When my usb drive insert the computer show "you need to format the disk in drive J: before you can use it. Do you want to format it?" then when I select to format disk, it show "Windows can't format J Chek to see that the disk and drive are connected properly,make sure that the disk is not read-only,and then try again.For more information,search Help for read-only files and how to change them" How can format it? Please help me it
4 Suggested Answers
SOURCE: When I am put my 8 gb Transcend usb deive into pc,
First I would advice to try to format it via disk management.
Second is try to format via CMD menu.
ok
try this.
To open disk management go through:
Control panel>administrative tools> computer management> then disk management on the left> then right click and format fat file system or as per to your convenience...
Posted on Mar 19, 2010
nonontech
  • 4737 Answers
SOURCE: I have Iomega 1tb External
Please connect it on another computer and format it from the command prompt. Once it's connected, note the Drive letter, i.e. E: or F: or which one. Now open the command prompt by clicking "Start", then "Run" (windows xp) or "Start Search" box (win vista and win 7) and type in "cmd" (without quotes), press enter. The commands are as follows, I'll assume it's drive letter is F:, in the command prompt window, type in "F:", press enter, then "format F:", again "yes" or "Y", you will need to confirm another warning, simply press enter and proceed, may take some time. After it's completed, you'll see another message, asking you to assign the volume name, give any name you like and press enter. That's all, if this doesn't fix, let me know.
The problem with this issue might be virus or drive partition corrupted or some technical/mechanical issues with the Hard drive. If it's infected by virus, then you should understand that the virus might still infect your system and so it is not possible to format it from your computer. On the other hand, you should check the usb cable and the adapter, and make sure they are properly connected and cleaned.
Let me know when you are done.
Good luck.
Thanks for using FixYa.
Posted on Sep 30, 2010
  • 644 Answers
SOURCE: Suddenly my Iomega 1tb stopped working and i
Have you tryed chkdsk in the command prompt, goto command prompt and type CHKDSK F: /F and press enter, this is a tool that checks your drives for any errors and hopfully should resolve any problems, rather than formating it and loosing everything on the drive.
Also have you tryed setting up the usb for mass storage in the bios somtimes there is a setting for this in the bios, or try setiing it back to factory defaults and see if that works.
The only other option would be to update your usb 2.0 driver in device manager in the properties of my computer icon on the desktop. hope this helps in some way and post back what happens.
Posted on Oct 03, 2010
How i format 8 gb usb sandisk
Usually, it comes formatted. However, you can re-format it (e.g. on a PC or Mac) using the usual disk format utilities, if you don't need any special/specific (SDHC) format features.
For instance, on a PC ... insert the USB SanDisk into a USB port. It will show up as a (storage) device on your "My Computer" window. Highlight that icon ... (put the cursor over it) ... and put your cursor on the FILE (menu) tab and click on it. It will display a drop-down menu with "Format" on it.
Click on the "Format" and it will guide you through the formatting process.
On a Mac, when you insert the USB SanDisk into a USB port, it will show up as a device on your desktop. You can use the "Disk Utilities" software (usually in the Applications - Utilities folder), to format it.
Jan 19, 2014 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to solve the problem " please insert the disk into drive" of memory card
ok how did format get done? if not on computer then formatting needs to be done with card in computer and do a thorough format NOT quick format
May 26, 2012 | SanDisk 2GB microSD Memory Card
My Transcend v30 pendrive is not working i had checked it in other computers but it was not working
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Apr 23, 2011 | Transcend (589307) Media
My 8gb kingston flashdrive is showing up as usb not recognised on my laptop but my 1gb is fine .What shoukd i do?
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Nov 09, 2009 | Kensington Electronics - Others
Computer crashed while USB was inserted. USB will no longer open.
Scan you pendrive for Virus from another computer who has effective antivirus program & it have latest Update.
Norton is my trusted.
Thanks.
Oct 06, 2009 | Lexar FireFly 1GB USB 2.0 JumpDrive - Blue
Pen drive not opening or formatting
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Jul 10, 2009 | Pen Drive IVO MP3 Player
PLEASE INSERT A DISK INTO DRIVE(H): (pendrive problem)
1)I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also )I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also
Feb 13, 2009 | Sony 8GB Micro Drive (SUD8G) -24419 USB...
Ttanscaned pen drive problem
I Have Cruzer micro (8Gb) pen drive When i Insert pendrive And open Show message (Pls Insert Disk) When I try to format Pen drive Show message (There is no disk in drive G) G Drive Right click And go properties Show 0byets Pls solve the problem Regards, Prashant
Jan 13, 2009 | Electronics - Others
My pen drive get detected and when click to open it shows the message: " PLEASE INSERT THE DISK INTO DRIVE I"
my pen drive get detected but i am not able to format and copy things to my pen drive
Mar 26, 2008 | Pen Drive IVO MP3 Player
Computers & Internet Logo
149 people viewed this question
David Payne
David Payne
