Question about Whirlpool Duet GHW9150P Front Load Washer
What is the load capacity for ghw9400pto - Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer troubleshooting
check pump for an object internally jamming it up remove lower front panel pump has a large plug with a handle rotate to remove you will get a rush of water so be prepared
Aug 24, 2014 | Whirlpool Duet 3.8 cu. ft. Front Load...
Capacity frigidaire fwt445ges2 load
Good Afternoon Friend,
I understand you want to know the capacity of your Frigidaire washer, model# FWT445GES2. After researching your model, I found that the capacity of your washer is 4.5 cubic feet. Hope this is helpful.
-Best Regards-
WP
Jul 05, 2014 | Frigidaire GLTF2940ES Front Load Washer
Capacity
if this is a top loader. the capacity is that as long as ur load is moving freely when adgitating is a good load. if its not moving freely its too much laundry
Feb 05, 2010 | Kenmore Washing Machines
What is its capacity
Overall home/domestic washers have similar capacities:
Front loaders: between 15 and 20 pounds capacity.
Top loaders: between 10 and 12 pounds capacity.
The best way to determine if you are not overloading your washer is by loading your clothes in the washer making sure it is loosely full of clothes "do not push the load down" to make room for more.
Aug 30, 2009 | Whirlpool Washing Machines
White-Westinghouse model la450mxw1 top load capacity in Kg.
I called Frigidaire technical support, they informed me that the capacity is 2.7 c/feet.
Nov 26, 2008 | Westinghouse WWS833ES Super Capacity Top...
What is the capaity of 2005 Kenmore Elite Washer and Dryer, models 110?
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
May 10, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
54 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
