Question about Photography
What is an enlarger? - Photography
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 51 Answers
As an engine is the heart of a car, so is an enlarger the heart of a darkroom. It is the instrument through which negatives are brought to life. Along with a good lens, it is the enlarger that the rest of the darkroom is built around. A darkroom can have the best plumbing, a great stereo and stainless steel trays, but without a good enlarger and lens, it can be hard to produce quality images.
Posted on Jan 17, 2013
I need to know how to take the fuse box under the hood of my 2005 Chevy Impala so I can put a new one in.
Underhood Electrical Center or Junction Block Replacement
Removal Procedure
  1. Disconnect the negative battery cable. Refer to Battery Negative Cable Disconnect/Connect Procedure in Engine Electrical.
  2. Click to Enlarge
  3. Disconnect the positive battery cables from the underhood fuse block terminals.
  4. Remove the tape from the wiring harness at the base of the underhood fuse block base.
  5. Click to Enlarge
  6. Release the underhood fuse block(s) clip retainers using a small flat-bladed tool.
  7. Click to Enlarge
  8. Remove the fuse block(s) and wiring harness lifting up from the base and reposition from the base.
  9. Click to Enlarge
  10. Remove the nuts from the underhood fuse block base.
  11. Remove the underhood fuse block base from the shock tower.
  12. Click to Enlarge
  13. Remove the underhood fuse block lower front terminal positive assurance retainers using a small flat-bladed tool.
  14. Click to Enlarge
  15. Remove the plastic shields from the battery cable and buss bar terminals, using a small flat-bladed tool to release the clip retainer.
  16. Click to Enlarge
  17. Remove the bolts from the buss bar jumper bar.
  18. Click to Enlarge
  19. Remove the buss bar jumper bar from the fuse block(s).
  20. Click to Enlarge
  21. Remove the fuses from the fuse block(s) to access the buss bar terminal release tabs.
  22. Click to Enlarge
  23. Remove the buss bar(s) from the fuse block(s) using a terminal releasing tool, and pulling down and out on the buss bar.
  24. Click to Enlarge
  25. Remove the buss bar(s) from the fuse block(s).
  26. Click to Enlarge
  27. Release the clip retainers from the underhood fuse block(s) battery cable and buss bar terminals using a small flat-bladed tool.
  28. Click to Enlarge
  29. Remove the underhood fuse block(s) battery cable and buss bar terminals from the fuse block by pulling down.
  30. Remove the fuse block and lamp wiring harness from the vehicle, if required.
I copied the info from my database, sorry, it is read only, The way I copied it, read only, no pictures.
Jan 28, 2018 | Chevrolet Impala Cars & Trucks
How do i enlarge photos/images?
In a photo editor like photo shop. Be aware even after enlarging a photo, it will not have more info. Small pictures have little info, and will be blurred when enlarged.
Mar 08, 2015 | Huawei Cell Phones
Does black and white photography use the same enlarger as color photography?
Black and white photography uses a much more basic enlarger, you will notice that some enlargers have knobs on the front that are magenta, cyan and yellow these are color enlargers. A color enlarger can be used to develop black and white images but a color image cannot be developed using a black and white enlarger.
Sep 17, 2013 | Photography
What is Condenser Enlargers?
Read about enlargers: http://www.bhphotovideo.com/find/Product_Resources/darkroom/enlargers.jsp
Jan 17, 2013 | Photography
Can I enlarge pictures using this porinter?
Enlarging photos will definately lower the quality of the original photo try using some software like photoshop to enlarge it to some extent and then try to print.
Jun 22, 2010 | HP Officejet 6500 Wireless All-in-One...
IPhone Smartphone: how do i get the screen to not be enlarged on my i...
Your iPhone is in enlarged mode caused by accidentally double tapping with 3 fingers. You can find the solution here: iPhone screen enlarged. You can turn the feature off.
May 18, 2010 | Apple iPhone Smartphone
How do I enlarge something on the copier?
your machine has Reduction / enlargement capacity from 25% - 400% as said in the manufacturers site...
read this manual:
http://support.lexmark.com/index?page=content&actp=PUBS&locale=en&segment=SUPPORTproductCode=&userlocale=EN_US&id=PU45810&productCode=LEXMARK_X4650
see in page 84 how to do it...
Sep 03, 2009 | Lexmark Office Equipment & Supplies
How to get enlarge photo copy.i want enlarge form of my id card
go to reduction and enlargement setting and select enlarge it should indicate incriments going up
Aug 12, 2009 | Office Equipment & Supplies
Enlarging copies
To enlarge when using the copy function on the machine, you simply do  the following:
  • Press the Copy button to activate copy mode
  • Choose "Enlarge/Reduce"
  • Press the left or right arrow key until you reach "Custom (25-400%)"
  • Press OK
  • Type in the % you want it enlarged, press OK.
  • Start copying away with Color/Mono Start.
Jun 03, 2009 | Brother MFC 490cw Color Inkjet...
Photography Logo
500 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Tony
Are you a Photography Expert? Answer questions, earn points and help others
