WD-1481RD front load LG washing machine plus dryer the drain hose from left bottom side is gone inside how can I are it out..??
The bottom left side where you clean the drainage. The small tiny pipe comes out to uncap and clean it that has gone inside.
  • 209 Answers
SOURCE: Brown spotting on washed clothes
chances are if you have eliminated anything thats got in by accident that the drum bearings are about to go, the drum bearings are protected by a water seal, this has started to leak and is now washing the grease out of the bearings back into the wash, you may also find a small amount of water on the floor, if you also remove the back and look behind the large pulley you may also see brown water marks running from the center of the outer drum
the next step will be a very noisy spin, like a rumbling noise
DRUM BEARINGS sorry
Posted on Oct 15, 2007
futureloginn
  • 734 Answers
SOURCE: No Drainage on my LG WD-8050F washing machine
hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Dec 12, 2008
SOURCE: Nasty water accumulation from washing machine
Posted by Jay on Jan 11 2009
I have the same washer now for several years now. I keep getting the smell now and then. After reading all these disappointed people I went down to the machine and cleaned out the "Pump filter". It had been smelling today, I was tired of this problem also. So i opened the little door at the bottom front left corner. There you find a little black hose, pull it out a little and pull the plug. There you drain the water that's laying inside smelling up the house. Now you un-screw the big black cap. Once you remove the cap, you find a plastic filter-catcher. I found paper, a dime, and several other things that came out of my pockets. You can take the basket to the sink and wash it out. Put it back together and try checking it in one month. Also I used some needle nose pliers to clean the nasty stuff around the gasket. At the bottom of gasket try pulling it back to get to the hair and ****. We have a dog, so the hair is bad.
Posted on Jan 12, 2009
  • 22 Answers
SOURCE: Haier Washer/Dryer HWD1000 water leak from the
Check the button trap. Little door at front bottom right corner. There is a big screw in plug that has to be closed very tightly. Also check the plug gasket is clean.
Posted on Aug 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: Washing machine drain hose/pipe leak
Make the standpipe longer (the black pipe).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
How do you unclog drain hose?
Remove the drain hose from the standpipe and the back of the machine and use a long rod or broom handle and push it through the hose.
May 26, 2012 | LG WD-14124RD Front Load Washer / Dryer
I have an LG washer dryer combo model No. wd-1481rd, it will not drain on the display panel it has "OE" diplayed when put onto drain cycle i have tried to go through complete other cycles and...
Check for clogged/kinked drain hose then open the small door at the lower left of the machine. Located behind the small door is the drain filter and the emergency drain hose. Remove the drain plug and drain the water into a container that's enough to hold such. You may need to drain the water by gravity by placing the drain hose (main) over a container. Position the container as low as possible to extract as much water. Once fully drained, remove the drain filter by turning the knob counterclockwise. Place a piece of the towel under the filter to catch residual water. Clean the filter and try to reach in the pump impeller and check it for restriction or damage. Replace the drain pump if the impeller is damaged or restricted and cannot be freed, or if it just whirs but water doesn't drain.
Aug 20, 2011 | LG Washing Machines
Where is the drain filter and the spin rinse sensor located on
Have not heard of a part called a "spin rinse sensor". Drain filter is located behind the small access door at the bottom left on front of the machine. Use small hose there to drain remaining water out of pump and hoses, then unscrew the big thing on the right side (end of the filter).
Mar 14, 2009 | LG WM1814CW Front Load Washer
My LG Washer and Dryer has OE what does it means?
According to the handbook: drain hose is kinked or clogged; the drain filter is clogged.
Solution: clean and straighten the drain hose; clean the drain filter.
I have tried both but have not yet solved the problem.
Feb 20, 2009 | LG WD-3274RHD Front Load Washer / Dryer
OE error code on LG front loader
The OE error code means:-
The Drain hose is kinked or blocked or the drain filter is blocked
Solution:-
Clean and straighten the drain hose and clean the drain filter
Nov 01, 2008 | LG WD-14124RD Front Load Washer / Dryer
Retro-fit drain hose
hi not seen one of these retro types but having always wiped the seal and door after use as recommended with clean damp cloth prevents seal deteriation i would have thought this drain?on retro type that drains accumulation of any water from seal would be draining inside the outer drum and thro to drain into pump? seems odd?
Oct 22, 2008 | LG WD-3274RHD Front Load Washer / Dryer
LG washing m/c trom model
Hi, clean the sosp drain hose clug ,push with clean stick the hole of the hose.
Jan 27, 2008 | LG WD-12126RD Front Load Washer / Dryer
"CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Sep 01, 2007 | LG WM-3677HW Front Load Washer / Dryer
Lg Front loading washing machine
most times on the Lg washer the lint trap is clogged and something may be hitting the impeller on the pump and causing it not to drain. remove the plastic cover on the lower left bottom and unscrew the black lint filter at the pump. you will get water on the floor there is no way to avoid that. clean the trap and make sure there is nothing inside the housing to block the pump impeller. replace the trap and run a rince cycle to check for proper draining.
Aug 04, 2007 | LG WD-1080FD Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
