Question about Sony Ericsson S312 Mobile Phone - Silver
Blinking keypad but does not turn on - Sony Ericsson S312 Mobile Phone - Silver
I have had the same problem which began last weekend. First, battery died on one of the car transmitters. Now I can only program 2 out of the 4 that used to work -- AND -- now the wireless keypad won't...
I think your keypad has just failed and I am wondering about the "fix" exercises. Just for kicks in case you haven't try this one. The key is "immediately releasing the learn button." Press and hold the button on your remote and then press and immediately release the learn button. Do this for each remote.
Nov 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
The lights of the wireless keypad keeps blinking and i cant get them to turn off
Hi
Check the receiver is turned off or on . If the receiver is kept on then the wireless keyboard will also keep blinking
Thanks
Oct 27, 2010 | Sony Playstation 3 Wireless Keypad/Mouse
Blinking EO and F2
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Jun 24, 2009 | Kenmore 30172 / 30174 / 30179 Gas Single...
My normal cycle and cancel button lights are blinking on my kitchenaid dishwasher. Model # KUDP02CR8S2 Any suggestions?
Probably a keypad gone bad. Try replacing the keypad.
There is a troubleshooting guide behind the foot kick panel. It gives a sequence to test for a bad keypad. You can try that sequence to be sure.
Apr 20, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Cancel Light Flashing on Kitchen Aid Dishwasher
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Sep 01, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Craftsman garage door keypad
The blinking on your keypad simply means that a code of some sort was sent. Whether it be the right on or not. Lets try to reprogram the unit. Press the colored learn button on the motor head and then within 30 seconds enter in the 4 digit code followed by the up/down action button. The light bulb should flash to let you know it has been accepted. Wait 5 minutes and try. If it does not work replace the keypad.
Jul 17, 2008 | Sears Craftsman LiftMaster Chamberlain...
Model 13553965- programming wireless keypad
You have to buy a liftmaster or craftsman keypad
May 04, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sony Ericsson S312 Mobile Phone - Silver Logo
71 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
