Question about Sony Cell Phones
Sony Xperia J Touch Screen problem
Here Sony Xperia J touch screen was not working properly, please help me friends.
5 Suggested Answers
SOURCE: Touch screen not working properly
you can do it by running setup wizard, located in control panel->others-> setup wizard and follow instructions till you will be asked to tap on blinking points.
Posted on Nov 21, 2007
homedesigner
  • 583 Answers
SOURCE: My samsung Tocco F480 touch screen has frozen.
If you haven't already tried this, turn off the unit, remove the battery for several minutes. This should reset the device and correct the issue. If it doesn't, then it will need service.
Posted on Mar 05, 2010
  • 34 Answers
SOURCE: sony ericsson M600i touch screen not working,not calibrating
it can be touch pad problem.
Posted on Jun 21, 2009
guru_fixya
  • 944 Answers
SOURCE: my satio touch screen is
The replacement of the touch screen is very simple.The cost of touch screen is £28.99.Have you calibrated your phone?
The steps to recalibrate is quite simple
Go to control panel menu-Setup wizard
tap 'YES' before cancel appears.Do this until you see 1,2,3,4
numbers blinking...
If still your problem is not solved this will be caused because of two reasons
1)Touch screen- will not work only when you drop it or Liquid in it is damaged.
2)Touch screen sensor
2)Keypad IC.
Touch screen sensor or keypad IC cost is very less you can replace it or solder it if it is loose.If you don't have hands on in it please don't try it you can take it to nearest service center.
The replacement of Touch screen is quiet simple.
The replacement can be done.follow the steps.
1)remove the battery and Sim card.
2)You can find screws now.so open the back and front panel
3)Be careful the LCD and the flex is being joint.so care fully remove it see how the flex is joint with the motherboard.there will be thin film like connection between the two.
4)Take the LCD you bought..In the image you can see gold type film that is flex.you have to place it perfectly.That's it
5)Close the phone.and now enjoy working with it.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Posted on Aug 01, 2010
Touch Screen on Sony phone not working
Maybe its a hardware failure, the Touchscreen or the Digitizer must be replaced. Send your phone to the nearest Sony Xperia Service Center for repair.
Mar 27, 2015 | Sony Xperia Z2
Touch Screen
It seems to be a hardware problem. However, you could try restoring your system, or installing a ROM.
It's quite weird that your screen stops working properly because of the charger. Good luck.
Dec 18, 2013 | Sony Xperia Tipo Dual ST21i2 Black Android...
Try to enter the following characters into the dialler: *#*#7378423#*#*
There you can test a fuctionality of the touch screen. If it's defective you have to change it. (In Sony service center they can do a touch calibration sometimes it helps)
Oct 14, 2013 | Sony Ericsson SONY XPERIA U ST25i...
How to replace screen on sony xperia miro
Sony xperia Micro is touch pad type phone, and screws are very small, remove beckside cover and open nut on screen. before adding new screen you must sure connection between screen and board are proper. otherwise you may go to any mobile repairing store and make this issue fix.
Jul 24, 2013 | Cell Phones
I have xperia j.. it needs a hard touch even after updating to jelly bean version 4.1.2
For touch problems you can try to do touch panel calibration:
http://talk.sonymobile.com/t5/Xperia-J/Touch-screen-issue-in-Sony-Xperia-J/td-p/287066
Apr 13, 2013 | Sony Xperia J ST26I Touch Screen with...
Touch screen problem
If you're still having touch-screen problems with your Tipo, you might need the screen calibration patch.
Download this file:
http://www.4shared.com/rar/3p6YulVl/ST21i_calibrate.html
The file is the official screen calibration patch from Sony for issues with the touchscreen of the 2012 range phones (I'm 100% sure it works on: Tipo, Tipo Dual, Miro and Xperia J)
Dec 20, 2012 | Sony ST21i Xperia Tipo Black
After upgrading my xperia x10 mini to 2.1 my phone is logged. if i touch the lock on the screen it moves to the right and nothing else happens. Please help!
do this may friend:
1- download a android update 2.1 or 2.2
2- update your phone offline with the update.
if it doesn't work:
flash your phone in a phone servicing shop.
please vote.
Jan 11, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Sending Message Problem!!
touch the START menu on the top left of your screen, touch on MESSAGING, select SMS/MMS account by touching, that will take you to your inbox. then just touch the MENU on bottom right of screen and select NEW... then touch SMS. It will ask you to add contact 1st. then touch screen where text goes till curser appears then type either by keyboard buttons or middle bottom of screen if you touch a electronic version of keyboard will appear you can use stylis to type on screen keyboard. Then bottom left of screen hit SEND. message sent message will come on screen when msg sent.... Goodluck
Apr 10, 2009 | Sony Ericsson XPERIA X1 Smartphone
Cell Phones Logo
1,922 people viewed this question
Top Sony Cell Phones Experts
M_Butkus
john h
Eric Sutherland
Are you a Sony Cell Phone Expert? Answer questions, earn points and help others
