
When you consider that these components cost a matter of pence you can see the value of trying to repair it yourself."
Posted on Jan 27, 2009
SOURCE: 42PFL5332D/37 does not turn on red light flashes 6 times.
Don't have a "solution" yet, but found this table that decodes the blinks:
Error Code Table
0 = No error
1 = X-ray protection, E/W protection, and/or Vertical protection active
2 = High beam current protection active
3 = Reserved
4 = +5V protection active
5 = Signal Processor (IC 7150) register corrupted
6 = Signal Processor (IC 7150) error
7 = Total failure
8 = Internal RAM error (Microprocessor IC 7000)
10 = NV memory (IC7088) addressing error
11 = NV memory (IC7088) size error
12 = Histogram (YUV) (IC 7770) error
14 = Sound processor I²C error (TDA9855)
16 = Main Tuner I²C error (IC 1125)
17 = PIP Processor I²C error (IC 7350)
18 = PIP Tuner I²C error (IC 1127)
I, too, have the 6 blinks of a red light. I found another person online that suggested that perhaps the power cord was "defective" as it's a common issue. I replaced the power cord with one from an old computer (they're the same cord) and it seems to be OK now. That's all I can offer you at this time.
Posted on Jan 24, 2010
Testimonial: "Thank you for your help, I will give it a shot!"
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
RED Light Flashs 10 times
I will need the model number of your set in order to properly assist you with the issue
Mar 16, 2012 | Panasonic Televison & Video
Sony LCD Model KF-60WE610 lamp was replaced and then it shortly after stopped turning on. Blinks Green 6 times then Red 6 times Please help!
For Sony Model KF-60WE610, KF-50WE610, and KF-42WE610, the Diagnostic Code of power light indicator flashing 6 times green, then flashing 6 times red (6 red etc), means you need to replace part number A-1302-272A G1 BOARD, COMPLETE. See Sony Service Manual, 4. Chasis-1 at part Ref no. 103. The Power Board sits vertically in two slots on the left side of the electronics board. 4 wire connectors to remove when replacing. This component fits all 3 KF models listed above.
Jun 22, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
I have a Philips 50" Flat HDTV model 50PF9431D/37. Problem with screen turning on. I get sound. I get 9 quick flashes in red. Then after unplugging and plugging back in several times. It then blinks...
I have the exact same problem! I have it hooked up to a power strip now to unplug it by flicking of the power strip and waiting for the red light to go out then I turn it back on while Channeling up 10 X's and then down and up until it comes on. I listen to the sound of the switch which it comes on. I turn it off if it is faint and then back on and channel up. Crazy process but it's been working. It takes about 10 minutes everytime to get the TV on until I get a tech to come out and look at it. The capacitor keeps a charge which is why the light is flashing with a code for 60 seconds./JJ
Aug 29, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips Cineos HTS9800W System Logo
37 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
