Question about Photography
What is the cheapest processing equipment? - Photography
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 51 Answers
The price range is $300 and up and can get to more than 2000$. Check out this website: http://www.alibaba.com/showroom/photo-printing-machine-prices.html
Posted on Jan 17, 2013
What are reasonable prices for SIP trunking?
A cheap SIP trunk service is the great solution for a company which is in the process of converting traditional telephone service to VoIP system. However, if the company has PBX system, then it is not necessary to replace all equipment and you can use SIP Trunking which is less expensive. SIP Trunking allows your existing PBX system to Internet for VoIP connection. In SIP, bandwidth matters a lot to get proper network throughout the use. Also, features like:
1) Efficiency of data connectivity
2) Sharing of international voice calling across enterprise
However, the price of SIP Trunking also matters. The price of the service depends on the plan you're taking. Different companies have different plans having features along. Reliance Global Call is a prominent company offering SIP Trunking solutions. The enterprise SIP Trunk allows you to have international long distance calls under cheapest price.
May 16, 2017 | Computers & Internet
Tip
What are 4 common welding processes?
There are four common welding processes utilized through out the work industry today. They are :
(Stick Welding or SMAW) Shield Metal Arc Welding
(Mig Welding or GMAW) Gas Metal Arc Welding
(Tig Welding or TMAW) Tungsten Metal Arc Welding
(FCAW) Flux Cored Arc Welding
There are many many welding processes, however these are the most common. The type I am going to discuss briefly today is SMAW. The most economical and cheapest way to learn if welding is for you or not is to start with stick welding. It has the least amount of variables that can go wrong for a beginner. It is not fast paced like mig or flux core, so you have time to watch the molten puddle to see what it is doing and make necessary adjustments to correct the size, shape, and contour of your weld bead. The hardest part for a beginner is to keep the electrode from sticking to the work piece. Thus is the reason it got the name of "stick welding". There are three common ways to strike an arc in SMAW. Tap Start, Scratch Start, and the last is to place the electrode upon your fingers like a pool cue, and shoot the rod like your playing pool.
on May 31, 2010 | Welding Tools
Anyone know the Quickest, Cheapest, Easiest way to make racks for three push bikes.
No easy way to do this, you need welding skills and equipment.
Sep 13, 2016 | Cars & Trucks
How Much Time Does The Whole Process Take?
When you are set up with Merchant Advisors, equipped with the correct documentation, we are able to fund your invoices within 24-48 hours.
Sep 09, 2015 | Retail Supplies
Download instruction manuals
Good luck with that. People keep buying these cheap kits that are junk from companies they never heard of before and when there is a problem there is no tech support. You get what you pay for, when you buy the cheapest equipment it will normally cost you more. I remove equipment like this all the time. Keeps me in business.
Aug 31, 2014 | Nil Eastern DVR4004K 250 Web Surveillance...
Need a 36 volt battery
Depending on the space available, physical dimensions of the battery you are replacing and its amp hour rating; you may want to wire three 12v batteries in series (or if you have the room, six 6v batteries). On one battery, you should have one Positive + (usually red) terminal to connect your Positive + (Red) cable from your equipment to and the other terminal (Negative - Black) would jumper to the Positive of the second battery. From the Negative terminal of the second battery, jumper to the Positive terminal of the last battery, leaving the Negative terminal for your equipment Negative - Cable (Usually Black) to connect to. All jumpers between batteries must be the same size wire as the equipment cables to carry the amperes of the equipment load (Usually a motor).
Apr 01, 2014 | Electrical Supplies
I have a 03 ford explorer code p0300 p0307 p0316 what could it be
a random miss fire can be caused by many things but the cheapest & easiest place to start is change the spark plugs & wires & distributor cap & rotor if equip. or check coil packs
Aug 11, 2013 | Ford Cars & Trucks
Computer will indicate power but power light keeps on flashing, no hard drive light, no fans or anything else, power light on screen, screen black
Your computer power supply has shut down with circuit protection. Look for equipment or leads that have shorted out.
Remove all the equipment until only the monitor is plugged in.
If this works restore the equipment one by one until you find the fault.
Try this order
monitor
fans
hard drives
If it does not work with just the monitor it is either a faulty power supply or a faulty motherboard.
The Power supply is a the cheapest one to buy, to find out which is faulty.
Mar 07, 2010 | Compaq Presario 5000 PC Desktop
How do I clean
Fill kettle until 3/4 full with 1 part vinegar and 2 parts water. Boil and allow to stand overnight.
Empty solution from kettle. Fill the kettle with clean water, bring to boil and discard water. Repeat and the kettle will be ready for use.
Or you can use a proprietary kettle descaler, which is available at most hardware stores.
May 16, 2009 | Breville SK550XL Electric Kettle
Photography Logo
667 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
