Question about Photography
Where can I find quality storage boxes for my slides?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 51 Answers
Here's a great online store specializing in photography slides: http://www.universityproducts.com/cart.php?m=product_list&c=1261
Posted on Jan 17, 2013
Mattress sliding under headboard
There are a couple of things you can do:
http://www.homedepot.com/p/American-Slide-Stop-All-Surface-8-ft-x-10-ft-Thin-Profile-Fiber-Rubber-Backed-Non-Slip-Rug-Pad-HD040810F/203173560
The other thing is to get 3 or 4 tubes of silicon caulking and lay a bead down on the box spring in a continuous pattern and then use something to spread it out like you would spread peanut butter. Wait for it to dry and then put the mattress back on.
Feb 06, 2014 | Liberty Furniture Avalon Storage Panel...
Poor quality conversion from slides to digital
Specify the format : .JPG or whatever it is.. please try to be specific.. SD Card is not a format.. its a storage media..slides as well is not a format.. its a terms..
Dec 19, 2013 | Wolverine Data F2D200 Film Scanner (35 mm)
I want to reinstall a oven storage drawer on a electric LG oven
I don't think you need to remove a slide rail. They should slide out by hand and then set drawer back into it. usually have to tile drawer up some to start.
Nov 06, 2013 | Kitchen Ranges
What is slide storage?
Slide Sotages are actually storage systems for large quantities of slides.
Jan 17, 2013 | Photography
Where is the tire lock kept on the 2002 RX 300
If you are referring to the mag wheel puzzle lock, storage is an optional location. The RX300 has a number of storage pockets, so check the spare tire area and tool kit, then the rear storage side pockets, glove box, console sliding drawer at bottom of console and your map pockets on the doors. If the puzzle key is missing , go to the dealership. They will have a matching master set and can order a replacement after identifying yours.
Nov 01, 2009 | 2002 Lexus RX 300
I cant find the cd player in my 2001 vw beetle
hello, you can find it inside your rear bonnet, it's called cd changer which look like a tool box. move/slide the upper cover and pull up the cd storage. ok.
Aug 14, 2009 | 2001 Volkswagen Beetle
Sunroof doesn"t open or close
Section 01-17: Roof Panel, Sliding—Electric 1996 Taurus, Sable Workshop Manual DESCRIPTION AND OPERATION Electric Operation The sliding roof panel (502B98):
  • is available as an option.
  • is electrically operated through the accessory delay relay (controlled by generic electronic module (GEM)).
  • is of self-storing design.
  • requires a specific headliner.
  • utilizes a unique roof console and dome lamp.
  • has an air deflector.
The electrical system operates in the following manner:
  • Two switches control movement of the roof panel.
  • When the SLIDE roof sliding panel switch (15B691) is rocked rearward, the roof sliding outer glass panel (502A82) slides into the storage space between the roof trim panel (51968) and the roof panel, exposing an opening over the front seats.
  • When the SLIDE roof sliding panel switch is rocked forward with the roof sliding outer glass panel fully back in the storage space, the roof sliding outer glass panel moves forward from the storage position.
  • The rear portion of the roof sliding outer glass panel moves upward on two lifter arms near the end of the forward travel, allowing a weather-tight seal when the roof sliding outer glass panel is closed.
  • An AUTO feature allows the SLIDE roof sliding panel switch to be touched momentarily to cause the roof panel to automatically move to the fully open position.
  • When the TILT roof sliding panel switch is rocked forward with the roof sliding outer glass panel fully forward, the rear of the roof sliding outer glass panel pops up to the VENT position.
  • With the roof sliding outer glass panel in the VENT position, rocking the TILT roof sliding panel switch rearward closes the roof sliding outer glass panel.
  • Sliding Roof Panel Does Not Open or Close
  • Open power feed fuse.
  • Circuitry open/shorted.
  • Damaged roof sliding panel switch.
  • Damaged sliding roof panel motor.
VISUAL INSPECTION CHART Mechanical Electrical
  • Damaged roof panel
  • Obstructed roof panel
  • Guide
  • Damaged drive cable(s)
  • Open Power Distribution Box Fuses 1 (40A) or 4 (30A)
Apr 19, 2009 | 1996 Ford Taurus
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
E-mailing photos
JPEG format storage is ideal for posting your photos to the Internet and for e-mailing them to friends. (It’s also useful for archiving when you've finished editing them and need to save storage space.) The compressed images still look good on-screen and contain a relatively large amount of information in the shrunken file. JPEG storage is great for maximizing space but not for maintaining image quality. If you want to get smaller files for archiving, use minimal JPEG compression (high quality/low compression). The ideal compression is lossless, which means there's no discernible drop in image quality even though the file size has decreased.
Sep 08, 2005 | HP Photosmart 120 Digital Camera
Photography Logo
559 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
