Question about Photography
Can I build my own dark room? - Photography
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 51 Answers
Yes, you can definately built it. but you need pre-conditions in your house. read more here: http://www.wikihow.com/Build-A-Darkroom
Posted on Jan 17, 2013
Can i take video in a dark room
Unfortunately, the Sanyo Xacti PD2 only supports a flash for still shots and dose not have a lamp light for the video side of the camera. You'll have to provide your own source of light for good quality video in a dark setting.
Hope this helps.
Feb 09, 2014 | Sanyo Xacti VPC-PD2 Digital Camcorder - 2"...
How do i lighten up ma keyboard? cant use my laptop in a dark room
Hi everyone, i'm using a hp pavilion touch smart 14 sleepbook, i can't use it in a dark room, can someone pls help me how can I lighten up my keyboard?
Feb 10, 2013 | Dell Computers & Internet
The NEC 100 projector I have in one of my class rooms has the strobe effect issue. I have changed the phase as well as a couple other settings none of which worked. We have tried to switch it out but all...
check the physical nature of the lamp in the projector. around the filament of the lamp, you might notice dark corrosion building around it. this might cause the issue you've mentioned.
Sep 13, 2011 | NEC NP100 Projector
Can not focus. The lens moves fine from one end to the other but I'm unable to see clear images with or IR while in a dark room.
Don't IR illuminator in the dark room. Turn on a small light in one of the corner; such as, a small light bulb. increase ambient light a little at a time until you can focus. You flooding the dark room with IR illumination which will reflect everywhere in there. This might take care of the fuzziness in the monocular. stewbison
Jan 29, 2011 | Yukon 24021 Monocular
Will the HB51R have to be placed outside to work on dusk to dawn.
The dawn to dusk feature is activated by photoelectric eye that senses when it gets dark.
If you put timer in a dark room, it will turn ON ... let's say to operate Christmas tree after you leave a room for the evening.
But if room stays dark, the timer will not sense when to turn off unless you also set timer to turn off 1-9 hours after ON.
That being said, a Christmas tree might make too much light for the timer's photoelectric eye.
Make sure photoelectric eye is turned away from direct light.
Dec 09, 2010 | Intermatic Outdoor Timer/Photo Control...
Dark picture image, dosen't respond to briteness control
are you able to see the picture in a dark room ? does it appear bright enough then ? if so the lights behind your screen have dimmed or gone out completely. this may just be the power supply for the lights or your lcd panel may need to be replaced
Nov 19, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
White corners SONY KDL52XBR6
This is called a dark shading error. All the LCD consumer sets have some visible degree of this effect. Some will be a little less or more than others even from the same batch in the assembly run. This has to do with the optical design quality of how the back-plane lamps illuminate the screen. The design and assembly tollerance of this area is very critical.
Normally, LCD screens don't show their best picture in a darkened room. The very black regions of the picture content may look a little washed out. LCD screens are best watched in a room that is lit, but not very bright. You have to consider that there is a powerful set of lights behind the polarized panel of the LCD display, and there will always be some breakthrough of light.
If you want a TV that is more like a CRT in its characteristics a Plasma would have been a good choice. The trade-off with the Plasma is that it does not have the picture sharpness of the LCD. A Plasma set is best watched in a darkened room.
If you have an LCD computer monitor, take a look at it in a dark room with a black screen. You will most likely see the dark shading errors. Only the very expensive production studio type LCD monitors have less of this error than the consumer sets, and they are not absolutely perfect.
Jerry G.
Nov 19, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Remote control sensor doesn't work when the room is dark.
its probably the led in the remoter, check with a camera on a phone point the camera at the remote if its dim, that's the problem, it could also be a damaged battery in the remote.
Jun 18, 2017 | Televison & Video
Projection TV when turned on picture is dark can view slight images until dinning room light is turned on
Try hooking the TV to a different outlet fed by a different breaker. Does the problem go away? If so, the culprit may be a wiring problem in your house that is causing the TV not to get enough power unless the dining room light is on.If in doubt, consult an electrician to make sure both the dining room light and TV outlet circuits are working properly.
Mar 06, 2008 | Mitsubishi WS-55613 55" Rear Projection...
White dust
Suggest you try using distilled water in the Humidifier in the baby's room. If your seeing that much dust you must have heavy hard water in your borough, suggest you replace the filter more often & or Demineralization Cartrid if your not already doing so.
Hard water is tough on many things in your home. Washing clothing can produce dark & light spots, some rust in color. Build up of rust & minerals through out the water lines in home. Bad taste. Build up of white stains in glasses & the list goes on.
The best choice would be a filtering system to remove most if not all hard water as it enters your water lines. Many companies near you can help you remove this problem. Listed below is one such company.
http://www.raindancewatersystems.com/maxicure.html
CPSC Issues Alert About Care Of Room Humidifiers
http://www.cpsc.gov/cpscpub/pubs/5046.html
Goog luck & Best Regards.
Thanks for using FixYa
please vote...
Jan 28, 2008 | Vicks Ultrasonic V5100 Humidifier
Photography Logo
451 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
