Question about Canon Irc3220 Color Copier, Network Printer & Scan
Heats up forever - Canon Irc3220 Color Copier, Network Printer & Scan
Temperature gauge is going up and down as i stop and go
Dec 15, 2012 | 1998 Ford Taurus
Dryer heats but takes forever to dry the clothes, sometimes over two hours
sounds like your exhaust is either clogged or has a kink in the hose.
Mar 26, 2012 | Dryers
The dryer is heating up but takes forever to dry clothes
first things first, check the vent. if the unit isnt vented properly or vent hose isn't clear, it will take forever to dry. if the vent is clear, check the vent thermostat.
Mar 21, 2011 | Dryers
The timer does not work correctly. The timer does not move and the dryer runs forever.
If the timer doesnt even advance in the time dry cycle then you have a bad timer. However you will need to make sure that your getting heat throughout the auto dry cycle because no heat will cause the dryer to run forever. Hope this helps _MJ_
Aug 17, 2010 | Kenmore Dryers
Kenmore sreies 80 gas dryer, doesnt heat well'
replace the ignitor or the gas selinoids
Apr 20, 2010 | Kenmore 72802 Gas Dryer
No heat
your blower motor resistor needs to be replaced if you only have one speed its a small inexpensive part runs about 15 dollars easy to replace.
Jan 17, 2010 | 2000 Oldsmobile Silhouette
Oven takes FOREVER to pre-heat
You probably have a bad heating element. Trip the breaker and make sure that all power is removed from the stove/oven. Remove the element, and test it for continuity. If it tests open, obtain a replacement from an appliance parts supply house. If it tests good, you should suspect either a bad switch or thermostat.
Regards, --W/D--
Jul 20, 2009 | GE Spectra JGBP35 Gas Kitchen Range
1994 S-10 pick up takes forever to heat up.
Could be the thermostat but also heating core partially corroded or plugged slowing down circulation.
Nov 18, 2008 | 1999 Chevrolet S-10 Pickup
Roper dryer, timer doesn't time out and not heating up?
Dryer will run forever if it doesnt heat up, Dryer has to heat up and thermostat has to get hot and open to start the timer. Odds are rally great, it is your heating element.
Oct 01, 2008 | Roper REX4634KQ Electric Dryer
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Canon Irc3220 Color Copier, Network Printer & Scan Logo
29 people viewed this question
Top Canon Computers & Internet Experts
Aashish Chaudhary
Aashish Chaudhary
Computer Links
Tony
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
