Question about Photography
What is slide storage? - Photography
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 51 Answers
Slide Sotages are actually storage systems for large quantities of slides.
Posted on Jan 17, 2013
I have a 1976 Gaffers & Sattlers slide in range I want to replace. Any idea how to remove it? Thanks
this taken from ehow site:
Slide-in ranges and freestanding ranges use the same installation techniques, with one minor difference: the slide-in range rests on the edge of your counter top. Removing a slide-in range is not difficult but will require a friend to assist. Removing the storage drawer from the slide-in range first will give you access to the power cord and gas shut-off valve, if your unit uses gas
Instructions
    • 1 Pull the bottom storage drawer out as far as it will slide. Lift up the front of the drawer and unhook the back of the drawer from the drawer guide. Pull the drawer away from the range.
    • 2 Reach under the slide-in range and unplug the power cord from the wall outlet. Turn the gas valve to the off position on the house line coming from the wall.
  • 3 Lift the top of the slide-in range with the assistance of your helper, and pull the range forward enough that you can access the back of the range.
  • 4 Go behind the range and locate the connection between the house gas line and the range gas line. Disconnect the flexible gas line from the house gas line with a pair of channel lock pliers or a pipe wrench.
  • 5 Lift up on the rear of the slide-in range while your partner lifts the front. Slide the range out of the cabinet opening and out of the house. Lifting the unit will prevent unnecessary damage to your counter tops.
  • Read more : http://www.ehow.com/how_5959888_remove-slide-range.html
    Jan 03, 2015 | Kitchen Ranges
    Front slide wont slide
    The slide system usually uses inline circuit breakers to control the power for the slide. Some are automatic reset and others have a small black button on the side that must be reset. On a motor coach you will find these in a storage compartment and they probably will not be labeled.
    Mar 17, 2014 | Dutchmen 2013 Komfort 3650FFL
    I want to reinstall a oven storage drawer on a electric LG oven
    I don't think you need to remove a slide rail. They should slide out by hand and then set drawer back into it. usually have to tile drawer up some to start.
    Nov 06, 2013 | Kitchen Ranges
    Where can I find quality storage boxes for my slides?
    Here's a great online store specializing in photography slides: http://www.universityproducts.com/cart.php?m=product_list&c=1261
    Jan 17, 2013 | Photography
    Ice not dispensing from door. There is ice in the cabinet.
    look behind the ice storage bin---there is a c-bracket that the storage bin slides into --- the motor may have to be replaced that turns the spiral feeder inside of the storage bin
    Jan 02, 2011 | Maytag MBF2256H Bottom Freezer...
    Just a question about storage- The heat and cold
    While the projectors are more forgiving to environmental extremes, I would opt for a closet and not the attic. The slide trays (more importantly the slides, themselves) need as constant a nominal temperature & humidity as you can provide. The slides will warp and stick in the trays if exposed to too much humidity.
    Jul 26, 2010 | Kodak Ektapro 9020 Slide Projector
    I have a sidekick slide and can not figure out how to download picture from my phone to my computer the service is t mobile can you help me
    hey do you have a cable or a bluetooth device in your pc?once you attached a data cable from the pc, your phone will asked you what to choose if its data storage or charge (something like that) choose data storage, then browse to the location of your pict, and try to move the picture in the sd card of your celphone.
    Sep 27, 2009 | Motorola Mobility SIDEKICK SLIDE Cell...
    The moonroof on my 2002 lincoln towncar is stuck open. I can hear the motor when I push the open button, but the motor sounds dead when I try to push the button to close. Could it be jammed? Is there a...
    Temporary Fix: unsnap off the access door in the overhead ceiling liner behind the sunroof opening;
    Use a 4mm hexagon Allen wrench to wind it closed.
    Sep 12, 2009 | 1999 Lincoln Town Car
    Storage compartment with sliding top is jammed and won't open
    best bet to pry it opened with a plastic screw driver
    Aug 26, 2009 | 2008 Honda Pilot
    Sunroof doesn"t open or close
    Section 01-17: Roof Panel, Sliding—Electric 1996 Taurus, Sable Workshop Manual DESCRIPTION AND OPERATION Electric Operation The sliding roof panel (502B98):
    • is available as an option.
    • is electrically operated through the accessory delay relay (controlled by generic electronic module (GEM)).
    • is of self-storing design.
    • requires a specific headliner.
    • utilizes a unique roof console and dome lamp.
    • has an air deflector.
    The electrical system operates in the following manner:
    • Two switches control movement of the roof panel.
    • When the SLIDE roof sliding panel switch (15B691) is rocked rearward, the roof sliding outer glass panel (502A82) slides into the storage space between the roof trim panel (51968) and the roof panel, exposing an opening over the front seats.
    • When the SLIDE roof sliding panel switch is rocked forward with the roof sliding outer glass panel fully back in the storage space, the roof sliding outer glass panel moves forward from the storage position.
    • The rear portion of the roof sliding outer glass panel moves upward on two lifter arms near the end of the forward travel, allowing a weather-tight seal when the roof sliding outer glass panel is closed.
    • An AUTO feature allows the SLIDE roof sliding panel switch to be touched momentarily to cause the roof panel to automatically move to the fully open position.
    • When the TILT roof sliding panel switch is rocked forward with the roof sliding outer glass panel fully forward, the rear of the roof sliding outer glass panel pops up to the VENT position.
    • With the roof sliding outer glass panel in the VENT position, rocking the TILT roof sliding panel switch rearward closes the roof sliding outer glass panel.
    • Sliding Roof Panel Does Not Open or Close
    • Open power feed fuse.
    • Circuitry open/shorted.
    • Damaged roof sliding panel switch.
    • Damaged sliding roof panel motor.
    VISUAL INSPECTION CHART Mechanical Electrical
    • Damaged roof panel
    • Obstructed roof panel
    • Guide
    • Damaged drive cable(s)
    • Open Power Distribution Box Fuses 1 (40A) or 4 (30A)
    Apr 19, 2009 | 1996 Ford Taurus
    Photography Logo
    542 people viewed this question
    Top Photography Experts
    pontelemon
    pontelemon
    Tony
    Are you a Photography Expert? Answer questions, earn points and help others
