Question about Refrigerators
I have a fisher and paykel refrigerator rf610a with error f24
5 Suggested Answers
SOURCE: Fisher and Paykel model RF610
The F24 error show that the sensor in the ice maker is out of normal ranges. The usual fix is to replace the sensor in the ice maker.  Also worth checking it to see is the water to the ice maker has frozen up in the value (switch the fridge off for a day). If the error still exists after that you will need to replace the ice maker sensor. You have a 2 year warranty on these parts so the fix should be free.
Posted on Mar 24, 2009
sonicboomele
  • 1557 Answers
SOURCE: fisher paykel e522bre active smart refrigerator
you need to have the defrost element replaced !!
Posted on May 15, 2010
SOURCE: fisher & paykel refrigerator n325t freezing up
how long it takes to form the ice in a frost free (fisher & Paykle) refregerator ?
Posted on Nov 14, 2010
ginko
  • 19396 Answers
SOURCE: Error code F20 on RF610A
Hi.
F20 means that there is a problem with the defrost system. The temperature sensor and the element comprised in the defrost system must be tested. Testing is done removing the firewall panel (usually in the freezer compartment in F&P) and accessing the parts. Parts are tested reading impedance with a multimeter. The test will determine if element is open or if the temperature sensor is open at room temperature to find out if any of the two parts must be replaced. Voltage to element must also be tested.
Try performing a manual defrost. Remove all food and disconnect the fridge overnight. If the problem does not come back, then the fault was probably a temporary malfunction. If the defrost system is faulty the problem may come back after a couple of days, when the defrost system restart malfunctioning. In that case ring the F&P number listed on the owners manual to call a technician.
Regards.
Ginko
Posted on May 09, 2011
How do you get to the fan in a rf610a. coming up with a f13 fault
The low ambient heater is drawing less current than expected. Either the heater or wiring is open circuit or the heater is faulty.
  1. Check the wiring and connections at both heater and power module
  2. Check the low ambient heater resistance. If not within limits replace.
As for the fan,
1. Disconnect the refrigerator from the power supply.
2. Remove all PC shelving.
3. Remove the duct grill in the PC.
4. Remove the PC duct cover and polystyrene insulation.
5. Using 2 fingers, withdraw the fan motor upwards. It is mounted horizontally in the divider partition.
6. With the motor out, this will expose a small multi plug and socket connection to the fan motor and wiring
harness. Unplug.
7. To refit back together, fit the wiring harness multi plug first into the pocket of the divider partition.
8. Using your 2 fingers, slip the motor back into the divider partition to fit horizontally.
NOTE: The back of the fan motor faces upwards.
9. Refit the duct covers and test.
May 07, 2016 | Fisher and Paykel Refrigerators
How to replace the fan in a rf610a
Which fan? Fridge fan or freezer fan?
Fridge fan
harness. Unplug.
To test the fan(s),
Testing a PC or FC fan motor with a multi meter is not possible, due to the electronics contained within the motor. The simple way to test a fan motor is to apply a DC voltage with a 9-volt battery.
Fisher and Paykel French door, freezer drawer, F24 and flashing wrench symbol. Help
That's a water filter error code.
Did you just change the water filter? If not, do so.
If you didn't change it or changing it doesn't solve it, the next step is to ensure there's no air trapped in the system. Get 2 or 3 glasses of water at the door.
If the error code still shows, press and hold the Filter button for 10 seconds which should re-set the code.
If that sorts it out, let us know what worked please. This helps other people with a similar problem know.
However, iIf you still have trouble and the appliance is still in warranty (possibly 2 years or more depending on where you bought it), call the company and provide the model and serial number and they should be able to tell you.
If in warranty, arrange a service call.
If not, let us know what you did and we'll go from there. Good luck!
Jun 03, 2015 | Fisher and Paykel Dishwashers
OK I have the RF610A fridge on top and freezer below in french door arrangement.
Have you checked the fridge thermostat? If the thermostat is ok then you should trace the volts which operate the valve which connects the compressor to the fridge evaporator coils. If the valve is getting volts then the valve is faulty. If not fault lies with control circuitry.
May 08, 2014 | Fisher and Paykel Refrigerators
Fisher paykel wiring diagram
From my dealings with Fisher Paykel they do not produce wiring diagrams as all components lead into the main PCB
Apr 08, 2014 | Refrigerators
Fisher and Paykel RF201ADUX Refrigerator - error code F30 F31
I found loose wires under the top right hinge, where you will find a small connector block. Put the loose wires back in and hey preso the lights were back on, the water and ice defenses worked and the fault code was cleared
Mar 19, 2012 | Fisher and Paykel Refrigerators
F24
Fridge is showing f24 fault and wrench symbol. No ice is being made and it peeps continually when door is open
Nov 16, 2011 | Fisher and Paykel RF201ADUX Bottom Freezer...
Fault Code F24
fisher paykel fridge model e522b fridge section is freezing up
Mar 31, 2010 | Fisher and Paykel Active Smart E522B...
Fisher and Paykel model RF610 approx 4 months old door warning goes off as soon as fridge or freezer doors are opened. error code F24 showing in display screen also spanner symbol icon thingy flashing.
Dec 19, 2008 | Refrigerators
Error code F32 for fisher paykel fridge F32 and a spanner is appearing in the display of our new Fisher Paykel fridge model # RF610ADUX. What does this mean ?
Got the same error here, called Fisher Paykel and the said it's an error related to the water line. They recommended running 3 L of water and see if code disappeared. If not, call service, they gave me a local company. Error code has disappeared, for now.
Aug 24, 2008 | Refrigerators
Refrigerators Logo
95 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
