I need a cheap working binding machine - Office Equipment & Supplies
  • 4 Answers
The best priced binding machines are the thermal binding machines.
If you want to be able to bind up to 600 pages the only cheap solution is the helios 60. At $119.99 from Thermobind it can bind up to 600 pages into a proffesional book, report or whatever.
However, if you would prefer a different binder see the guide to thermal binding.
Posted on Apr 03, 2013
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 51 Answers
I don't know about working but you can find cheap used ones on eBay: http://www.ebay.com/sch/Binding-Machines-/61756/i.html
Posted on Jan 17, 2013
I made my first quilt how do i finish the sides
You will want to bind your quilt. Go to YouTube and search for "bind a quilt" or something similar and watch the video tutorials. There are several ways of binding a quilt, so you'll need to decide which method you want to use.
youtube bind quilt Google Search
Nov 08, 2015 | Sewing Machines
Why is it that the toner in my photocopied documents does not dry? ....machine model Nashuatec Aficio Dsm415pf
The fuser is bad. There is a heater in the unit that cases the toner to bind to the paper. It is called the fuser. THEY ARE NOT CHEAP
Jun 13, 2014 | Office Equipment & Supplies
How big is a binding machine?
Binding machines' dimensions can vary a lot according to its function. There are smaller ones for the binding of single small books, and are about a meter long, and there are much bigger ones, that can bind 50 books at a time.
Oct 03, 2013 | Office Equipment & Supplies
What is a binding machine?
"A binding machine binds a stack of papers into a book or booklet. There are many kinds of binding machines, from those that use a spiral binding like a notebook to those that use glue like a hardcover book" (wiki.answers.com)
What is a coil binding machine?
Coil binding is like a slinky, twirling and binding your punched sheets into a book.
An Electric coil inserter speedily binds books up to about 150 sheets
Jan 28, 2013 | Office Equipment & Supplies
What types of binding machines are there?
There are 3 main types: comb binding machine, coil binding machine or wire binding machine
Bernina Binding Foot
check on youtube for a video
Aug 20, 2012 | Bernina Sewing Machines
Had new lower ball joints installed and front end aligned on 02 Trailblazer 2wd. Steering is stiff now and wheel will not self center. What could be problem?
often I find on these vehicles a cheap "new" ball joint will bind
additionally, if the tech did not torque the ball joints to spec this too will cause a bind
both will cause stiff steering and no return
take it back to where the work was done and have them fix it CORRECTLY!
Apr 25, 2010 | 2002 Chevrolet TrailBlazer
DC440st
This problem can be a bad main motor. The motor has gears on it and they can bind when they are worn. The motor assembly itself electrically can be bad.
If there is something binding in the gear train assembly this can cause the motor not to turn. A bound up copy cartridge can cause the motor not to turn.
A bad board can also cause this not to start.
To replace the main motor, it is very detailed and time consuming.
Try a service call, hope it is cheap enough and the copier is in good shape besides the motor being bad.
Dec 30, 2009 | Xerox DC440ST Copier
JUKI MO-634D trouble
Well, you might just need a good oiling. Make sure the machine is not threaded and there are no thread snarls where the loopers interact. It also pays to insert new needles and observe the loopers and needles interact. they should come withn .01-.5mm of touching eachother; there should be no hard positive contact between loopers and needles. So, if its tight to turn over by had, this is usually a cam or bushing that need oiling, or thread that got sucked into the machine and is binding the thing up. What I would do is remove the covers, slip the motor belt off, turn over by hand. If it frees up, the bind is in the motor, if its still tight, then id look for thread, and oil the machine with a light weight oil (sew mach oil, tri-flow... NOT 3in1 oil!). If you have a keen eye, you can wiggle the handwheel and try to observe what parts are moving slightly, and which are not. using that method you may be able to track the bind to a section of the machine or even a specific shaft/cam/component of the machine. Another common bind point in sergers is where the knives mate. Move the top knife to its idle (non cuttin) position and see if this relieves the bind.
Jun 27, 2008 | Juki MO-644D Mechanical Sewing Machine
695 people viewed this question
jasbo
jasbo
