Question about Pioneer Bcs-212 Home Theater System
My bcs-222 does not keep in memory the optical output
I connect it to a samsung led UE32B6000VP used a optical cable and also a hmdi cable.
For audio from my samsung led tv to my samsung av receiver must i use an optical cable connection?
There should be setting menu on tv whereby you can select RCA or optical.samsung units have automatic selectivity when you use optical cables so they will gives instant output when switched on....make sure you pull off the plastic ends covers ,they only go in one way into the connection ports.if you only have RCA leads you may have to set up the output audio on tv menu.
Jan 19, 2015 | RCA Audio Players & Recorders
Conrad johnson converter connection
Hi sherring, have you cheked that your cable isnt damaged? the connecton at either end might be loose.
Dec 31, 2007 | Technics SA-AX530 Receiver
Hello i bought a sound bar its a phillips cant get any sound out of it tried another tv same thing
Most sound bars are connected from the TV via the audio output. Try connecting out from tv with Toslink or optical cable. This should operate all of your tv audio.
Jan 03, 2015 | Toshiba Televison & Video
Trying to hook up Bose AV 321 media system to Samsung LED TV model
You can use a Optical to Analog audio adaptor (found all over the internet for under $30). You'll also need an optical cable that goes between the adaptor and TV. Be sure to set the audio output on the TV settings to PCM audio output, otherwise there will be no output.
Jan 22, 2014 | Samsung Televison & Video
No sound using optical out on sony bravia xbr
Optical Output is not generally used for a subwoofer output, nor is it used as a subwoofer input. Please check the type of connection again to be sure. Both methods are for digital use, however, the Optical output uses an LED for digital communications at the receiver, as well as an Optical transistor to receive this input at the subwoofer. Optical connections willing have a blicking light at the end of the cable that goes to the subwoofer, coaxial(RCA) connections will not flash. For more information, please contact me at my website audioserviceclinic.com. Thank you.
Sep 23, 2013 | Bose Lifestyle 28 System
I'm trying to connect my LED samsung tv to my pioneer amp M-L11 using the digital audio output. Can you tell me please if my stereo system should be able to be support my tv so that i am able to h
Pioneer Amp input is analog. if there is a headphones out
( no model for Samsung LED TV) , connect it , not using your
Fisual Digital Opitcal Toslink Cable.
If you really need to use the TV digital out you may need a Digital
to Analog converter , to be connected on Pioneer XC L11 Aux Input .
Optical is Out only for that model.
Sep 26, 2012 | Audio Players & Recorders
Hi.How can I connect SHARP HT-SB400 sound bar system to TV SAMSUNG UE40C6000 LED? I have RCA cable supplied by sharp, it's that possible? My SAMSUNG operation system is : T-VAL6DEUC-1016.0
You should be able to connect these but you'll need some extra adapters/converters/cables. The Sharp HT-SB400 has analog audio inputs (http://www.sharp.co.uk/cps/rde/xchg/gb/hs.xsl/-/html/product-details.htm?product=HTSB400&cat=10500 ). The Samsung UE40C6000 LED TV has a digital (optical) output and a headphone jack (http://www.samsung.com/uk/consumer/tv-audio-video/television/led-tv/UE40C6000RKXXU-spec ).
With a RCA (F/F) to 3.5 mm (M) adapter, you may be able to connect the headphone audio out to your sound bar directly. This is an example: http://www.cyberguys.com/product-details/?productid=4730 . I'm not sure if this will automatically disable the TV speakers.
The other option is to get a digital audio to analog audio converter. One of these is http://www.amazon.com/Digital-Audio-Analog-Converter/dp/B0013LWK3A . You'll also need the optical digital cable in addition to the RCA audio cable that you have. With this you'll have to follow the manual for turning on the digital audio output on the TV (under the Sound menu) and turn off the TV speakers.
I hope this helps.
Mar 04, 2012 | Sharp Audio Players & Recorders
I have a new samsung 40" led tv and i have
The specs say that it has an optical audio in on your home theater system. So the easiest way to hook up is to connect the optical audio out of your tv to the optical audio in of your home theater system and walla! What ever play on the tv will play on the home-theater system. You are looking for a Toslink optical audio cable
http://cgi.ebay.com/6-OPTICAL-FIBER-OPTIC-TOSLINK-DIGITAL-AUDIO-CABLE-6-FT-/370402436177
Jul 14, 2011 | Samsung UE40B7020 40 in. LED TV
Does the pioneer sx315 receiver work with the samsung led?
From memory, this amp does not have HDMI.
If this is the case, use an optical fibre cable for your connections.(Audio)
And if you want every thing to run through your amp you will also need to use component video cables (red/green/blue)
I would suggest the following.
Blue Ray to TV with HDMI.
HD Reciever to TV with HDMI.
TV AUDIO OUT to AMP with Optical Fibre.
This way, whatever is displayed on the tv, the sound will come throught the amp.
Hope this helps.
Sep 05, 2009 | Pioneer Audio Players & Recorders
System shuts it's self off at start-up repeatedly, then will stay on indefinately. hooked up to samsung lcd 52" and samsung blu-ray w/hmdi cables and optic link
LCD
BLU-RAY
HDMI
OPTIC LINK
Could it be that the system is adjusting itself to your custom choices and then functioning normally?
Apr 26, 2009 | Samsung HT-Z310T Theater System
Pioneer Bcs-212 Home Theater System Logo
35 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
