Question about Frigidaire Affinity ATF7000E Front Load Washer
Loud sound during the spin cycle in high revolve, after wash and rinse.
  • Frigidaire Master
  • 17,130 Answers
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Posted on Jan 17, 2013
5 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Noisy Spin Cycle
frigidaire frontloader infamous for rear bearings going bad,NOISY is probable an understatement. I wold open door and grab hold of inner tub, try to lift it up a bit, problably a bit of play in there, thats an indication of bearing failure, call authorized servicer possible warr parts
Posted on Feb 22, 2008
SOURCE: high speed drum rinse ..drum not spinning during rinse cycle
Clean out coin collector thoroughly. Replace drain pump if necessary. Water will drain if you can place drain hose on floor and let water siphon out.
Posted on Mar 24, 2009
  • 2976 Answers
SOURCE: Machine makes loud banging noise during the spin cycle
The load is out of balance. Open the lid and redistribute the contents. When it's empty, grab the basket and give it a slight push sideways. It should move a little but, not free swing. If it doesn't have much resistance, the "snubber" has dried out and should be replaced. It is simply a piece of rubber in a metal bracket, that rests on the tub. When the basket spins,the snubber keeps it from jumping around.
Posted on Aug 31, 2009
  • 97 Answers
SOURCE: Banging during the wash and spin cycle
sounds like drum is out of balanced call repairman they can rebalance drum this needs to be done ,once a year.
Posted on Dec 16, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin | eHow.com http://www.ehow.com/how_6496482
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
Oct 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
OUt of balance during rinse and spin cycles
I have the same problem. During the spin cycle, the washer spins all over the room.....very loudly.
Dec 26, 2009 | Maytag Washing Machines
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
Washer makes a loud, pulsing, screeching noise with no spinning
With a manufacturing date of 7/15/97, your washing machine is clearly worn out.
Nov 07, 2017 | Whirlpool Washing Machines
Loud noise during washing/rinsing cycles
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
Can anyone help.???
Oct 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
High pitch sound during rinse and spin cycle
makes loud squeel at end of spin cycle
Dec 27, 2007 | Washing Machines
Frigidaire Affinity ATF7000E Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
