Question about InFocus Proxima Model Dp 6150 Computer Home Theater Projector 56 Hours Used
Hi I have a proxima DP 6155 that will turn on, display the start up image, and then it shuts off. If I press the power button again right away it will flash a distorted image that I can't make out
5 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: proxima ultralight x350 runs fine for few minutes,
lamp is on it's way out. proxima no longer carries the lamp, but try to find it online. part # sp-lamp-027
Posted on Sep 16, 2009
  • 74 Answers
SOURCE: Image looks doble in colors.Gren,Blue Red
Depending on how severe it is, it can be fixed. I can do the repair if you'd like.
Posted on Apr 15, 2010
  • 74 Answers
SOURCE: Hi. The projector does not display images on
If your using a laptop, you need to make sure your computer port if activated. If that doesn't work, then you'll need to try another cable.
Posted on Apr 21, 2010
SOURCE: Projector will not display image and will not turn
samsung 1
Posted on Jun 21, 2010
System is frozen. Wont shut down or go to start screen.
Here are two things to try:
I- Using the Power button:
1 Press and hold the Power button for at least 4 seconds.
2 Swipe-down the shutdown confirmation screen to the bottom
edge of the display to turn off the tablet.
Using Charms:
1 Swipe-in from the right edge of the display to access Charms.
2 Touch Settings
Turning Off the Screen
Press the Power button to turn off the screen.
Using Charms:
2 Touch Settings
NOTE: If your tablet is in a standby state (tablet is on, but screen is off), press the Power button or Windows button once to turn on the screen.
12
Setting Up Your Tablet
? Power
? Shut down to turn off the tablet.
II- Unplug the battery, wait 30 seconds, then install the battery again.
Sep 04, 2015 | Dell Venue 8 Pro Tablet Computer
Hoover bagged wind tunnel 2 vacuum turns its self off after about 10 min. of normal vacuuming I can press the power button right away and the vacuum will turn back on and vacuum for sometime as long as 5...
There is a thermal sensor in the motor which shuts power off if it gets too hot but usually it won't turn back on until it cools down. It seems you might have a defective switch
Oct 06, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
Acer Aspire 7720-6155 wont boot
put cd in dvd writer then open the laptop and press f8 and after that if lap asked for esc/ or for enter press esc then it will work .
Sep 12, 2013 | Acer ASPIRE 7720-6155 LAPTOP LCD SCREEN...
Hello., I've just tried to power up a Proxima 9310., and for the first time in my experience the orange light has come on and shut down has effected after a couple of seconds. I would like to ask for...
hi,
Time to replace the lamp of you projector.Lighting up of the orange light indicates that. All the projectors comes with self disorganizing program. if there is any complaint except power supply that will indicated by the projector by its self disorganizing system.
switch OFF the projector for some time. then power it ON. if picture come then first of all reset the lamp hour timer. To do the same do the follwing
1. Press the menu button and press rear click button or select button
2. Select settings press the rear click or select button
3. On setting display select Lamp age and press the rear click or select button
4. Move the arrow to Yes and press the rear click select button
OK will displayed and wait for your conformation
5. Move the arrow to Yes and press the rear click or select button
if there is no picture when you switch on the projector then go for a new lamp. you hve to do the reset procedure after replacing the lamp. It is always recommended the you should reset the lamp hour only after replacing the lamp.
ok
Apr 04, 2011 | InFocus Proxima Pro AV 9310 Multimedia...
Hi,I have a Proxima desktop projector that I have
right click on your desk top and check the display settings.
May 15, 2010 | Office Equipment & Supplies
How can i watch video from Samsung s1050 in my computer?
Hi, Here is the procedure on how to play the video clip on your camera. Play mode If you have turned on the camera by pressing the POWER button, you can press the PLAY MODE button once to switch to Play mode and press it again to switch to Recording mode. You can turn the power on with the play mode button. The camera is turned on in play mode. Press the play mode button again and the camera will be turned off. You can set up the PLAY mode function by using the camera buttons and LCD
monitor. Playing back a still image
1. Select the PLAY mode by pressing the play mode button.
2. The last image stored on the memory is displayed on the LCD monitor.
3. Select the recorded movie clip and press the Play & Pause button to play back.
- To pause a movie clip file while playing it back, press the play & pause button again. ac0dd93.png
- Pressing the play & pause button again will cause the movie clip file restart.
- To rewind the movie clip while it is playing, press the LEFT button. To fast forward the movie clip, press the RIGHT button.
- To stop playback of the movie clip, press the play & pause button, and then press the LEFT or RIGHT button. 0e83d9c.png
Apr 13, 2010 | Samsung S1050 Digital Camera
Camera turns on, and then turns off again right away
My M1033 had the same problem...I found a blog about someone using air to clean around the lens area...I cleaned my lens very thoroughly and noticed some gunk and once I cleaned this off, the camera seems to work like new!
Apr 05, 2010 | Kodak EasyShare M1033 Digital Camera
Mar 10, 2010 | InFocus Proxima DP6155 Multimedia...
Dp-1820e rebooting not starting
you may try this:
unplug the network, usb, and fax connection
remove all papers
turn on the machine
press print key
press stop
press 1 for yes to cancel the job (if theres a job queue)
Mar 31, 2008 | Panasonic Workio DP-150PA Copier
Need Drivers
Hi Jess
Is your PC's image splitt ?
Right click on your desktop and go to properties - then click on settings and then advanced settings.
You'll see a block with two screens on it. If only one is activated - activate the secondary screen as well.
If you are using a Notebook also try holding in the Fn ( Function ) button - just left of your spacebar and in your F-row buttons at the top there should be one with two screens on it - Differs from brand to brand of PC's.
Hope this helps you !
Mar 26, 2008 | ASK Proxima Proxima DP2000S Data Video...
InFocus Proxima Model Dp 6150 Computer Home Theater Projector 56 Hours Used Logo
22 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
