Question about Husqvarna Viking PC Main Board for Viking Designer 1 USB, Designer 1
MAIN BOARD BLOWN NEED WIRING DIAGRAM TO REPAIR
Where is fuse located...part #3601-001197
The part number you provided is invalid--Samsung parts start with DD such as the main board is listed. The main board part number is DD92-00033B. There is no fuse--I've scoured the exploded diagram and parts list--there is a leakage sensor located at the bottom of the unit, directly in the center of the bottom frame. If water is detected, the sensor tells the main board to shut down. The main board is located behind a cover at the base of the dishwasher below the door. You will have to remove the kick panel to access it. WARNING--that main board cover can be tricky to put back on. It's metal, has a relatively sharp edge, and if installed improperly, will cut into the wiring harness--and that will be a BIG oops! Make darn sure you route the wiring harness properly so the cover fits properly without pinching anything(ask me how I know this--and I'm a tech--it can happen to the most experienced person). BTW, did you have a power outage recently? Maybe 3-4 weeks prior to the problem. Outages are notorious for damaging circuit boards. If your unit is totally dead, you might have a blown main board--that's why I gave you the part number. The user interface board(touch panel) is DD92-00037A. The display board is DD92-00038A. I hope I helped you!
Sep 12, 2015 | Samsung DW80F800UWS 24" Stainless Steel...
Which components do I need to check following a voltage surge (lightning) on Hitachi colour TV CL32WF810AN.
If the main fuse should blow up; surely there should be a short circuit to any component/s at it. If the secondary [DC] fuse also has blown up, there should be a reason for it too.
You should first check out the main power board alone, and then the secondary board connected. It will be impossible to follow these without its schematic diagram. Try to download it by internet. Without proper guidance; how can we follow the complicated circuits, and check the components?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 06, 2014 | Televison & Video
Looking for a wiring schematic for a ge dide by side gsl25jfphbs no power ro evap fan motor
The problem you are having is most likely a defective=> WR55X10473 Main Control Board. The defective WR55X10473 Main Control Board may have been caused by a defective=> WR60X10185 Evaporator Fan Motor. If your motor has a white thermistor in the connector you need the related fan motor WR60X10074. If it has a connector for a light you will need a=> WR23X10467 Fan Motor Reason I am telling you this is because if the fan is defective it can again damage the Main Control Board. The same wiring diagram is found=> HERE or HERE by clicking on the wiring diagram. Listen to this video because it explains what I am trying to say. GE Refrigerator Fan Motor Diagnostics If you would like I can walk you through the diagnostic's to see what is going on. I am here should you have questions, Thanks John Tripp Appliance 911
May 17, 2014 | GE Refrigerators
I need a wiring diagram for an indesit front loader model no IWD7105B
if there is power to the main board but nothing out of it its huighly possible it needs a new main board.
Apr 10, 2014 | Washing Machines
EPIC TL 2200 wont start
1) Test the fuse or c. breaker see the diagram attached.
2) Test the c. breaker from your hourse, or blown fuse
3) Test the main switch of the treadmill see how to do it
4) Test the voltage input motor, if there are voltage the motor need repair.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Jun 08, 2012 | Epic Exercise & Fitness
I need a wiring diagram for my Hewitt package computer
What do u need to do? A wiring diagram will not be needed unless you are replacing components on the main board, this will require advance electronics knowledge and experience. If it IS just a hard disk or CD-ROM, maybe even memory CPU or psu replacements, a wiring diagram is not needed, just knowledge. If u don't understand any of the above, DO NOT EVEN ATTEMPT MAINTENANCE
Nov 04, 2011 | HP Computers & Internet
My Westiinghouse Silhouette Series 2 Frost Free 303 Freezer (Model No. FJ303F) appears to have blown a fan. My electrician is wanting a wiring a wiring diagram to facilitate repair.
what you need to do is get rid of the electrician, and get a refrigeration service man and he wont need the wiring diagram.
Feb 22, 2011 | Freezers
Mine has 7 red blinks and wont come on. i pulled off the back and found a fuse blown on left circuit board, i can unplug the left circuit board from main circuit board thats in middle and tv will act like...
No, your done. Now replace the Y-Main, that's the large one you found the fuse blown on and replace the two buffer boards that the Y plugs into. Those are the two at the far left. The part numbers are on the boards. So that's 3 boards you will need. sometimes they sell the buffers together as a pair which is cheaper. DO NOT buy from second hand resellers. Always buy new when it comes to plasma sets.
Nov 30, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
GE GSS25SGMBS Side by Side Refrigerator
I don't have real specific info, but it looks like pins 2 (red) to pin 3 (black, common) should be 13 VDC (constant, not pulsed DC as in LG models) pin 1 (tan) is a transmit / receive and pins 4 (violet) and 5 (white) are dispenser board output to main board input. They don't really tell me which does what. Looks like there is a water relay (K6) on the main board. You did make sure the dispenser is not in the locked setting, right? (locked would give no dispenser functions, including ice dispense)
Nov 29, 2008 | Refrigerators
Husqvarna Viking PC Main Board for Viking Designer 1 USB, Designer 1 Logo
55 people viewed this question
Top Husqvarna Viking Computers & Internet Experts
Stan Skaggs
Stan Skaggs
Tom Chichester
Ravi
Are you a Husqvarna Viking Computer and Internet Expert? Answer questions, earn points and help others
