I have a Bosch21e water heater problem is its not heating we had to switch over to a full gas bottle since then we have had no hot water any help would be great.
  • 96 Answers
Sounds like you have air in the line and needs to be bled out
Posted on Jan 27, 2009
We have a gas unit in our ensuite for a hot water we can not seem to get any hot water the gas cylinders are getting low so i have asked for them to be refilled or could i there.
refill the gas bottles and then if that doesn't fix it, get a technician out as it may be the pressure switch not opening the gas so that the pilot light ignites the burner
May 03, 2015 | Bosch Water Heaters
I have moved into a property with a kelvinator LPG
Most probably the flow switch that senses water flow and opens the gas and turns it on is stuck due to not being used.
Sep 18, 2014 | Water Heaters
Fagor compact plus
You could have a defective gas control valve or a bad thermocouple. Also check the venturi tubes again. sometimes cob webs collect in them and it may be difficult to see unless you remove them and check.
Good luck,
Marty
May 05, 2014 | Water Heaters
Rinnai 32 Hot water system cutting out
The water flow switch is bad but may be able to be adjusted by yo if you closely examine it.
Jun 30, 2013 | Rinnai Heating & Cooling
The heater only blows cold air,the radiator is full,thermastat is working and the engine temp is within normal ranges.
I've had this problem. 2000 GMC uses a closed coolant system. Meaning takes and returns coolant from and to the Reserve Bottle and has little air in the engine and heater systems.
If everything appears ok but no heat. "Air Lock" is the most likely cause. (With interior heater set to full heat) Solution; 1. Make sure water pump works. 2. Drain about 1/2 engine coolant into container. 3 Remove both heater hoses from engine side and flush heater core in both directs through heater hoses with garden hose. 4. Reattach heater hoses in correct locations. 4. Refill engine with coolant. 5 Start engine and run for 2 min., use caution when topping up coolant.
6. Most 2000 GMC have twist off caps with plugs located mid way on heater hoses. with engine cold, start engine these caps may be loosened to allow trapped air to escape. Do not attempt with engine hot due to hot coolant injuries. This may take more than one attempt to remove all air from heat system. 7. Lastly most 2000 GMC water pumps have a bleeder plug,( 3/8" square driver plug) located on the water pump. With egine cold this plug should be removed to remove any air. Reinstall plug with thread sealant.
Hope this helps cheers
Dec 09, 2010 | 2000 GMC Jimmy
I have a Atwood 10 gallon electric/ propane water heater on the Hornet travel trailer I purchased used. There are two switches on the wall, one is an on/off switch that lights up and the oither is just an...
The two switches control the water heater either in the gas or electric mode. The switch with the lights would be for the gas operation, and the switch without lights would be for the electric mode. Prior to operating either switch, make sure the water tank is full of water. Turn your hot water tap on, if water comes out, tank is full. Connect trailer to 110 Volt source, turn circuit breakers on, Place switch without lights to on position. If water does not heat in 45 minutes, Install new heat proble. The gas mode should be repaired by someone that is familiar with that system. Atwood can provide you with a local service center.
Oct 10, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
How long does it take to reheat water when gas bottle runs out and then you switch to new bottle ?
water getting hot should be almost instant... it may take a minute to move the cold out of the pipes.
is your heater ignighting?
if not then you might have a small amount of air in the gas line when you changed the bottle.
you will need to bleed the line...
with the gas turned on, loosen the gas connection to the unit and let the air out until you smell gas.
tighten the connection, snug, do not over tighten.
wait about 5 minutes for the gas to dissipate before attempting to light the unit.
during this time, you can use a little soap water on the connection you loosened to make sure it is not leaking.
now go turn on your faucets, let the water run for a minute and make sure you get hot water.
if no hot water, then you might have something else wrong. you will need to let us know the error code and what the unit is doing
Aug 11, 2010 | Bosch & Tankless LP Hot Water Heater
Rheem Integrity 24 Has Error LO79 can someone tell
79 is fan motor current fault or circuit board you will have contact rheem
Jun 07, 2010 | Rheem Tankless Hot Water Heater...
We are getting luke warm water and the low gas alarm is sounding even though we have a full bottle of gas. My gas hob is working fine.
even though you have a full bottle it might not be the right bottle, you have to have a min 2lb for a water heater to work, take and have the bottle checked to make sure it is the right pressure tank
Apr 19, 2009 | Water Heaters
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
