Question about Dell Inspiron 6000 Notebook
Laptop problem Hello. I start my computer but when it gets to the main screen it just blinks. The whole screen blinks and does not let me access any programs. I cant restore my system or run anything. I tried safe mode and that doesnt work either. This problem started after a game was downloaded from limewire. Can you help me?
Thank you problem solved.
Posted on Jan 25, 2009
I have hp pavillion DV6-6c35dx black screen with caps lock blinking twice to indicate corrupted bios. How do I flash the bios on this laptop?
If that computer wont boot to a screen that you can recognize, it is a brick. When the bios is corrupted and it wont allow the machine to start you cannot access any screens that will allow you to recover. It takes special equipment to flash the BIOS when this happens and most places just replace the whole motherboard because this equipment is not used often by repair shops.
Dec 14, 2016 | HP Computers & Internet
DEll Latitude D520 is not starting at all.
Remove the main battery and try again, no change! remove the ram memory one at a time, testing as you go making sure there is one ram stick in the slot at all times. If none of these work, the motherboard is the likely problem and you will need a technician to access.
Jul 21, 2012 | Dell OptiPlex Computers & Internet
I have put a password on my main screen on laptop, but forgot it, how can i get back into my laptop
Hello.
There is a hidden Administrator account that is created when your operating system is installed. Access that account and then reset your password.
1. Boot your computer and press F8 repeatedly
2. Access Safe Mode
3. Key in "Administrator" in Username, with no password.
4. Go to Control Panel, then User Accounts
5. Select the account you want to reset the password
6. Change the password
Hope this helps
Mar 21, 2011 | Acer Computers & Internet
Will not start. screen black as the red light continues to blink. must be unplugged to get the blinking red light to stop. alive but dead.
The reason your television does not come on and you only have blinking red light is because there is a problem inside the unit.
The problem mainly is either from the main panel or the power panel of the television. There is a burnt capacitor on the main panel or the power panel that is why it is not powering up.
Unplug the television for a while, about an hour or two, so the high voltage on it will dissipate, then you unscrew the screws at the back. You will have access to the main panel and the power panel, assess it and you will find a burnt capacitor, have it replaced by turning the panel to the other side and melting it off with a soldering iron and replacing it with a new one. Then couple the television back together.
Take care
Oct 14, 2010 | Toshiba 42HP95 Television
Compaq 6735s notebook pc goes to HP screen, but wont boot
First you need to determine how many blinks you are getting when you try to power on the laptop.
Check the blinking codes below and reason behind that for HP Compaq laptops
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock - System board General system board failure
Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure
Plz get back so I can suggest you the steps to resolve the issue.
Dreamkam
May 24, 2010 | HP Compaq 6735s Notebook
DV8309 power up problem: blue lights on for few seconds then off
The inverter inside the lcd panel is most likely your problem. Try removing the whole lcd screen from the laptop if you are capable and run it with the external screen to confirm. leave the lcd switch off (this lcd switch above the power button turns the lcd inverter on and off)
Jun 19, 2009 | HP Computers & Internet
Screen is blinking very frequently
Hello, this is a known problem with the model of that laptop. You will also notice in safe mode your screen will not flicker but in normal mode it will flicker.
Your laptop should still be under warranty and needs the LCD replaced.
Mar 04, 2009 | HP Compaq 6720s Notebook
Computer problem
The only thing that you can do is Reinstall Your Operating System, Windows ??? Word to the Wise! Limewire is FULL of Viruses and you will get them more often than not!
Jan 25, 2009 | Dell Inspiron 6000 Notebook
Black screen, White blinking line on bottom of Monitor
During the move was your laptop dropped or bumped ? If so you might of unseated the video adapter from your laptop. Have you tried another monitor? I wouldnt rule the monitor as the problem. Try another monitor. If you have more questions or problems feel free to get back to me and I will do my best to talk you through a solution.
Sep 19, 2007 | Dell E196FP 19" LCD Monitor
Dell Inspiron 6000 Notebook Logo
Alun Cox
