Question about Epson LQ Office Equipment & Supplies
We are using Epson LQ 590 using IBM iseries for prinitng, but the printer driver is not comaptibale with the Iseries. looking for driver which is compatible with IBM iseries.
  • 13 Answers
SOURCE: Outq Set-up
Hi Margoz,
This shouls help you.
http://www.redbooks.ibm.com/abstracts/SG242160.html?Open
Aido
Posted on Mar 06, 2008
  • 6 Answers
SOURCE: Zebra TLP 2844 Controlling the font size w/iSeries??
Hi Burgymon,
The font that is used under the barcode will use the last font properties described prior to the barcode in the output. You may want to suppress the human readable option and create a separate text field to display the text version of the barcode contents.
Posted on Sep 25, 2008
LineMatrix
  • 34 Answers
SOURCE: Printronix p5010 with AS/400 IBM server
I can get the P5010 printing on your AS400... But, there are to many things to check without knowing a little more about your environment.
If you can't ping the PTX P5010 from the AS400 or a PC, then you have a printer configuration problem.
Take the printer offline and hit the Print Config button. and then the enter on OPs Panel. Then post top or first paragraph of the config. so I can look at...
__________________________________________________________
If you can ping the printer from the AS400...
You will need to create a remote out que on AS400... command is crtoutq then hit F4...
if you can't post the printer config here... Fax it 972-233-7306, Attn: P5010, Toby
Posted on Dec 01, 2008
acdr
  • 1913 Answers
SOURCE: epson matrix drivers compatible with IBM laptop
http://www.nodevice.in/driver/LQ-1170/get24975.html
just enter varifiacation code and download from here.
Posted on Mar 04, 2009
muntejaya
  • 10421 Answers
SOURCE: Trying to use the Konica
Please get the correct driver here : www.printcountry.com/drivers.asp
www.opendrivers.com/.../printers-free-driver-download.html
www.driversdown.com/driverslist/r_4_1.shtml
Regards, Jay__u87ue4w
Posted on Feb 26, 2011
I am using LabelView to create a label that will be imported into an iSeries system. I am using Zebra 140xiIII as the printer in LabelView. When I import this label file into the iSeries system, I am...
iseries uses EBCDIC and the file is probably ASCII when importing from/to the iSeries charset convertions ensues, there must be some char that isn't translating well and thus converting itself in some control code, use DSPF or EDTF to open the file and check with F15 the encoding for more info I need to know what is your system CCSID
Apr 28, 2011 | Zebra 140XiIII Plus Thermal Label Printer
I cant set the printer with as400
Turn the printer off
Enable auto config in Systems Value QAUTOCFG see ...
http://publib.boulder.ibm.com/infocenter/iseries/v6r1m0/topic/rzarl/rzarlautoconfig.htm
Then turn the printer on
If the printer descriptor doesn't get created automatically, use
CRTDEVPRT command see:
http://publib.boulder.ibm.com/infocenter/iseries/v5r3/index.jsp?topic=%2Fcl%2Fcrtdevprt.htm
Dec 28, 2010 | TallyGenicom 6306 Matrix Printer
How to you know if your new Tallygenicom printer 6312 is compatible to your system?
The answer to this depends very much on what sort of system you are using......
If it is a Windows System you can simply install the Windows Printer Driver and use the printer as a normal Windows Printer.
On Unix / Linux you can set the printer up (usualy using CUPS) in this case you can use one of the standard device types and select a corresponding emulation on the printer-
Set the printer to Epson FX emulation and use a Epson 9 Pin printer driver
Set the printer to IBM Proprinter emulation and use an IBM Proprinter priver (9pin)
On the AS400, iSeries, Seriesi you can also use the Epson FX emulation or IBM Emulation and select the corresponding device type on the host system
Other systems may support similar functionality.
You can also send plane text files to the printer, or alternatively program you own escape commands to control print features.
So like I say it depends on the system you are using, perhaps a good place to start is by contacting Support for the Computer Application or System you are using to see if they support Dot Matrix and or Line Printers.
It is not possable to give a generic "Covers all Systems" answer, unfortunatly
Sep 10, 2010 | TallyGenicom 6312 Matrix Printer
I would know if D-Link DP 301P Print Server supports SNMP protocol because i need to print from IBM iseries thank you
It supports all below protocol so you can give print from IBM iseries .
TCP/IP Protocols Supported :
  • BOOTP
  • SNMP
  • Telnet
  • TFTP
  • FTP
  • LPD
  • RARP
  • DHCP
Jul 28, 2009 | D-Link DP 301P (DP-301P) Print Server
Printing problems (InfoPrint 6500/iseries)
need more info plesae give me the most information on type of equipment and software issues and driver setting if you know and version of software may be helpful infor mation
contact threw this web site
rod the candymangandy
Feb 03, 2009 | IBM Infoprint 6500 Matrix Printer
LQ 590 POS
the driver for your printer is not installed correctly. please reinstall.
Sep 23, 2008 | Epson Dot Matrix LQ-590 Printer
Hi Burgymon,
Mar 25, 2008 | Zebra TLP 2844-Z Thermal Label Printer
126 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
